[mapserver-commits] r7598 - trunk/mapserver/mapscript/php3
    svn at osgeo.org
    svn at osgeo.org
    Fri May 16 09:26:49 EDT 2008
Author: dmorissette
Date: 2008-05-16 09:26:48 -0400 (Fri, 16 May 2008)
New Revision: 7598
   trunk/mapserver/mapscript/php3/README
   trunk/mapserver/mapscript/php3/php_mapscript.c
Added align keyword to scalebar in PHP MapScript (#2468)
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README	2008-05-16 08:27:26 UTC (rev 7597)
+++ trunk/mapserver/mapscript/php3/README	2008-05-16 13:26:48 UTC (rev 7598)
@@ -42,10 +42,10 @@
   The following MapServer constants are available:
     Boolean values:
-    MS_TRUE, MS_FALSE, MS_ON, MS_OFF, MS_YES, MS_NO
+        MS_TRUE, MS_FALSE, MS_ON, MS_OFF, MS_YES, MS_NO
     Map units:
-    MS_INCHES, MS_FEET, MS_MILES, MS_METERS, MS_KILOMETERS, MS_DD,
+        MS_INCHES, MS_FEET, MS_MILES, MS_METERS, MS_KILOMETERS, MS_DD,
         MS_PIXELS
     Layer types:
@@ -101,20 +101,23 @@
         MS_SYMBOL_PIXMAP, MS_SYMBOL_TRUETYPE, MS_SYMBOL_CARTOLINE
     Image Mode types (outputFormatObj):
         MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB, MS_IMAGEMODE_RGBA,
         MS_IMAGEMODE_INT16, MS_IMAGEMODE_FLOAT32, MS_IMAGEMODE_BYTE,
         MS_IMAGEMODE_NULL
-    Style/Attribue binding
+    Style/Attribue binding:
         MS_STYLE_BINDING_SIZE,  MS_STYLE_BINDING_ANGLE, MS_STYLE_BINDING_COLOR,
         MS_STYLE_BINDING_OUTLINECOLOR, MS_STYLE_BINDING_SYMBOL
-    Label/Attribute binding
+    Label/Attribute binding:
         MS_LABEL_BINDING_SIZE, MS_LABEL_BINDING_ANGLE, MS_LABEL_BINDING_COLOR,
         MS_LABEL_BINDING_OUTLINECOLOR, MS_LABEL_BINDING_FONT,
         MS_LABEL_BINDING_PRIORITY
+    Alignment:
+        MS_ALIGN_LEFT, MS_ALIGN_CENTER, MS_ALIGN_RIGHT
  Functions:
@@ -1576,7 +1579,8 @@
    int postlabelcache;
    labelObj label;
    colorObj imagecolor;
+   int align;
  Methods:
       int set(string property_name, new_value)
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2008-05-16 08:27:26 UTC (rev 7597)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2008-05-16 13:26:48 UTC (rev 7598)
@@ -1132,6 +1132,11 @@
     REGISTER_LONG_CONSTANT("MS_XY",         MS_XY,          const_flag);
     REGISTER_LONG_CONSTANT("MS_FOLLOW",     MS_FOLLOW,      const_flag);
+    /* alignment constants*/
+    REGISTER_LONG_CONSTANT("MS_ALIGN_LEFT",  MS_ALIGN_LEFT,  const_flag);
+    REGISTER_LONG_CONSTANT("MS_ALIGN_CENTER",MS_ALIGN_CENTER,const_flag);
+    REGISTER_LONG_CONSTANT("MS_ALIGN_RIGHT", MS_ALIGN_RIGHT, const_flag);
     /* shape type constants*/
     REGISTER_LONG_CONSTANT("MS_SHAPE_POINT",MS_SHAPE_POINT, const_flag);
     REGISTER_LONG_CONSTANT("MS_SHAPE_LINE",  MS_SHAPE_LINE, const_flag);
@@ -13298,13 +13303,7 @@
                                          HashTable *list, pval *return_value TSRMLS_DC)
     int         scalebar_id;
-#ifdef PHP4
     pval        *new_obj_ptr;
-#else
-    pval        new_obj_param;  /* No, it's not a pval * !!! */
-    pval        *new_obj_ptr;
-    new_obj_ptr = &new_obj_param;
-#endif
     if (pscalebar == NULL)
         return 0;
@@ -13326,17 +13325,14 @@
     add_property_long(return_value,  "interlace",       pscalebar->interlace);
     add_property_long(return_value,  "postlabelcache",
                       pscalebar->postlabelcache);
+    add_property_long(return_value,  "align",           pscalebar->align);
-#ifdef PHP4
     MAKE_STD_ZVAL(new_obj_ptr);
-#endif
     _phpms_build_label_object(&(pscalebar->label), list, new_obj_ptr TSRMLS_CC);
     _phpms_add_property_object(return_value, "label", new_obj_ptr,E_ERROR TSRMLS_CC);
-#ifdef PHP4
     MAKE_STD_ZVAL(new_obj_ptr);  /* Alloc and Init a ZVAL for new object */
-#endif
     _phpms_build_color_object(&(pscalebar->imagecolor),list, new_obj_ptr TSRMLS_CC);
     _phpms_add_property_object(return_value, "imagecolor",new_obj_ptr,E_ERROR TSRMLS_CC);
@@ -13370,15 +13366,9 @@
     scalebarObj *self;
     pval   *pPropertyName, *pNewValue, *pThis;
-#ifdef PHP4
     HashTable   *list=NULL;
-#endif
-#ifdef PHP4
     pThis = getThis();
-#else
-    getThis(&pThis);
-#endif
     if (pThis == NULL ||
         getParameters(ht, 2, &pPropertyName, &pNewValue) != SUCCESS)
@@ -13404,16 +13394,17 @@
     convert_to_string(pPropertyName);
-    IF_SET_LONG(       "height",         self->height)
-    else IF_SET_LONG(  "width",   self->width)
-    else IF_SET_LONG(  "style",   self->style)
-    else IF_SET_LONG(  "intervals",   self->intervals)
-    else IF_SET_LONG(  "units",   self->units)
-    else IF_SET_LONG(  "status",   self->status)
-    else IF_SET_LONG(  "position",   self->position)
+    IF_SET_LONG(       "height",        self->height)
+    else IF_SET_LONG(  "width",         self->width)
+    else IF_SET_LONG(  "style",         self->style)
+    else IF_SET_LONG(  "intervals",     self->intervals)
+    else IF_SET_LONG(  "units",         self->units)
+    else IF_SET_LONG(  "status",        self->status)
+    else IF_SET_LONG(  "position",      self->position)
     else IF_SET_LONG(  "transparent",   self->transparent)
-    else IF_SET_LONG(  "interlace",   self->interlace)
-    else IF_SET_LONG(  "postlabelcache",   self->postlabelcache)
+    else IF_SET_LONG(  "interlace",     self->interlace)
+    else IF_SET_LONG(  "postlabelcache",self->postlabelcache)
+    else IF_SET_LONG(  "align",         self->align)
     else
         php3_error(E_ERROR,"Property '%s' does not exist in this object.",
@@ -13436,15 +13427,9 @@
     scalebarObj *self;
     pval        *pThis, *pR, *pG, *pB;
     int         r, g, b = 0;
-#ifdef PHP4
-#endif
-#ifdef PHP4
     pThis = getThis();
-#else
-    getThis(&pThis);
-#endif
         getParameters(ht, 3, &pR, &pG, &pB) != SUCCESS)
More information about the mapserver-commits
