[mapserver-commits] r7488 - trunk/mapserver
Thu Mar 27 19:45:52 EDT 2008
Author: Assefa
Date: 2008-03-27 19:45:51 -0400 (Thu, 27 Mar 2008)
New Revision: 7488
   trunk/mapserver/mapswf.c
   trunk/mapserver/mapswf.h
correct memeory leaks (#2555)
Modified: trunk/mapserver/mapswf.c
--- trunk/mapserver/mapswf.c	2008-03-27 20:12:48 UTC (rev 7487)
+++ trunk/mapserver/mapswf.c	2008-03-27 23:45:51 UTC (rev 7488)
@@ -56,9 +56,189 @@
 SWFMovie GetCurrentMovie(mapObj *map, imageObj *image);
+/*                       void StoreDblData                              */
+/*      Keep tracks of the DblData allocated to properly free them      */
+/*                        Ticket #2555                                  */
+void StoreDblData(unsigned char *oDblData, imageObj *image)
+	int nDblData;
+	((SWFObj *)image->img.swf)->nDblDatas += 1;
+	nDblData = ((SWFObj *)image->img.swf)->nDblDatas;
+	if (!((SWFObj *)image->img.swf)->DblDatas)
+		((SWFObj *)image->img.swf)->DblDatas =
+			(unsigned char **)malloc(sizeof(oDblData)*1);
+    else
+        	(unsigned char **)realloc(((SWFObj *)image->img.swf)->DblDatas,
+        			sizeof(oDblData)*nDblData);
+	((SWFObj *)image->img.swf)->DblDatas[nDblData-1] = oDblData;
+/*                       void StoreShape                                */
+/*      Keep tracks of the SWFShape allocated to properly free them     */
+/*                        Ticket #2555                                  */
+void StoreShape(SWFShape oShape, imageObj *image)
+	int nShape;
+	((SWFObj *)image->img.swf)->nShapes += 1;
+	nShape = ((SWFObj *)image->img.swf)->nShapes;
+	if (!((SWFObj *)image->img.swf)->Shapes)
+		((SWFObj *)image->img.swf)->Shapes =
+	        	(SWFShape *)malloc(sizeof(SWFShape));
+	else
+        	(SWFShape *)realloc(((SWFObj *)image->img.swf)->Shapes,
+        			sizeof(SWFShape)*nShape);
+	((SWFObj *)image->img.swf)->Shapes[nShape-1] = oShape;
+/*                       void StoreInput                                */
+/*      Keep tracks of the SWFInput allocated to properly free them     */
+/*                        Ticket #2555                                  */
+void StoreInput(SWFInput oInput, imageObj *image)
+	int nInput;
+	((SWFObj *)image->img.swf)->nInputs += 1;
+	nInput = ((SWFObj *)image->img.swf)->nInputs;
+	if (!((SWFObj *)image->img.swf)->Inputs)
+		((SWFObj *)image->img.swf)->Inputs =
+	        	(SWFInput *)malloc(sizeof(SWFInput));
+	else
+        	(SWFInput *)realloc(((SWFObj *)image->img.swf)->Inputs,
+        			sizeof(SWFInput)*nInput);
+	((SWFObj *)image->img.swf)->Inputs[nInput-1] = oInput;
+/*                       void StoreBitmap                               */
+/*      Keep tracks of the SWFBitmap allocated to properly free them    */
+/*                        Ticket #2555                                  */
+void StoreBitmap(SWFBitmap oBitmap, imageObj *image)
+	int nBitmap;
+	((SWFObj *)image->img.swf)->nBitmaps += 1;
+	nBitmap = ((SWFObj *)image->img.swf)->nBitmaps;
+	if (!((SWFObj *)image->img.swf)->Bitmaps)
+		((SWFObj *)image->img.swf)->Bitmaps =
+	        	(SWFBitmap *)malloc(sizeof(SWFBitmap));
+	else
+        	(SWFBitmap *)realloc(((SWFObj *)image->img.swf)->Bitmaps,
+        			sizeof(SWFBitmap)*nBitmap);
+	((SWFObj *)image->img.swf)->Bitmaps[nBitmap-1] = oBitmap;
+/*                       void StoreButton                               */
