[mapserver-commits] r8076 - in trunk/docs/references: mapfile mapscript/php ogc output
Mon Nov 24 12:23:24 EST 2008
Author: hobu
Date: 2008-11-24 12:23:24 -0500 (Mon, 24 Nov 2008)
New Revision: 8076
   trunk/docs/references/mapfile/index.txt
   trunk/docs/references/mapscript/php/by_example.txt
   trunk/docs/references/mapscript/php/install.txt
   trunk/docs/references/ogc/mapcontext.txt
   trunk/docs/references/ogc/wms_server.txt
   trunk/docs/references/output/antialias.txt
some edits to satisfy latex
Modified: trunk/docs/references/mapfile/index.txt
--- trunk/docs/references/mapfile/index.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/mapfile/index.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -59,9 +59,6 @@
 :ref:`JOIN`
-:ref:`JOIN`
 * :ref:`JOIN` defines how a specific data join is defined.
 :ref:`LABEL`
Modified: trunk/docs/references/mapscript/php/by_example.txt
--- trunk/docs/references/mapscript/php/by_example.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/mapscript/php/by_example.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -293,7 +293,7 @@
 The .map file remains the same as the one presented in the previous example.
 PHP/Mapscript Code
 Here I present the new code.
@@ -437,7 +437,7 @@
 Done?, now let's start the explanation with the HTML part.
 Code Explanation - HTML
 Line 49 declares a form, and line 53 declares the image generated by MapScript
 to be part of that form, so when you click on it, the X and Y coordinates of the
@@ -449,8 +449,9 @@
 be explained in due time.
 Code Explanation - PHP
 Now look at the PHP code, it's almost the same code used in example 1, with the
 addition of lines 9 to 37. What do these lines do?
Modified: trunk/docs/references/mapscript/php/install.txt
--- trunk/docs/references/mapscript/php/install.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/mapscript/php/install.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -96,13 +96,14 @@
 ..  versions of Apache, mySQL, and PHP; however, it appears that the FoxServ
 ..  project may be abandonned, so MS4W is recommended.
-*NOTE:*
-When setting up PHP on Windows, make sure that PHP is configured as a CGI and not
-as an Apache module because php_mapscript.dll is not thread-safe and does not work
-as an Apache module (See the `Example Steps of a Full Windows Installation section`_
-of this document).
+.. note::
+    When setting up PHP on Windows, make sure that PHP is configured as a CGI and not
+    as an Apache module because php_mapscript.dll is not thread-safe and does not work
+    as an Apache module (See the `Example Steps of a Full Windows Installation section`_
+    of this document).
 Build/Install the PHP/Mapscript Module
@@ -145,8 +146,8 @@
 (pathto/php/extensions)
 Using phpinfo()
 To verify that PHP and PHP/Mapscript were installed properly, create a '.php' file
 containing the following code and try to access it through your web server:
Modified: trunk/docs/references/ogc/mapcontext.txt
--- trunk/docs/references/ogc/mapcontext.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/ogc/mapcontext.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -77,7 +77,7 @@
 be used for images)
 Web Object Metadata
 - *ows_schemas_location* : Location of XML schema document. Default is
   http://schemas.opengeospatial.net. See http://ogc.dmsolutions.ca for an example
@@ -141,8 +141,9 @@
   exist beyond version 0.1.4)
 Layer Object Metadata
 - *wms_abstract* : A blurb of text providing more information about the WMS server.
 - *wms_dataurl_href* : Link to an online resource where data corresponding to the
Modified: trunk/docs/references/ogc/wms_server.txt
--- trunk/docs/references/ogc/wms_server.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/ogc/wms_server.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -348,8 +348,6 @@
 request will be explained below.
-Use a Valid GetMap Request According to the WMS Spec
 The following is a list of the required GetMap parameters according to the WMS spec:
Modified: trunk/docs/references/output/antialias.txt
--- trunk/docs/references/output/antialias.txt	2008-11-24 03:54:12 UTC (rev 8075)
+++ trunk/docs/references/output/antialias.txt	2008-11-24 17:23:24 UTC (rev 8076)
@@ -1,5 +1,5 @@
- AGG Rendering Specifics
+ AntiAliasing with MapServer
 :Author:  Pericles Nacionales
