[mapserver-commits] r7556 - trunk/docs/howto
Fri May 2 10:25:34 EDT 2008
Author: Assefa
Date: 2008-05-02 10:25:33 -0400 (Fri, 02 May 2008)
New Revision: 7556
   trunk/docs/howto/tile_mode.txt
Minor changes in the examples code
Modified: trunk/docs/howto/tile_mode.txt
--- trunk/docs/howto/tile_mode.txt	2008-05-02 13:33:51 UTC (rev 7555)
+++ trunk/docs/howto/tile_mode.txt	2008-05-02 14:25:33 UTC (rev 7556)
@@ -129,10 +129,10 @@
       if (GBrowserIsCompatible()) {
         var urlTemplate = 'http://localhost/cgi-bin/mapserv?';
             urlTemplate += 'map=/var/map.map&';
-            urlTemplate += 'layers=layer1,layer2&';
+            urlTemplate += 'layers=layer1 layer2&';
             urlTemplate += 'mode=tile&';
             urlTemplate += 'tilemode=gmap&';
-            urlTemplate == 'tile={X}+{Y}+{Z}';
+            urlTemplate += 'tile={X}+{Y}+{Z}';
         var myLayer = new GTileLayer(null,0,18,{
                                      tileUrlTemplate:urlTemplate,
                                      isPng:true,
@@ -173,10 +173,10 @@
                                      isPng:true,
@@ -224,7 +224,7 @@
           var url = "http://localhost/cgi-bin/mapserv?";
           url += "map=/var/map.map&";
           url += "mode=tile&";
-          url += "layers=layer1,layer2&";
+          url += "layers=layer1 layer2&";
           url += "tilemode=ve&";
           url += "tile=%4";
