[mapserver-commits] r7622 - trunk/mapserver
Tue May 27 10:50:46 EDT 2008
Author: pramsey
Date: 2008-05-27 10:50:45 -0400 (Tue, 27 May 2008)
New Revision: 7622
   trunk/mapserver/mappostgis.c
   trunk/mapserver/maptile.c
Fix Win32 build.
Modified: trunk/mapserver/mappostgis.c
--- trunk/mapserver/mappostgis.c	2008-05-26 19:01:24 UTC (rev 7621)
+++ trunk/mapserver/mappostgis.c	2008-05-27 14:50:45 UTC (rev 7622)
@@ -171,6 +171,7 @@
 int msPOSTGISSanitizeConnection(PGconn *conn)
     int conn_bad = 0;
+    PGTransactionStatusType trans_status;
     if (PQstatus(conn) == CONNECTION_BAD)
@@ -205,7 +206,7 @@
 	return MS_FAILURE;
-    const PGTransactionStatusType trans_status = PQtransactionStatus(conn);
+    trans_status = PQtransactionStatus(conn);
     if (trans_status == PQTRANS_INTRANS || trans_status == PQTRANS_INERROR) /* idle, in a transaction block or a failed transaction block */
         PGresult *rb_res = PQexec(conn, "ROLLBACK");
@@ -677,7 +678,8 @@
 int msPOSTGISLayerClose(layerObj *layer)
     msPOSTGISLayerInfo  *layerinfo;
+    PGresult *rollb_res;
     layerinfo = getPostGISLayerInfo(layer);
     if(layer->debug) {
@@ -718,7 +720,7 @@
             layerinfo->cursor_name[0] = '\0';
-            PGresult *rollb_res = PQexec(layerinfo->conn, "ROLLBACK");
+            rollb_res = PQexec(layerinfo->conn, "ROLLBACK");
             if (!rollb_res || PQresultStatus(rollb_res) != PGRES_COMMAND_OK) {
                 msSetError(MS_QUERYERR, "Error executing PostgreSQL ROLLBACK statement: %s", "msPOSTGISLayerClose()", PQerrorMessage(layerinfo->conn));
@@ -1175,10 +1177,10 @@
     size_t  length;
     char    *temp;
-    PGresult            *query_result, *beg_res, *rollb_res;
+    PGresult            *query_result, *beg_res, *rollb_res, *close_res;
     char                *wkb;
-    int                 result, t, size;
+    int                 result, t, size, num_tuples;
     char                *temp1, *temp2;
     if(layer->debug) {
@@ -1292,7 +1294,7 @@
     /* query has been done, so we can retreive the results */
     shape->type = MS_SHAPE_NULL;
-    const int num_tuples = PQntuples(query_result);
+    num_tuples = PQntuples(query_result);
     if(0 < num_tuples) {
         /* only need to get one shape */
         /* retreive an item */
@@ -1352,7 +1354,7 @@
     PQclear(query_result);
-    PGresult *close_res = PQexec(layerinfo->conn, "CLOSE mycursor2");
+    close_res = PQexec(layerinfo->conn, "CLOSE mycursor2");
     if (!close_res || PQresultStatus(close_res) != PGRES_COMMAND_OK)
         msSetError(MS_QUERYERR, "Error executing PostgreSQL CLOSE statement.", "msPOSTGISLayerGetShape()");
Modified: trunk/mapserver/maptile.c
--- trunk/mapserver/maptile.c	2008-05-26 19:01:24 UTC (rev 7621)
+++ trunk/mapserver/maptile.c	2008-05-27 14:50:45 UTC (rev 7622)
@@ -124,7 +124,8 @@
  *                            msTileSetExtent                           *
- *  Called from setExtent() in maptemplate.c.                           *
+ *  Based on the input parameters, set the output extent for this       *
+ *  tile.                                                               *
 int msTileSetExtent(mapservObj* msObj) {
 #ifdef USE_TILE_API
