[mapserver-commits] r8082 - in trunk/docs/references: compilation mapfile symbology
Mon Nov 24 15:23:32 EST 2008
Author: hobu
Date: 2008-11-24 15:23:30 -0500 (Mon, 24 Nov 2008)
New Revision: 8082
Added:
   trunk/docs/references/mapfile/symbol.txt
Removed:
   trunk/docs/references/symbology/notes.txt
   trunk/docs/references/symbology/syntax.txt
   trunk/docs/references/compilation/unix.txt
   trunk/docs/references/mapfile/index.txt
move SYMBOL into the mapfile reference
Modified: trunk/docs/references/compilation/unix.txt
--- trunk/docs/references/compilation/unix.txt	2008-11-24 20:03:05 UTC (rev 8081)
+++ trunk/docs/references/compilation/unix.txt	2008-11-24 20:23:30 UTC (rev 8082)
@@ -1,3 +1,5 @@
+.. _unix:
  Compiling on Unix
@@ -10,8 +12,6 @@
 :Author: Howard Butler
 :Contact: hobu.inc at gmail.com
-.. sectnum::
 .. contents:: Table of Contents
     :depth: 2
     :backlinks: top
Modified: trunk/docs/references/mapfile/index.txt
--- trunk/docs/references/mapfile/index.txt	2008-11-24 20:03:05 UTC (rev 8081)
+++ trunk/docs/references/mapfile/index.txt	2008-11-24 20:23:30 UTC (rev 8082)
@@ -118,6 +118,11 @@
 * :ref:`STYLE` holds the parameters for symbolization.
+:ref:`SYMBOL`
+* :ref:`SYMBOL` defines how to draw map items.
 :ref:`Variable Substitution <variable_sub>`
Copied: trunk/docs/references/mapfile/symbol.txt (from rev 8080, trunk/docs/references/symbology/syntax.txt)
--- trunk/docs/references/mapfile/symbol.txt	                        (rev 0)
+++ trunk/docs/references/mapfile/symbol.txt	2008-11-24 20:23:30 UTC (rev 8082)
@@ -0,0 +1,112 @@
+.. _symbol:
+ SYMBOL
+- Symbol definitions can be included within the main MapFile or, more
+  commonly, in a separate file. Symbol definitions in a separate file
+  are designated using the SYMBOLSET keyword, as part of the :ref:`MAP Object <map>`.
+  This recommended setup is ideal for re-using symbol definitions across
+  multiple MapServer applications.
+- There are 3 main types of symbols in MapServer: Markers,
+  Shadesets, and Lines.
+- Symbol 0 is always the degenerate case for a particular class of
+  symbol. For points, symbol 0 is a single pixel, for shading (i.e.
+  filled polygons) symbol 0 is a solid fill, and for lines, symbol 0
+  is a single pixel wide line.
+- Symbol definitions contain no color information, colors are set within
+  :ref:`CLASS` objects.
+- For MapServer versions < 5 there is a maximum of 64 symbols per file. This can
+  be changed by editing mapsymbol.h and changing the value of MS_MAXSYMBOLS at the
+  top of the file.  As of MapServer 5.0 there is no symbol limit.
+- More information can be found in the :ref:`Construction of Cartographic Symbols <sym_construction>`
+  document.
+ANTIALIAS [true|false]
+    Should TrueType fonts be antialiased.
+CHARACTER [char]
+    Character used to reference a particular TrueType font character.
+    You'll need to figure out the mapping from the keyboard character
+    to font character.
+FILLED [true|false]
+    Sets the symbol to be filled with a user defined color (See the
+    :ref:`CLASS` object). For marker symbols, if OUTLINECOLOR was specified
+    then the symbol is outlined with it.
+FONT [string]
+    Name of TrueType font to use as defined in the :ref:`FONTSET`.
+GAP [int]
+    Given in pixels. This defines a distance between symbols for
+    TrueType lines.  As of MapServer 5.0 this also applies to PixMap symbols.
+    When drawing the symbol along a line segment, a negative GAP will will add
+    180 degress to the angle. The TrueType and PixMap symbols are always oriented
+    along the line.  A GAP of 0 (the default value) will cause MapServer to use
+    the symbol as a brush to draw the line.
