[mapserver-commits] r7561 - trunk/mapserver
Mon May 5 23:37:04 EDT 2008
Author: sdlime
Date: 2008-05-05 23:37:04 -0400 (Mon, 05 May 2008)
New Revision: 7561
   trunk/mapserver/maptemplate.c
A bit more tag handling code for RFC36.
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2008-05-05 19:41:10 UTC (rev 7560)
+++ trunk/mapserver/maptemplate.c	2008-05-06 03:37:04 UTC (rev 7561)
@@ -793,10 +793,10 @@
   char *preTag, *postTag; /* text before and after the tag */
-  char *tag, *tagStart, *tagEnd;
+  char *tag, *tagInstance, *tagStart;
   hashTableObj *tagArgs=NULL;
-  int i, j;
+  int i, j, status;
   if(!*line) {
     msSetError(MS_WEBERR, "Invalid line pointer.", "processFeaturesTag()");
@@ -818,7 +818,7 @@
   if(getInlineTag("features", *line, &tag) != MS_SUCCESS) {
-    msSetError(MS_WEBERR, "Malformed features tag.", "processResultSetTag()");
+    msSetError(MS_WEBERR, "Malformed features tag.", "processFeaturesTag()");
     return MS_FAILURE;
@@ -830,12 +830,59 @@
   /* we know the layer has query results or we wouldn't be in this code */
+  status = msLayerOpen(layer); /* open the layer */
+  if(status != MS_SUCCESS) return status;
+  status = msLayerGetItems(layer); /* retrieve all the item names */
+  if(layer->numjoins > 0) { /* initialize necessary JOINs here */
+    for(j=0; j<layer->numjoins; j++) {
+      status = msJoinConnect(layer, &(layer->joins[j]));
+  mapserv->LRN = 1; /* layer result counter */
+  msInitShape(&(mapserv->ResultShape));
+  for(i=0; i<layer->resultcache->numresults; i++) {
+    status = msLayerGetShape(layer, &(mapserv->ResultShape), layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+    /* prepare any necessary JOINs here (one-to-one only) */
+        if(layer->joins[j].type == MS_JOIN_ONE_TO_ONE) {
+          msJoinPrepare(&(layer->joins[j]), &(mapserv->ResultShape));
+          msJoinNext(&(layer->joins[j])); /* fetch the first row */
+    /* process the tag */
+    tagInstance = strdup(tag); /* work from a copy */
+    tagInstance = processLine(mapserv, tagInstance, NULL, QUERY); /* do substitutions */
+    *line = msStringConcatenate(*line, tagInstance); /* grow the line */
+    free(tagInstance);
+    msFreeShape(&(mapserv->ResultShape)); /* init too */
+    mapserv->RN++; /* increment counters */
+    mapserv->LRN++;
+  msLayerClose(layer);
+  mapserv->ResultLayer = NULL; /* necessary? */
   *line = msStringConcatenate(*line, postTag);
   ** clean up
   free(postTag);
+  free(tag);
   return(MS_SUCCESS);
