[mapserver-commits] r8074 - in trunk/docs: . references/mapscript references/mapscript/php
Sun Nov 23 22:33:26 EST 2008
Author: hobu
Date: 2008-11-23 22:33:26 -0500 (Sun, 23 Nov 2008)
New Revision: 8074
Added:
   trunk/docs/references/mapscript/php/index.txt
   trunk/docs/index.txt
   trunk/docs/references/mapscript/index.txt
   trunk/docs/references/mapscript/introduction.txt
   trunk/docs/references/mapscript/mapfile.txt
   trunk/docs/references/mapscript/mapscript.txt
   trunk/docs/references/mapscript/php/by_example.txt
   trunk/docs/references/mapscript/php/class-constants.txt
   trunk/docs/references/mapscript/php/class-functions.txt
   trunk/docs/references/mapscript/php/class-intro.txt
   trunk/docs/references/mapscript/php/install.txt
   trunk/docs/references/mapscript/python.txt
   trunk/docs/references/mapscript/querying.txt
   trunk/docs/references/mapscript/variables.txt
mapscript sphinx
Modified: trunk/docs/index.txt
--- trunk/docs/index.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/index.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -16,6 +16,5 @@
 * :ref:`genindex`
-* :ref:`modindex`
 * :ref:`search`
Modified: trunk/docs/references/mapscript/index.txt
--- trunk/docs/references/mapscript/index.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/index.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -14,8 +14,8 @@
    introduction
    mapscript
+   php/index
    dotnet_compile
-   php/index
    python
    imagery
    mapfile
Modified: trunk/docs/references/mapscript/introduction.txt
--- trunk/docs/references/mapscript/introduction.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/introduction.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -5,7 +5,7 @@
 This is language agnostic documentation for the MapScript interface to
 MapServer generated by SWIG.  This document is intended for developers
 and to serve as a reference for writers of more extensive, language
-specific documentation in DocBook format for the MDP.
+specific documentation located at :ref:`mapfile`
  Appendices
@@ -13,7 +13,7 @@
 Language-specific extensions are described in the following appendices
-`Python Appendix </docs/howto/mapscript_python>`__
+:ref:`Python Appendix <python>`
  Documentation Elements
Modified: trunk/docs/references/mapscript/mapfile.txt
--- trunk/docs/references/mapscript/mapfile.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/mapfile.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,5 @@
+.. ms_mapscript:
  Mapscript Mapfile HOWTO
Modified: trunk/docs/references/mapscript/mapscript.txt
--- trunk/docs/references/mapscript/mapscript.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/mapscript.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,5 +1,5 @@
- Mapscript API Reference
+ SWIG Mapscript API Reference
 :Author: Sean Gillies
Modified: trunk/docs/references/mapscript/php/by_example.txt
--- trunk/docs/references/mapscript/php/by_example.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/php/by_example.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,5 +1,5 @@
- PHP MapScript by Example
+ By Example
 :Author:       Vinko Vrsalovic
@@ -8,8 +8,6 @@
 :Date: $Date$
 :Last Updated: 2005/12/12
-.. sectnum::
 .. contents::
     :depth: 2
     :backlinks: top
Modified: trunk/docs/references/mapscript/php/class-constants.txt
--- trunk/docs/references/mapscript/php/class-constants.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/php/class-constants.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,15 @@
+ Class Constants
+:Author: Jeff McKenna
+:Contact: jmckenna at gatewaygeomatics.com
+:Last Updated: 2008/07/16
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
 - Constant names and class member variable names are case-sensitive in PHP.
 - Several MapScript functions (all those that access files in the back end
Modified: trunk/docs/references/mapscript/php/class-functions.txt
--- trunk/docs/references/mapscript/php/class-functions.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/php/class-functions.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,15 @@
+ Functions
+    :depth: 2
+    :backlinks: top
 - Several MapScript functions (all those that access files in the back end such
Modified: trunk/docs/references/mapscript/php/class-intro.txt
--- trunk/docs/references/mapscript/php/class-intro.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/php/class-intro.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,10 +1,15 @@
-:Author:         Jeff McKenna
-:Contact:        jmckenna(at)gatewaygeomatics.com
-:README version: r7813
-:Last Updated:   2008/07/16
+ Introduction
+    :depth: 2
+    :backlinks: top
 Abstract
Added: trunk/docs/references/mapscript/php/index.txt
--- trunk/docs/references/mapscript/php/index.txt	                        (rev 0)
+++ trunk/docs/references/mapscript/php/index.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -0,0 +1,17 @@
+.. _php:
+ PHP MapScript
+.. toctree::
+   :maxdepth: 2
+   install
+   class-intro
+   class-functions
+   class-constants
+   by_example
Modified: trunk/docs/references/mapscript/php/install.txt
--- trunk/docs/references/mapscript/php/install.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/php/install.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,15 +1,14 @@
+.. index::
+    single: php; installation
+ Installation
-:Contact:      jmckenna(at)dmsolutions.ca
 :Last Updated: 2007/09/11
-.. sectnum::
     :depth: 2
     :backlinks: top
Modified: trunk/docs/references/mapscript/python.txt
--- trunk/docs/references/mapscript/python.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/python.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,5 @@
+.. _python:
  Python MapScript Appendix
Modified: trunk/docs/references/mapscript/querying.txt
--- trunk/docs/references/mapscript/querying.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/querying.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,5 @@
+.. _querying:
  MapScript Query HowTo
Modified: trunk/docs/references/mapscript/variables.txt
--- trunk/docs/references/mapscript/variables.txt	2008-11-24 02:40:12 UTC (rev 8073)
+++ trunk/docs/references/mapscript/variables.txt	2008-11-24 03:33:26 UTC (rev 8074)
@@ -1,3 +1,5 @@
+.. variables:
  MapScript Variables
