[mapserver-commits] r7569 - trunk/mapserver
Wed May 7 02:43:16 EDT 2008
Author: sdlime
Date: 2008-05-07 02:43:15 -0400 (Wed, 07 May 2008)
New Revision: 7569
   trunk/mapserver/mapoutput.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/maptemplate.c
   trunk/mapserver/maptemplate.h
More RFC work. Added TEMPLATE output format and feature tag support.
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2008-05-07 04:36:01 UTC (rev 7568)
+++ trunk/mapserver/mapoutput.c	2008-05-07 06:43:15 UTC (rev 7569)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Various support code related to the outputFormatObj.
@@ -272,8 +272,17 @@
         format->extension = strdup("svg");
         format->renderer = MS_RENDER_WITH_SVG;
+    if( strcasecmp(driver,"template") == 0 ) {
+      format = msAllocOutputFormat( map, "template", driver );
+      format->mimetype = strdup("text/html");
+      format->extension = strdup("html");
+      format->imagemode = 0;
+      format->renderer = MS_RENDER_WITH_TEMPLATE;
     if( format != NULL )
-        format->inmapfile = MS_FALSE;
+      format->inmapfile = MS_FALSE;
     return format;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-05-07 04:36:01 UTC (rev 7568)
+++ trunk/mapserver/mapserver.h	2008-05-07 06:43:15 UTC (rev 7569)
@@ -277,15 +277,16 @@
 #define MS_DRIVER_IMAGEMAP(format)  (strncasecmp((format)->driver,"imagemap",8)==0)
 #define MS_DRIVER_SVG(format) (strncasecmp((format)->driver,"svg",3)==0)
 #define MS_DRIVER_AGG(format) (strncasecmp((format)->driver,"agg/",3)==0)
+#define MS_DRIVER_TEMPLATE(format) (strncasecmp((format)->driver,"template",8)==0)
-#define MS_RENDER_WITH_GD 1
+#define MS_RENDER_WITH_GD       1
 #define MS_RENDER_WITH_SWF      2
 #define MS_RENDER_WITH_RAWDATA  3
-#define MS_RENDER_WITH_PDF  4
+#define MS_RENDER_WITH_PDF      4
 #define MS_RENDER_WITH_IMAGEMAP 5
 #define MS_RENDER_WITH_SVG      6
 #define MS_RENDER_WITH_AGG      7
+#define MS_RENDER_WITH_TEMPLATE 8 /* query results only */
 #define MS_RENDERER_GD(format)  ((format)->renderer == MS_RENDER_WITH_GD)
 #define MS_RENDERER_SWF(format) ((format)->renderer == MS_RENDER_WITH_SWF)
@@ -294,6 +295,7 @@
 #define MS_RENDERER_IMAGEMAP(format) ((format)->renderer == MS_RENDER_WITH_IMAGEMAP)
 #define MS_RENDERER_SVG(format) ((format)->renderer == MS_RENDER_WITH_SVG)
 #define MS_RENDERER_AGG(format) ((format)->renderer == MS_RENDER_WITH_AGG)
+#define MS_RENDERER_TEMPLATE(format) ((format)->renderer == MS_RENDER_WITH_TEMPLATE)
 #define MS_CELLSIZE(min,max,d) ((max - min)/(d-1)) /* where min/max are from an MapServer pixel center-to-pixel center extent */
 #define MS_OWS_CELLSIZE(min,max,d) ((max - min)/d) /* where min/max are from an OGC pixel outside edge-to-pixel outside edge extent */
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2008-05-07 04:36:01 UTC (rev 7568)
+++ trunk/mapserver/maptemplate.c	2008-05-07 06:43:15 UTC (rev 7569)
@@ -178,60 +178,69 @@
   return MS_SUCCESS;
-int msReturnTemplateQuery(mapservObj *mapserv, char* pszMimeType, char **papszBuffer)
+int msReturnTemplateQuery(mapservObj *mapserv, char *queryFormat, char **papszBuffer)
   imageObj *img = NULL;
   int status;
   char buffer[1024];
-  if(!pszMimeType) {
-    msSetError(MS_WEBERR, "Mime type not specified.", "msReturnTemplateQuery()");
+  outputFormatObj *outputFormat;
+  if(!queryFormat) {
+    msSetError(MS_WEBERR, "Return format/mime-type not specified.", "msReturnTemplateQuery()");
     return MS_FAILURE;
-  if(mapserv->Map->querymap.status) {
-    checkWebScale(mapserv);
-    img = msDrawMap(mapserv->Map, MS_TRUE);
-    if(!img) return MS_FAILURE;
+  /* does the format reference an outputFormatObj */
+  if((outputFormat = msSelectOutputFormat( mapserv->Map, queryFormat)) != NULL) {
-    snprintf(buffer, 1024, "%s%s%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+    printf("got an output format!\n");