+/*      Keep tracks of the SWFButton allocated to properly free them    */
+/*                        Ticket #2555                                  */
+void StoreButton(SWFButton oButton, imageObj *image)
+	int nButton;
+	((SWFObj *)image->img.swf)->nButtons += 1;
+	nButton = ((SWFObj *)image->img.swf)->nButtons;
+	if (!((SWFObj *)image->img.swf)->Buttons)
+		((SWFObj *)image->img.swf)->Buttons =
+			(SWFButton *)malloc(sizeof(oButton));
+	else
+			(SWFButton *)realloc(((SWFObj *)image->img.swf)->Buttons,
+					sizeof(oButton)*nButton);
+	((SWFObj *)image->img.swf)->Buttons[nButton-1] = oButton;
+/*                       void StoreFont                                 */
+/*      Keep tracks of the SWFFont allocated to properly free them      */
+/*                        Ticket #2555                                  */
+void StoreFont(SWFFont oFont, imageObj *image)
+	int nFont;
+	((SWFObj *)image->img.swf)->nFonts += 1;
+	nFont = ((SWFObj *)image->img.swf)->nFonts;
+	if (!((SWFObj *)image->img.swf)->Fonts)
+		((SWFObj *)image->img.swf)->Fonts =
+			(SWFFont *)malloc(sizeof(oFont));
+	else
+			(SWFFont *)realloc(((SWFObj *)image->img.swf)->Fonts,
+					sizeof(oFont)*nFont);
+	((SWFObj *)image->img.swf)->Fonts[nFont-1] = oFont;
+/*                       void StoreText                                 */
+/*      Keep tracks of the SWFText allocated to properly free them      */
+/*                        Ticket #2555                                  */
+void StoreText(SWFText oText, imageObj *image)
+	int nText;
+	((SWFObj *)image->img.swf)->nTexts += 1;
+	nText = ((SWFObj *)image->img.swf)->nTexts;
+	if (!((SWFObj *)image->img.swf)->Texts)
+		((SWFObj *)image->img.swf)->Texts =
+			(SWFText *)malloc(sizeof(oText));
+	else
+			(SWFText *)realloc(((SWFObj *)image->img.swf)->Texts,
+					sizeof(oText)*nText);
+	((SWFObj *)image->img.swf)->Texts[nText-1] = oText;
 /*                    gdImagePtr getTileImageFromSymbol                 */
 /*      Returns a gdimage from a symbol that will be used to fill       */
@@ -299,12 +479,13 @@
 /*                          SWFShape bitmap2shape                       */
-/*      Return a fillef polygon shape using a bitmap.                   */
+/*      Return a filled polygon shape using a bitmap.                   */
 SWFShape bitmap2shape(unsigned char *data,unsigned long size,int width,
-                      int height, byte flags)
+                      int height, byte flags, imageObj *image)
     SWFShape oShape;
+    SWFInput oBuffer;
     SWFFill oFill;
     SWFBitmap oBitmap;
@@ -312,20 +493,22 @@
         return NULL;
     oShape = newSWFShape();
-    oBitmap = newSWFBitmap_fromInput(newSWFInput_buffer(data,size));
+    oBuffer = newSWFInput_buffer(data,size);
+    StoreInput(oBuffer, image);
+    oBitmap = newSWFBitmap_fromInput(oBuffer);
+    StoreBitmap(oBitmap, image);
     oFill = SWFShape_addBitmapFill(oShape, oBitmap, flags);
     /* oFill = SWFShape_addBitmapFill(oShape, oBitmap, 0); */
     SWFShape_setRightFill(oShape, oFill);
+    destroySWFFill(oFill);
     SWFShape_drawLine(oShape, (float)width, 0.0);
     SWFShape_drawLine(oShape, 0.0, (float)height);
     SWFShape_drawLine(oShape, (float)-width, 0.0);
     SWFShape_drawLine(oShape, 0.0, (float)-height);
-    /* destroySWFBitmap(oBitmap); */
     return oShape;
