[mapserver-commits] r8006 - trunk/mapserver
Tue Nov 4 14:24:49 EST 2008
Author: pramsey
Date: 2008-11-04 14:24:49 -0500 (Tue, 04 Nov 2008)
New Revision: 8006
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mappostgis.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapstring.c
msStringTrim for trimming parsed PostGIS parameters
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-11-04 06:48:07 UTC (rev 8005)
+++ trunk/mapserver/HISTORY.TXT	2008-11-04 19:24:49 UTC (rev 8006)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- mapstring.c: msStringTrim(*char str), front-and-back whitespace trimmer
 - mappostgis.c: re-write to remove binary cursors and break up
   logic into smaller parts, add support for maxfeatures
Modified: trunk/mapserver/mappostgis.c
--- trunk/mapserver/mappostgis.c	2008-11-04 06:48:07 UTC (rev 8005)
+++ trunk/mapserver/mappostgis.c	2008-11-04 19:24:49 UTC (rev 8006)
@@ -594,6 +594,7 @@
         layerinfo->uid = (char*) malloc((tmp - (pos_uid + 14)) + 1);
         strncpy(layerinfo->uid, pos_uid + 14, tmp - (pos_uid + 14));
         (layerinfo->uid)[tmp - (pos_uid + 14)] = '\0'; /* null terminate it */
+        msStringTrim(layerinfo->uid);
@@ -612,6 +613,7 @@
             layerinfo->srid = (char*) malloc(slength + 1);
             strncpy(layerinfo->srid, pos_srid + 12, slength);
             (layerinfo->srid)[slength] = '\0'; /* null terminate it */
+            msStringTrim(layerinfo->srid);
@@ -646,11 +648,13 @@
     layerinfo->geomcolumn = (char*) malloc((pos_scn - data) + 1);
     strncpy(layerinfo->geomcolumn, data, pos_scn - data);
     (layerinfo->geomcolumn)[pos_scn - data] = '\0';
+    msStringTrim(layerinfo->geomcolumn);
     /* Copy the table name or sub-select clause */
     layerinfo->fromsource = (char*) malloc((pos_opt - (pos_scn + 6)) + 1);
     strncpy(layerinfo->fromsource, pos_scn + 6, pos_opt - (pos_scn + 6));
     (layerinfo->fromsource)[pos_opt - (pos_scn + 6)] = '\0';
+    msStringTrim(layerinfo->fromsource);
     /* Something is wrong, our goemetry column and table references are not there. */
     if (strlen(layerinfo->fromsource) < 1 || strlen(layerinfo->geomcolumn) < 1) {
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2008-11-04 06:48:07 UTC (rev 8005)
+++ trunk/mapserver/mapserver.h	2008-11-04 19:24:49 UTC (rev 8006)
@@ -1602,8 +1602,9 @@
 MS_DLL_EXPORT int msRasterQueryByPoint(mapObj *map, layerObj *layer, int mode,
                          pointObj p, double buffer );
-MS_DLL_EXPORT void msStringTrimBlanks(char *string); /* in mapstring.c */
+/* in mapstring.c */
+MS_DLL_EXPORT void msStringTrim(char *str);
+MS_DLL_EXPORT void msStringTrimBlanks(char *string);
 MS_DLL_EXPORT char *msStringTrimLeft(char *string);
 MS_DLL_EXPORT char *msStringChop(char *string);
 MS_DLL_EXPORT void msStringTrimEOL(char *string);
Modified: trunk/mapserver/mapstring.c
--- trunk/mapserver/mapstring.c	2008-11-04 06:48:07 UTC (rev 8005)
+++ trunk/mapserver/mapstring.c	2008-11-04 19:24:49 UTC (rev 8006)
@@ -352,10 +352,38 @@
   return(string);
- * remove leading white spaces and shif evey thing to the left
+** Trim leading and trailing white space.
+void msStringTrim(char *str)
+    int i;
+    /* Send nulls home without supper. */
+    if( ! str ) return;
+    /* Move non-white string to the front. */
+    i = strspn(str, " ");
+    if(i) {
+        memmove(str, str + i, strlen(str) - i + 1);
+    /* Nothing left? Exit. */
+    if(strlen(str) == 0) {
+        return;
+    /* Null-terminate end of non-white string. */
+    for(i=strlen(str)-1; i>=0; i--) { /* step backwards from end */
+        if(str[i] != ' ') {
+	        str[i+1] = '\0';
+	        return;
+    return;
+** Remove leading white spaces and shift everything to the left.
     char *read, *write;
@@ -390,7 +418,7 @@
-/*       Trims leading blanks from a string                                        */
+/*       Trims trailing blanks from a string                                        */