-    status = msSaveImage(mapserv->Map, img, buffer);
-    if(status != MS_SUCCESS) return status;
+  } else {
+    if(mapserv->Map->querymap.status) {
+      checkWebScale(mapserv);
-    msFreeImage(img);
+      img = msDrawMap(mapserv->Map, MS_TRUE);
+      if(!img) return MS_FAILURE;
-    if((mapserv->Map->legend.status == MS_ON || mapserv->UseShapes) && mapserv->Map->legend.template == NULL) {
-      img = msDrawLegend(mapserv->Map, MS_FALSE);
-      snprintf(buffer, 1024, "%s%sleg%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+      snprintf(buffer, 1024, "%s%s%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
       msFreeImage(img);
+      if((mapserv->Map->legend.status == MS_ON || mapserv->UseShapes) && mapserv->Map->legend.template == NULL) {
+        img = msDrawLegend(mapserv->Map, MS_FALSE);
+        snprintf(buffer, 1024, "%s%sleg%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+        status = msSaveImage(mapserv->Map, img, buffer);
+        if(status != MS_SUCCESS) return status;
+        msFreeImage(img);
-    if(mapserv->Map->scalebar.status == MS_ON) {
-      img = msDrawScalebar(mapserv->Map);
-      snprintf(buffer, 1024, "%s%ssb%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
-      status = msSaveImage( mapserv->Map, img, buffer);
-      msFreeImage(img);
+      if(mapserv->Map->scalebar.status == MS_ON) {
+        img = msDrawScalebar(mapserv->Map);
+        snprintf(buffer, 1024, "%s%ssb%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+        status = msSaveImage( mapserv->Map, img, buffer);
+        msFreeImage(img);
-    if(mapserv->Map->reference.status == MS_ON) {
-      img = msDrawReferenceMap(mapserv->Map);
-       snprintf(buffer, 1024, "%s%sref%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
-       msFreeImage(img);
+      if(mapserv->Map->reference.status == MS_ON) {
+        img = msDrawReferenceMap(mapserv->Map);
+        snprintf(buffer, 1024, "%s%sref%s.%s", mapserv->Map->web.imagepath, mapserv->Map->name, mapserv->Id, MS_IMAGE_EXTENSION(mapserv->Map->outputformat));
+        msFreeImage(img);
+    if((status = msReturnQuery(mapserv, queryFormat, papszBuffer)) != MS_SUCCESS)
+      return status;
-  if((status = msReturnQuery(mapserv, pszMimeType, papszBuffer)) != MS_SUCCESS)
-    return status;
   return MS_SUCCESS;
@@ -844,17 +853,17 @@
   mapserv->LRN = 1; /* layer result counter */
-  msInitShape(&(mapserv->ResultShape));
+  msInitShape(&(mapserv->resultshape));
   for(i=0; i<layer->resultcache->numresults; i++) {
-    status = msLayerGetShape(layer, &(mapserv->ResultShape), layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+    status = msLayerGetShape(layer, &(mapserv->resultshape), layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
     /* prepare any necessary JOINs here (one-to-one only) */
     if(layer->numjoins > 0) {
       for(j=0; j<layer->numjoins; j++) {
         if(layer->joins[j].type == MS_JOIN_ONE_TO_ONE) {
-          msJoinPrepare(&(layer->joins[j]), &(mapserv->ResultShape));
+          msJoinPrepare(&(layer->joins[j]), &(mapserv->resultshape));
           msJoinNext(&(layer->joins[j])); /* fetch the first row */
@@ -867,7 +876,7 @@
     *line = msStringConcatenate(*line, tagInstance); /* grow the line */
     free(tagInstance);
-    msFreeShape(&(mapserv->ResultShape)); /* init too */
+    msFreeShape(&(mapserv->resultshape)); /* init too */
     mapserv->RN++; /* increment counters */
     mapserv->LRN++;
@@ -957,10 +966,16 @@
   if(lp->resultcache && lp->resultcache->numresults > 0) {
     /* output the tag content */
+    *line = msStringConcatenate(*line, tag);
   *line = msStringConcatenate(*line, postTag);
+  /* clean up */
+  msFreeHashTable(tagArgs); tagArgs=NULL;
+  free(postTag);
+  free(tag);
   return(MS_SUCCESS);
@@ -2632,7 +2647,7 @@
   if((outbuf = strdup("")) == NULL) return(NULL); /* empty at first */