@@ -333,7 +516,7 @@
 /*                        unsigned char *bitmap2dbl                     */
-/*      Coverts a bitmap to dbl bitmap suitable for ming.               */
+/*      Converts a bitmap to dbl bitmap suitable for ming.              */
 unsigned char *bitmap2dbl(unsigned char *data,int *size, int *bytesPerColor)
@@ -357,6 +540,7 @@
         dbldata[i] = data[j];
     *size = outsize + 14;
     return(dbldata);
@@ -421,7 +605,6 @@
     return(data);
 /*                          SWFShape gdImage2Shape                      */
@@ -431,7 +614,7 @@
 /*      Conversion functions were provided by :                         */
 /*            Jan Hartmann <jhart at frw.uva.nl>                           */
-SWFShape gdImage2Shape(gdImagePtr img)
+SWFShape gdImage2Shape(gdImagePtr img, imageObj *image)
     unsigned char *data, *dbldata;
     int size;
@@ -443,18 +626,18 @@
     data = gd2bitmap(img, &size, &bytesPerColor);
     dbldata = bitmap2dbl(data,&size,&bytesPerColor);
-    oShape = bitmap2shape(dbldata, size, img->sx, img->sy, SWFFILL_SOLID);
+    free(data); //memory leak cf ticket #2555
+    oShape = bitmap2shape(dbldata, size, img->sx, img->sy, SWFFILL_SOLID, image);
+    StoreDblData(dbldata, image); //memory leak cf ticket #2555
     return oShape;
 /*                       SWFButton BuildButtonFromGD                    */
 /*      Return a button object using a GD image.                        */
-SWFButton BuildButtonFromGD(gdImagePtr img)/* , colorObj *psHighlightColor) */
+SWFButton BuildButtonFromGD(gdImagePtr img, imageObj *image)/* , colorObj *psHighlightColor) */
     SWFShape oShape;
     SWFButton oButton;
@@ -464,7 +647,8 @@
     if (!img)
         return NULL;
-    oShape = gdImage2Shape(img);
+    oShape = gdImage2Shape(img, image);
+    StoreShape(oShape, image);
     oButton = newSWFButton();
     SWFButton_addShape(oButton, oShape,
@@ -473,8 +657,6 @@
     return oButton;
 /*                        SWFShape BuildEllipseShape                    */
@@ -485,6 +667,7 @@
                            colorObj *psFillColor, colorObj *psOutlineColor)
     SWFShape oShape;
+    SWFFill oFill;
@@ -495,14 +678,16 @@
         SWFShape_setLine(oShape, 0, (byte)psOutlineColor->red,
                          (byte)psOutlineColor->green, (byte)psOutlineColor->blue, 0xff);
-    if (psFillColor)
-        SWFShape_setRightFill(oShape,
-                              SWFShape_addSolidFill(oShape,
-                                                    (byte)psFillColor->red,
-                                                    (byte)psFillColor->green,
-                                                    (byte)psFillColor->blue,
-                                                    0xff));
+    if (psFillColor) {
+    	/* correct memory leak  by catching the SWFFill*/
+    	oFill = SWFShape_addSolidFill(oShape, (byte)psFillColor->red,
+    			(byte)psFillColor->green,
+    	        (byte)psFillColor->blue,
+    	        0xff);
+        SWFShape_setRightFill(oShape, oFill);
+        /* and destroying it */
     SWFShape_movePenTo(oShape, (float)(nX-(nWidth/2)), (float)nY);
@@ -538,7 +723,7 @@
 SWFButton BuildEllipseButton(int nX, int nY, int nWidth, int nHeight,
                              colorObj *psFillColor, colorObj *psOutlineColor,
                              colorObj *psHightlightColor,
