[mapserver-commits] r7483 - trunk/mapserver
Thu Mar 27 15:39:32 EDT 2008
Author: tomkralidis
Date: 2008-03-27 15:39:31 -0400 (Thu, 27 Mar 2008)
New Revision: 7483
   trunk/mapserver/mapogcsos.c
print warning when sos_procedure_item is not defined
for msSOSGetObservation (#2413)
Modified: trunk/mapserver/mapogcsos.c
--- trunk/mapserver/mapogcsos.c	2008-03-27 19:09:19 UTC (rev 7482)
+++ trunk/mapserver/mapogcsos.c	2008-03-27 19:39:31 UTC (rev 7483)
@@ -736,7 +736,7 @@
         /*TODO add location*/
-        /*precedure*/
+        /*procedure*/
         /* if a procedure_item is defined, we should extract the value for the
            attributes. If not dump what is found in the procedure metadata bug 2054*/
         if ((pszValue =  msOWSLookupMetadata(&(lp->metadata), "S", "procedure_item")))
@@ -777,6 +777,9 @@
         else if ((pszValue = msOWSLookupMetadata(&(lp->metadata), "S", "procedure")))
+            if (! msOWSLookupMetadata(&(lp->metadata), "S", "procedure_item"))
+                xmlAddSibling(psNode, xmlNewComment(BAD_CAST "WARNING: Optional metadata \"sos_procedure_item\" missing for sos:procedure.  If you have more than 1 procedures, sos:procedure will output them incorrectly."));
             sprintf(szTmp, "%s", "urn:ogc:def:procedure:");
             pszTmp = msStringConcatenate(pszTmp, szTmp);
             pszTmp = msStringConcatenate(pszTmp, (char *)pszValue);
@@ -787,7 +790,7 @@
             pszTmp = NULL;
-        /*observed propery*/
+        /*observed property*/
                                        "observedProperty_id");
         if (pszValue)
@@ -1052,8 +1055,9 @@
          /* procedure */
          if (pszProcedure) /*this should always be true since procedure is a manadtory element*/
-             //sprintf(szTmp, "%s", "urn:ogc:def:procedure:");
+             if (! msOWSLookupMetadata(&(lp->metadata), "S", "procedure_item") && msOWSLookupMetadata(&(lp->metadata), "S", "procedure"))
              pszTmp = msStringConcatenate(pszTmp, "urn:ogc:def:procedure:");
              pszTmp = msStringConcatenate(pszTmp, (char *)pszProcedure);
              psNode =  xmlNewChild(psObsNode, NULL, BAD_CAST "procedure", NULL);
@@ -1886,6 +1890,7 @@
      by the  offering,observedproperty filter done above */
   if (sosparams->pszProcedure) {
+    bLayerFound = 0;
     tokens = msStringSplit(sosparams->pszProcedure, ',', &n);
     if (tokens && n > 0) {
@@ -1899,8 +1904,10 @@
             for (j=0; j<n; j++) {
               for (k=0; k<n1; k++) {
-                if (strcasecmp(tokens1[k], tokens[j]) == 0)
+                if (strcasecmp(tokens1[k], tokens[j]) == 0) { /* found */
+                  bLayerFound = 1;
                   break;
               if (k<n1)
                 break;
@@ -2304,7 +2311,7 @@
                         psResultNode = xmlNewChild(psObservationNode, NULL, BAD_CAST "result", NULL);
                         for(j=0; j<GET_LAYER(map, i)->resultcache->numresults; j++)
-                            /*add a block serarator*/
+                            /*add a block separator*/
                             if (j > 0)
                                 pszBlockSep = msOWSLookupMetadata(&(map->web.metadata), "S",