-  msJoinPrepare(join, &(mapserv->ResultShape)); /* execute the join */
+  msJoinPrepare(join, &(mapserv->resultshape)); /* execute the join */
   while(msJoinNext(join) == MS_SUCCESS) {
     /* First time through, deal with the header (if necessary) and open the main template. We only */
     /* want to do this if there are joined records. */
@@ -3036,11 +3051,11 @@
     /* if(ResultLayer->description) outstr = msReplaceSubstring(outstr, "[cd]", ResultLayer->description); // current layer description     */
+  if(processResultSetTag(mapserv, &outstr, stream) != MS_SUCCESS)
+    return(NULL);
   if(mode == QUERY) { /* return shape and/or values  */
-    if(processResultSetTag(mapserv, &outstr, stream) != MS_SUCCESS)
-      return(NULL);
     /* allow layer metadata access in a query template, within the context of a query no layer name is necessary */
     if(&(mapserv->ResultLayer->metadata) && strstr(outstr, "[metadata_")) {
       for(i=0; i<MS_HASHSIZE; i++) {
@@ -3058,45 +3073,45 @@
-    sprintf(repstr, "%f %f", (mapserv->ResultShape.bounds.maxx + mapserv->ResultShape.bounds.minx)/2, (mapserv->ResultShape.bounds.maxy + mapserv->ResultShape.bounds.miny)/2);
+    sprintf(repstr, "%f %f", (mapserv->resultshape.bounds.maxx + mapserv->resultshape.bounds.minx)/2, (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
     outstr = msReplaceSubstring(outstr, "[shpmid]", repstr);
-    sprintf(repstr, "%f", (mapserv->ResultShape.bounds.maxx + mapserv->ResultShape.bounds.minx)/2);
+    sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxx + mapserv->resultshape.bounds.minx)/2);
     outstr = msReplaceSubstring(outstr, "[shpmidx]", repstr);
-    sprintf(repstr, "%f", (mapserv->ResultShape.bounds.maxy + mapserv->ResultShape.bounds.miny)/2);
+    sprintf(repstr, "%f", (mapserv->resultshape.bounds.maxy + mapserv->resultshape.bounds.miny)/2);
     outstr = msReplaceSubstring(outstr, "[shpmidy]", repstr);
-    sprintf(repstr, "%f %f %f %f", mapserv->ResultShape.bounds.minx, mapserv->ResultShape.bounds.miny,  mapserv->ResultShape.bounds.maxx, mapserv->ResultShape.bounds.maxy);
+    sprintf(repstr, "%f %f %f %f", mapserv->resultshape.bounds.minx, mapserv->resultshape.bounds.miny,  mapserv->resultshape.bounds.maxx, mapserv->resultshape.bounds.maxy);
     outstr = msReplaceSubstring(outstr, "[shpext]", repstr);
     encodedstr = msEncodeUrl(repstr);
     outstr = msReplaceSubstring(outstr, "[shpext_esc]", encodedstr);
     free(encodedstr);
-    sprintf(repstr, "%d", mapserv->ResultShape.classindex);
+    sprintf(repstr, "%d", mapserv->resultshape.classindex);
     outstr = msReplaceSubstring(outstr, "[shpclass]", repstr);
-    if(processShpxyTag(mapserv->ResultLayer, &outstr, &mapserv->ResultShape) != MS_SUCCESS)
+    if(processShpxyTag(mapserv->ResultLayer, &outstr, &mapserv->resultshape) != MS_SUCCESS)
       return(NULL);
-    sprintf(repstr, "%f", mapserv->ResultShape.bounds.minx);
+    sprintf(repstr, "%f", mapserv->resultshape.bounds.minx);
     outstr = msReplaceSubstring(outstr, "[shpminx]", repstr);
-    sprintf(repstr, "%f", mapserv->ResultShape.bounds.miny);
+    sprintf(repstr, "%f", mapserv->resultshape.bounds.miny);
     outstr = msReplaceSubstring(outstr, "[shpminy]", repstr);
-    sprintf(repstr, "%f", mapserv->ResultShape.bounds.maxx);
+    sprintf(repstr, "%f", mapserv->resultshape.bounds.maxx);
     outstr = msReplaceSubstring(outstr, "[shpmaxx]", repstr);
-    sprintf(repstr, "%f", mapserv->ResultShape.bounds.maxy);
+    sprintf(repstr, "%f", mapserv->resultshape.bounds.maxy);
     outstr = msReplaceSubstring(outstr, "[shpmaxy]", repstr);
-    sprintf(repstr, "%ld", mapserv->ResultShape.index);
+    sprintf(repstr, "%ld", mapserv->resultshape.index);
     outstr = msReplaceSubstring(outstr, "[shpidx]", repstr);
-    sprintf(repstr, "%d", mapserv->ResultShape.tileindex);