-                             int nLayerIndex, int nShapeIndex)
+                             int nLayerIndex, int nShapeIndex, imageObj *image)
     SWFShape oShape;
     SWFButton oButton;
@@ -550,14 +735,18 @@
     oShape = BuildEllipseShape(nX, nY, nWidth, nHeight, psFillColor,
                                psOutlineColor);
                        SWFBUTTON_UP | SWFBUTTON_HIT | SWFBUTTON_DOWN);
     if (psHightlightColor)
         oShape = BuildEllipseShape(nX, nY, nWidth, nHeight, psHightlightColor,
                                    NULL);
     SWFButton_addShape(oButton, oShape, SWFBUTTON_OVER);
     if (nLayerIndex >=0 && nShapeIndex >= 0)
@@ -598,6 +787,7 @@
     int i, j;
     SWFShape oShape;
+    SWFFill oFill;
     if (p && p->numlines > 0 && (psFillColor !=NULL || psOutlineColor != NULL))
@@ -606,13 +796,15 @@
             SWFShape_setLine(oShape, width, (byte)psOutlineColor->red,
         if (psFillColor)
-                                                        0xff));
+        			(byte)psFillColor->red,
+                    0xff);
        for (i = 0; i < p->numlines; i++)
            if (p->line[i].numpoints)
@@ -642,6 +834,7 @@
     SWFShape oShape = newSWFShape();
+    SWFFill oFill;
     int i = 0;
     if (psFillColor == NULL && psOutlineColor == NULL)
@@ -652,13 +845,13 @@
         if (psOutlineColor)
-                                                    0xff));
+                0xff);
         /*SWFShape_setRightFill(oShape,
                               SWFShape_addSolidFill(oShape, 0xFF,
                                                     0,
@@ -733,55 +926,60 @@
                                colorObj *psHighlightColor,
-    SWFButton b;
+    SWFButton oButton;
+    SWFShape oShape;
     /* int bFill = 0; */
-    b = newSWFButton();
-    SWFButton_addShape(b, BuildShape(adfPoints, nPoints,
-                                     psFillColor, psOutlineColor),
+    oButton = newSWFButton();
+    oShape = BuildShape(adfPoints, nPoints, psFillColor, psOutlineColor);
+    SWFButton_addShape(oButton, oShape,
     if (psHighlightColor)
-        if(psFillColor)
-                                             psHighlightColor, NULL),
-                               SWFBUTTON_OVER);
+        if(psFillColor)
+        	oShape = BuildShape(adfPoints, nPoints, psHighlightColor, NULL);
+            SWFButton_addShape(oButton, oShape, SWFBUTTON_OVER);
         else if (psOutlineColor)
-                                              NULL, psHighlightColor),
-                                SWFBUTTON_OVER);
+        	oShape = BuildShape(adfPoints, nPoints, NULL, psHighlightColor);
         sprintf(gszAction, "_root.ElementSelected(%d,%d,%d);", nLayerIndex,
                 nShapeIndex, MOUSEUP);
-        SWFButton_addAction(b, compileSWFActionCode(gszAction),
+        SWFButton_addAction(oButton, compileSWFActionCode(gszAction),
                             SWFBUTTON_MOUSEUP);
                 nShapeIndex, MOUSEDOWN);
                             SWFBUTTON_MOUSEDOWN);
                 nShapeIndex, MOUSEOVER);
                             SWFBUTTON_MOUSEOVER);
                 nShapeIndex, MOUSEOUT);
                             SWFBUTTON_MOUSEOUT);
-    return b;
+    return oButton;
@@ -877,12 +1075,33 @@
     ((SWFObj *)image->img.swf)->map = map;
