[mapserver-commits] r7633 - trunk/mapserver
Fri May 30 09:05:44 EDT 2008
Author: sdlime
Date: 2008-05-30 09:05:43 -0400 (Fri, 30 May 2008)
New Revision: 7633
   trunk/mapserver/maplexer.l
Exposed ERROR and EMPTY webObj properties to be changed via URL. (bug 2634)
Modified: trunk/mapserver/maplexer.l
--- trunk/mapserver/maplexer.l	2008-05-30 05:00:10 UTC (rev 7632)
+++ trunk/mapserver/maplexer.l	2008-05-30 13:05:43 UTC (rev 7633)
@@ -161,10 +161,10 @@
 <INITIAL>debug                                 { return(DEBUG); }
 <INITIAL>driver                                { return(DRIVER); }
 <INITIAL>dump                                  { return(DUMP); }
-<INITIAL>empty                                 { return(EMPTY); }
+<INITIAL,URL_STRING>empty                      { return(EMPTY); }
 <INITIAL>encoding                              { return(ENCODING); }
 <INITIAL,URL_STRING>end                        { return(END); }
-<INITIAL>error                                 { return(ERROR); }
+<INITIAL,URL_STRING>error                      { return(ERROR); }
 <INITIAL>expression                            { return(EXPRESSION); }
 <INITIAL,URL_VARIABLE,URL_STRING>extent        { return(EXTENT); }
 <INITIAL>extension                             { return(EXTENSION); }