+    sprintf(repstr, "%d", mapserv->resultshape.tileindex);
     outstr = msReplaceSubstring(outstr, "[tileidx]", repstr);
     /* return ALL attributes in one delimeted list */
     if(strstr(outstr, "[values]") != NULL) {
       char *valuestr=NULL;
-      valuestr = msJoinStrings(mapserv->ResultShape.values, mapserv->ResultLayer->numitems, ",");
+      valuestr = msJoinStrings(mapserv->resultshape.values, mapserv->ResultLayer->numitems, ",");
       outstr = msReplaceSubstring(outstr, "[values]", valuestr);
       free(valuestr);
@@ -3105,7 +3120,7 @@
       /* by default let's encode attributes for HTML presentation */
       snprintf(substr, PROCESSLINE_BUFLEN, "[%s]", mapserv->ResultLayer->items[i]);
       if(strstr(outstr, substr) != NULL) {
-        encodedstr = msEncodeHTMLEntities(mapserv->ResultShape.values[i]);
+        encodedstr = msEncodeHTMLEntities(mapserv->resultshape.values[i]);
         outstr = msReplaceSubstring(outstr, substr, encodedstr);
         free(encodedstr);
@@ -3113,7 +3128,7 @@
       /* of course you might want to embed that data in URLs */
       snprintf(substr, PROCESSLINE_BUFLEN, "[%s_esc]", mapserv->ResultLayer->items[i]);
-        encodedstr = msEncodeUrl(mapserv->ResultShape.values[i]);
+        encodedstr = msEncodeUrl(mapserv->resultshape.values[i]);
         free(encodedstr);
@@ -3121,10 +3136,10 @@
       /* or you might want to access the attributes unaltered */
       snprintf(substr, PROCESSLINE_BUFLEN, "[%s_raw]", mapserv->ResultLayer->items[i]);
-        outstr = msReplaceSubstring(outstr, substr, mapserv->ResultShape.values[i]);
+        outstr = msReplaceSubstring(outstr, substr, mapserv->resultshape.values[i]);
-    if(processItemTag(mapserv->ResultLayer, &outstr, &mapserv->ResultShape) != MS_SUCCESS)
+    if(processItemTag(mapserv->ResultLayer, &outstr, &mapserv->resultshape) != MS_SUCCESS)
       return(NULL);
     /* handle joins in this next section */
@@ -3325,7 +3340,7 @@
     nExpandBuffer = 1;
   if((mapserv->Mode == ITEMQUERY) || (mapserv->Mode == QUERY)) { /* may need to handle a URL result set */
@@ -3358,7 +3373,7 @@
         status = msLayerGetItems(lp);
-        status = msLayerGetShape(lp, &(mapserv->ResultShape), lp->resultcache->results[0].tileindex, lp->resultcache->results[0].shapeindex);
+        status = msLayerGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[0].tileindex, lp->resultcache->results[0].shapeindex);
         if(lp->numjoins > 0) {
@@ -3366,7 +3381,7 @@
             status = msJoinConnect(lp, &(lp->joins[k]));
-            msJoinPrepare(&(lp->joins[k]), &(mapserv->ResultShape));
+            msJoinPrepare(&(lp->joins[k]), &(mapserv->resultshape));
             msJoinNext(&(lp->joins[k])); /* fetch the first row */
@@ -3375,7 +3390,7 @@
           if(msReturnURL(mapserv, template, QUERY) != MS_SUCCESS) return MS_FAILURE;
         msLayerClose(lp);
         mapserv->ResultLayer = NULL;
@@ -3448,14 +3463,14 @@
     mapserv->LRN = 1; /* layer result number */
     for(j=0; j<lp->resultcache->numresults; j++) {
-      status = msLayerGetShape(lp, &(mapserv->ResultShape), lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+      status = msLayerGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
         for(k=0; k<lp->numjoins; k++) {
           if(lp->joins[k].type == MS_JOIN_ONE_TO_ONE) {
@@ -3468,7 +3483,7 @@
       if(msReturnPage(mapserv, template, QUERY, papszBuffer) != MS_SUCCESS) return MS_FAILURE;
       mapserv->LRN++;
Modified: trunk/mapserver/maptemplate.h
--- trunk/mapserver/maptemplate.h	2008-05-07 04:36:01 UTC (rev 7568)
+++ trunk/mapserver/maptemplate.h	2008-05-07 06:43:15 UTC (rev 7569)
@@ -79,7 +79,7 @@
    int UseShapes; /* are results of a query to be used in calculating an extent of some sort */
-   shapeObj SelectShape, ResultShape;
+   shapeObj SelectShape, resultshape;
    rectObj RawExt;