     ((SWFObj *)image->img.swf)->nCurrentLayerIdx = -1;
-     ((SWFObj *)image->img.swf)->nCurrentShapeIdx = -1;
+    ((SWFObj *)image->img.swf)->nCurrentShapeIdx = -1;
     ((SWFObj *)image->img.swf)->nLayerMovies = 0;
     ((SWFObj *)image->img.swf)->pasMovies = NULL;
     ((SWFObj *)image->img.swf)->nCurrentMovie = -1;
+    ((SWFObj *)image->img.swf)->nFonts = 0;
+    ((SWFObj *)image->img.swf)->Fonts = NULL;
+    ((SWFObj *)image->img.swf)->nTexts = 0;
+    ((SWFObj *)image->img.swf)->Texts = NULL;
+    ((SWFObj *)image->img.swf)->nShapes = 0;
+    ((SWFObj *)image->img.swf)->Shapes = NULL;
+    ((SWFObj *)image->img.swf)->nBitmaps = 0;
+    ((SWFObj *)image->img.swf)->Bitmaps = NULL;
+    ((SWFObj *)image->img.swf)->nInputs = 0;
+    ((SWFObj *)image->img.swf)->Inputs = NULL;
+    ((SWFObj *)image->img.swf)->nButtons = 0;
+    ((SWFObj *)image->img.swf)->Buttons = NULL;
+    ((SWFObj *)image->img.swf)->nDblDatas = 0;
+    ((SWFObj *)image->img.swf)->DblDatas = NULL;
     ((SWFObj *)image->img.swf)->panLayerIndex = NULL;
     ((SWFObj *)image->img.swf)->nTmpCount = 0;
@@ -928,6 +1147,7 @@
                           msCreateDefaultOutputFormat(map, driver),
                           map->web.imagepath, map->web.imageurl);
+    free(driver);
     return image;
@@ -1309,7 +1529,8 @@
             gdImageStringFT(imgtmp, bbox, ((symbol->antialias)?(fc):-(fc)),
                             font, size, 0, 1, 1, symbol->character);
             /* oShape = gdImage2Shape(imgtmp); */
-            oButton = BuildButtonFromGD(imgtmp);/* , NULL); */
+            oButton = BuildButtonFromGD(imgtmp, image);/* , NULL); */
+            StoreButton(oButton, image);
             AddMouseActions(oButton, nLayerIndex, nShapeIndex);
             oDisplay = SWFMovie_add(GetCurrentMovie(map, image),
                                     oButton);
@@ -1327,8 +1548,9 @@
                 offset_y = MS_NINT(p->y - .5*symbol->img->sy);
                 /* gdImageCopy(img, symbol->img, offset_x, offset_y, 0, 0,  */
                 /* symbol->img->sx, symbol->img->sy); */
-                oButton = BuildButtonFromGD(symbol->img);/* , NULL); */
-                AddMouseActions(oButton, nLayerIndex, nShapeIndex);
+                oButton = BuildButtonFromGD(symbol->img, image);/* , NULL); */
+		AddMouseActions(oButton, nLayerIndex, nShapeIndex);
                                         oButton);
@@ -1354,8 +1576,9 @@
                 /* And save the image  -- could also use gdImageJpeg */
                 /* gdImageJpeg(imgtmp, out, 0); */
                                         oButton);
@@ -1402,8 +1625,10 @@
                                      MS_NINT(scale*symbol->points[0].y),
                                      psFillColor, psOutlineColor,
                                      &sColorHighlightObj,
-                                     nLayerIndex, nShapeIndex);
-                oDisplay = SWFMovie_add(GetCurrentMovie(map, image), oButton);
+                                     nLayerIndex, nShapeIndex, image);
+		// Ticket #2555 memory leak : need to store buttons to properly destroy them
+		oDisplay = SWFMovie_add(GetCurrentMovie(map, image), oButton);
@@ -1418,8 +1643,8 @@
                                            psFillColor, NULL,
@@ -1464,8 +1689,8 @@
                 oButton = BuildButtonPolygon(mPoints, symbol->numpoints,
