[mapserver-commits] r7620 - branches/branch-5-0/mapserver
Mon May 26 09:33:18 EDT 2008
Author: dmorissette
Date: 2008-05-26 09:33:18 -0400 (Mon, 26 May 2008)
New Revision: 7620
   branches/branch-5-0/mapserver/HISTORY.TXT
   branches/branch-5-0/mapserver/mapogr.cpp
Avoid displaying OGR connection strings in error messages (#2629)
Modified: branches/branch-5-0/mapserver/HISTORY.TXT
--- branches/branch-5-0/mapserver/HISTORY.TXT	2008-05-26 13:24:41 UTC (rev 7619)
+++ branches/branch-5-0/mapserver/HISTORY.TXT	2008-05-26 13:33:18 UTC (rev 7620)
@@ -13,6 +13,8 @@
 Current Version (future 5.0.3, svn branch-5-0)
+- Avoid displaying OGR connection strings in error messages (#2629)
 - mappostgis.c: fix postgis idle-in-transaction problem (#2626)
 - mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName correctly (#2611)
Modified: branches/branch-5-0/mapserver/mapogr.cpp
--- branches/branch-5-0/mapserver/mapogr.cpp	2008-05-26 13:24:41 UTC (rev 7619)
+++ branches/branch-5-0/mapserver/mapogr.cpp	2008-05-26 13:33:18 UTC (rev 7620)
@@ -826,9 +826,9 @@
   if( pszDSName == NULL )
       msSetError(MS_OGRERR,
-                 "Error parsing OGR connection information:%s",
+                 "Error parsing OGR connection information in layer `%s'",
                  "msOGRFileOpen()",
-                 (connection?connection:"(null)") );
+                 layer->name?layer->name:"(null)" );
       return NULL;
@@ -874,15 +874,16 @@
           if( strlen(CPLGetLastErrorMsg()) == 0 )
-                         "Open failed for OGR connection `%s'.  "
+                         "Open failed for OGR connection in layer `%s'.  "
                          "File not found or unsupported format.",
                          "msOGRFileOpen()",
-                         pszDSSelectedName );
           else
-                         "Open failed for OGR connection `%s'.\n%s\n",
+                         "Open failed for OGR connection in layer `%s'.\n%s\n",
                          "msOGRFileOpen()",
-                         pszDSSelectedName, CPLGetLastErrorMsg() );
+                         layer->name?layer->name:"(null)",
+                         CPLGetLastErrorMsg() );
           CPLFree( pszDSName );
           CPLFree( pszLayerDef );
           return NULL;
@@ -1088,7 +1089,7 @@
                      "SetAttributeFilter(%s) failed on layer %s.\n%s",
                      "msOGRFileWhichShapes()",
-                     layer->filter.string+6, layer->name,
+                     layer->filter.string+6, layer->name?layer->name:"(null)",
           RELEASE_OGR_LOCK;
           return MS_FAILURE;
@@ -1122,9 +1123,9 @@
      (numitems = poDefn->GetFieldCount()) == 0)
-               "Layer %s,%d contains no fields.",
+               "OGR Connection for layer `%s' contains no fields.",
                "msOGRFileGetItems()",
-               psInfo->pszFname, psInfo->nLayerIndex );
     return NULL;
@@ -1544,11 +1545,10 @@
                      "%s  "
                      "PROJECTION AUTO cannot be used for this "
-                     "OGR connection (`%s').",
+                     "OGR connection (in layer `%s').",
                      "msOGRLayerOpen()",
                      ms_error->message,
-                     (pszOverrideConnection ? pszOverrideConnection:
-                                              layer->connection) );
           msOGRFileClose( layer, psInfo );
           layer->layerinfo = NULL;
           return(MS_FAILURE);
