[mapserver-commits] r8052 - trunk/docs/references/fontset
Sun Nov 23 13:48:14 EST 2008
Author: hobu
Date: 2008-11-23 13:48:14 -0500 (Sun, 23 Nov 2008)
New Revision: 8052
   trunk/docs/references/fontset/fontset.txt
convert to ReST
Modified: trunk/docs/references/fontset/fontset.txt
--- trunk/docs/references/fontset/fontset.txt	2008-11-23 18:37:16 UTC (rev 8051)
+++ trunk/docs/references/fontset/fontset.txt	2008-11-23 18:48:14 UTC (rev 8052)
@@ -1,17 +1,37 @@
-    <p>
-    <b>Notes</b>: Aliases are case sensitive. Excellent reference information about
+ Fontsets
+:Author:        Kari Guerts
+:Author:        Jeff McKenna
+:Contact:       jmckenna at gatewaygeomatics.com
+:Revision: $Revision$
+:Date: $Date$
+:Last Updated: 2008/10/08
+.. sectnum::
+.. contents::
+    :depth: 2
+    :backlinks: top
+Format
+The format is very simple. Each line contains 2 items: an alias and
+the name/path of the font separated by white space. The alias is simply
+the name you refer to the font as in your mapfiles (eg. times-bold).
+The name is the actual name of the TrueType file. If not full path then
+it is interpreted as relative to the location of the fontset. Here's the
+fontset I use (the font.list file and all .ttf files are stored in the
+same sub-directory).
+.. note:: Aliases are case sensitive. Excellent reference information about
     the TrueType format and online font resources is available from the
-    <a href="http://www.freetype.org/">FreeType</a> project website.
-    <p>
-    <b>Format</b>: The format is very simple. Each
-    line contains 2 items: an alias and the name/path of the font seperated by white
-    space. The alias is simply the name you refer to the font as in your mapfiles (eg.
-    times-bold). The name is the actual name of the TrueType file. If not fullpath then
-    it is interpreted as relative to the location of the fontset. Here's the fontset I use
-    (the font.list file and all .ttf files are stored in the same sub-directory).
-    <p>
+    `FreeType`_.
-    <pre>
       arial                           arial.ttf
       arial-bold                      arialbd.ttf
       arial-italic                    ariali.ttf
@@ -44,4 +64,4 @@
       verdana-bold-italic             verdanaz.ttf
     </pre>
\ No newline at end of file
+.. _FreeType: http://www.freetype.org/