@@ -1490,6 +1715,7 @@
                                           psFillColor,
             } /* end if-then-else */
@@ -1641,7 +1867,7 @@
 /*      nX,nY using the font pszFontFile.                               */
 SWFText DrawText(char *string, int nX, int nY, char *pszFontFile,
-                 double dfSize, colorObj *psColor)
+                 double dfSize, colorObj *psColor, imageObj *image)
     SWFText     oText = NULL;
     SWFFont     oFont = NULL;
@@ -1658,7 +1884,10 @@
         fclose(f);
         if (oFont)
-            oText = newSWFText();
+            // ticket #2555 memory leak
+            StoreFont(oFont, image);
+	    oText = newSWFText();
             SWFText_setFont(oText, oFont);
             SWFText_moveTo(oText, (float)nX, (float)nY);
             SWFText_setColor(oText, (byte)psColor->red, (byte)psColor->green, (byte)psColor->blue,
@@ -1778,18 +2007,18 @@
         if (nLayerIndex < 0 || nShapeIndex < 0)
             oShape = DrawShapePolyline(p, &sFc, width);
             SWFMovie_add(GetCurrentMovie(map, image), oShape);
-            /* destroySWFShape(oShape); */
         else
             oButton = DrawButtonPolyline(p, &sFc, &sColorHighlightObj, nLayerIndex,
                                          nShapeIndex, width);
-             sprintf(gszTmp, "button%d",((SWFObj *)image->img.swf)->nTmpCount);
-             ((SWFObj *)image->img.swf)->nTmpCount++;
-             SWFDisplayItem_setName(oDisplay, gszTmp);
-            /* destroySWFButton(oButton); */
+            sprintf(gszTmp, "button%d",((SWFObj *)image->img.swf)->nTmpCount);
+            ((SWFObj *)image->img.swf)->nTmpCount++;
+            SWFDisplayItem_setName(oDisplay, gszTmp);
         return;
@@ -1919,6 +2148,7 @@
             oShape = DrawShapeFilledPolygon(p, psFillColor, psOutlineColor,
                                             width);
         else
@@ -1926,6 +2156,7 @@
             oButton = DrawButtonFilledPolygon(p, psFillColor, psOutlineColor,
@@ -1957,7 +2188,8 @@
         data = gd2bitmap(tile, &size, &bytesPerColor);
         oShape = bitmap2shape(dbldata, size, tile->sx, tile->sy,
-                              SWFFILL_SOLID);/* SWFFILL_TILED_BITMAP); */
+                              SWFFILL_SOLID, image);/* SWFFILL_TILED_BITMAP); */
     else
@@ -1967,6 +2199,7 @@
                                                 width);
             else
@@ -1974,7 +2207,8 @@
@@ -2005,6 +2239,9 @@
     double         size = 0;
     int         drawShadow=0;
     char szPath[MS_MAXPATHLEN];
+    SWFDisplayItem oShadowDisplay;
+    SWFDisplayItem oDisplay;
 /*      if not SWF, return.                                             */
@@ -2091,35 +2328,35 @@
 /*      axis.... We will then move the text SWFDisplayItem_moveTo       */
 /*      and rotate it.                                                  */
-    /* first  draw the shadow with a x+1,y+1 position or using the shadowsize if defined*/
+    /* first draw the shadow with a x+1,y+1 position or using the shadowsize if defined*/
     if (drawShadow)
-        oShadowText = DrawText(string, 0, 0, msBuildPath(szPath, fontset->filename, font), size, &sShadowColor);
+        oShadowText = DrawText(string, 0, 0, msBuildPath(szPath, fontset->filename, font), size, &sShadowColor, image);
         if (oShadowText)
-            SWFDisplayItem oShadowDisplay;
+        	StoreText(oShadowText, image);
             /* nTmp = ((SWFObj *)image->img.swf)->nCurrentMovie; */
             oShadowDisplay = SWFMovie_add(GetCurrentMovie(map, image), oShadowText);
             if (label->shadowsizex > 0 && label->shadowsizey > 0)
-              SWFDisplayItem_moveTo(oShadowDisplay, (float)x + label->shadowsizex,
+            	SWFDisplayItem_moveTo(oShadowDisplay, (float)x + label->shadowsizex,
                                     (float)y + label->shadowsizey);
             else
-               SWFDisplayItem_moveTo(oShadowDisplay, (float)x + 1, (float)y + 1);
+            	SWFDisplayItem_moveTo(oShadowDisplay, (float)x + 1, (float)y + 1);
             SWFDisplayItem_rotate(oShadowDisplay, (float)label->angle);
     /* oText = DrawText(string, x, y, msBuildPath(szPath, fontset->filename, font), size, &sColor); */
-    oText = DrawText(string, 0, 0, msBuildPath(szPath, fontset->filename, font), size, &sColor);
+    oText = DrawText(string, 0, 0, msBuildPath(szPath, fontset->filename, font), size, &sColor, image);
     if (oText)
-         SWFDisplayItem oDisplay;
+    	StoreText(oText, image);
         oDisplay = SWFMovie_add(GetCurrentMovie(map, image), oText);
         SWFDisplayItem_moveTo(oDisplay, (float)x, (float)y);
         SWFDisplayItem_rotate(oDisplay, (float)label->angle);
     return 0;
@@ -2133,7 +2370,7 @@
 int msGetLabelSizeSWF(char *string, labelObj *label, rectObj *rect,
                       fontSetObj *fontset, double scalefactor)
-    SWFText    oText = NULL;
+    SWFText     oText = NULL;
     char        *font;
     double      dfWidth = 0.0;
@@ -2165,7 +2402,7 @@
         fclose(f);
         if (oFont)
             /* SWFText_addString(oText, string, NULL); */
             dfWidth = 0.0;
@@ -2174,8 +2411,8 @@
             if (dfWidth <=0)
               return -1;
-            /* destroySWFText(oText); */
-            /* destroySWFFont(oFont); */
+            destroySWFText(oText);
+            destroySWFFont(oFont);
@@ -2279,7 +2516,8 @@
         image->format->renderer = MS_RENDER_WITH_GD;
         msDrawLabelCache(imagetmp, map);
         image->format->renderer = orig_renderer;
-        oShape = gdImage2Shape(imagetmp->img.gd);
+        oShape = gdImage2Shape(imagetmp->img.gd, image);
         return 0;
@@ -2581,8 +2819,9 @@
     if (msDrawWMSLayerLow(nLayerId, pasReqInfo, numRequests, map, layer,
                           image_tmp) != -1)
-        oShape = gdImage2Shape(image_tmp->img.gd);
+        oShape = gdImage2Shape(image_tmp->img.gd, image);
         if (bFreeImage)
@@ -2635,8 +2874,9 @@
     if (msDrawRasterLayerLow(map, layer, image_tmp) != -1)
         if (bFreeImage)
           msFreeImage( image_tmp );
@@ -2971,7 +3211,7 @@
         sprintf(szAction, "stop();");
         oAction = compileSWFActionCode(szAction);
         SWFMovie_add(((SWFObj *)image->img.swf)->sMainMovie, oAction);
 #ifdef MING_VERSION_03
         SWFMovie_save(((SWFObj *)image->img.swf)->sMainMovie, filename, -1);
 #else
@@ -2979,7 +3219,7 @@
 #endif
         /* test */
         /* SWFMovie_save(((SWFObj *)image->img.swf)->sMainMovie, "c:/tmp/ms_tmp/main.swf");   */
         if( bFileIsTemporary )
           fp = fopen( filename, "rb" );
@@ -3030,13 +3270,55 @@
     int i = 0;
     if (image && MS_DRIVER_SWF(image->format) )
-        destroySWFMovie(((SWFObj *)image->img.swf)->sMainMovie);
-        for (i=0; i<((SWFObj *)image->img.swf)->nLayerMovies; i++)
-            destroySWFMovie(((SWFObj *)image->img.swf)->pasMovies[i]);
+    	/* fonts */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nFonts; i++)
+    		destroySWFFont(((SWFObj *)image->img.swf)->Fonts[i]);
+    	free(((SWFObj *)image->img.swf)->Fonts);
+    	/* texts */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nTexts; i++)
+    		destroySWFText(((SWFObj *)image->img.swf)->Texts[i]);
+    	free(((SWFObj *)image->img.swf)->Texts);
+    	/* bitmaps */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nBitmaps; i++)
+    		destroySWFBitmap(((SWFObj *)image->img.swf)->Bitmaps[i]);
+    	free(((SWFObj *)image->img.swf)->Bitmaps);
+    	/* inputs */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nInputs; i++)
+    		destroySWFInput(((SWFObj *)image->img.swf)->Inputs[i]);
+    	free(((SWFObj *)image->img.swf)->Inputs);
+    	/* shapes */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nShapes; i++)
+    		destroySWFShape(((SWFObj *)image->img.swf)->Shapes[i]);
+    	free(((SWFObj *)image->img.swf)->Shapes);
+    	/* buttons */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nButtons; i++)
+    		// need to check if some of the buttons disappeared or couldn't be created ! */
+    		if (((SWFObj *)image->img.swf)->Buttons[i])
+    			destroySWFButton(((SWFObj *)image->img.swf)->Buttons[i]);
+    	free(((SWFObj *)image->img.swf)->Buttons);
+    	/* movies */
+    	for (i=0; i<((SWFObj *)image->img.swf)->nLayerMovies; i++)
+    		destroySWFMovie(((SWFObj *)image->img.swf)->pasMovies[i]);
+    	free(((SWFObj *)image->img.swf)->pasMovies);
+    	destroySWFMovie(((SWFObj *)image->img.swf)->sMainMovie);
+        /* DblData images */
+        for (i=0; i<((SWFObj *)image->img.swf)->nDblDatas; i++)
+        	free(((SWFObj *)image->img.swf)->DblDatas[i]);
+        free(((SWFObj *)image->img.swf)->DblDatas);
         ((SWFObj *)image->img.swf)->map = NULL;
+        free(((SWFObj *)image->img.swf)->panLayerIndex);
+        free(image->img.swf);
@@ -3126,8 +3408,9 @@
         /* msLoadPalette(imagetmp->img.gd, &(map->palette), map->imagecolor); */
         msDrawVectorLayer(map, layer, imagetmp);
         if (bFreeImage)
Modified: trunk/mapserver/mapswf.h
--- trunk/mapserver/mapswf.h	2008-03-27 20:12:48 UTC (rev 7487)
+++ trunk/mapserver/mapswf.h	2008-03-27 23:45:51 UTC (rev 7488)
@@ -24,6 +24,20 @@
   int nCurrentLayerIdx;
   int nCurrentShapeIdx;
+  SWFFont *Fonts; /* keep tracks of the fonts used to properly free them */
+  int nFonts;
+  SWFText *Texts; /* keep tracks of the texts used to properly free them */
+  int nTexts;
+  SWFShape *Shapes; /* keep tracks of the shapes used to properly free them */
+  int nShapes;
+  SWFButton *Buttons; /* keep tracks of the buttons used to properly free them */
+  int nButtons;
+  SWFBitmap *Bitmaps; /* keep tracks of the bitmaps used to properly free them */
+  int nBitmaps;
+  SWFInput *Inputs; /* keep tracks of the input buffers used to properly free them */
+  int nInputs;
+  unsigned char **DblDatas; /* keep tracks of the DblDatas used to properly free them */
+  int nDblDatas;
   void    *imagetmp;  /*used when the output format is SINGLE */
                       /*(one movie for the whole map)*/