+IMAGE [string]
+    Image (GIF or PNG) to use as a marker or brush for type PIXMAP symbols.
+NAME [string]
+    Alias for this font to be used in :ref:`CLASS` objects
+LINECAP [butt|round|square|triangle]
+    Sets the line cap type for the cartoline symbol. Default is butt. Works
+    with the CARTOLINE symbol only!
+LINEJOIN [round|miter|bevel]
+    Sets the line join type for the cartoline symbol. Default is "none" -
+    lines will not be joined . Works with the CARTOLINE symbol only!
+LINEJOINMAXSIZE [int]
+    Sets the max length of the miter line join type. The value represents a
+    coefficient which multiplies a current symbol size. Default is 3.
+    Works with the CARTOLINE symbol only!
+PATTERN [num on] [num off] [num on] ... END
+    Defines a dash style or pattern.  Implemented in MapServer 5.0,
+    to replace the deprecated STYLE parameter.
+POINTS [x y] [x y] ... END
+    Signifies the start of the definition of points that make up a vector
+    symbol or that define the x and y radius of an ellipse symbol. The end
+    of this section is signified with the keyword END. Coordinates are given
+    in pixels and define the default size of the symbol before any scaling.
+    You can create non-contiguous paths by inserting negative coordinates at
+    the appropriate place. For ellipse symbols you provide a single point that
+    defines the x and y radius of an ellipse. Circles are created when x and
+    y are equal.
+.. note::
+    If a class using this symbol doesn't contain an explicit size, then the
+    default symbol size will be based on the range of "y" values in the point
+    coordinates. e.g. if the y coordinates of the points in the symbol range
+    from 0 to 5, then the default size for this symbol will be assumed to be 5.
+STYLE [num on] [num off] [num on] ... END -deprecated
+    Since MapServer 5.0 the proper parameter to use is PATTERN instead.
+    The deprecated STYLE parameter defines a dash style or pattern.
+TRANSPARENT [color index]
+    Sets a transparent color for the input GIF image for pixmap symbols, or
+    determines whether all shade symbols should have a transparent background.
+    For shade symbols it may be desirable to have background features
+    "show through" a transparent hatching pattern, creating a more complex map.
+    By default a symbol's background is the same as the parent image (i.e.
+    color 0). This is user configurable.
+TYPE [vector|ellipse|pixmap|truetype|simple|cartoline|hatch]
+        *  vector: a simple drawing is used to define the shape of the symbol.
+        *  ellipse: radius values in the x and y directions define an ellipse.
+        *  pixmap: a user supplied GIF image will be used as the symbol.
+        *  truetype: TrueType font to use as defined in the FONTSET.
+        *  cartoline: allows for different designs of line ends (mitered, rounded,
+           beveled). More information can be found in the
+           :ref:`Cartographic Symbols document <sym_construction>`.
+        *  hatch: produces hatched lines throughout the shape.
Deleted: trunk/docs/references/symbology/notes.txt
--- trunk/docs/references/symbology/notes.txt	2008-11-24 20:03:05 UTC (rev 8081)
+++ trunk/docs/references/symbology/notes.txt	2008-11-24 20:23:30 UTC (rev 8082)
@@ -1,18 +0,0 @@
-- Symbol definitions can be included within the main MapFile or, more
-  commonly, in a separate file. Symbol definitions in a separate file
-  are designated using the SYMBOLSET keyword, as part of the :ref`MAP Object <map>`.
-  This recommended setup is ideal for re-using symbol definitions across
-  multiple MapServer applications.
-- There are 3 main types of symbols in MapServer: Markers,
-  Shadesets, and Lines.
-- Symbol 0 is always the degenerate case for a particular class of
-  symbol. For points, symbol 0 is a single pixel, for shading (i.e.
-  filled polygons) symbol 0 is a solid fill, and for lines, symbol 0
-  is a single pixel wide line.
-- Symbol definitions contain no color information, colors are set within
-  :ref:`CLASS` objects.
-- For MapServer versions < 5 there is a maximum of 64 symbols per file. This can
-  be changed by editing mapsymbol.h and changing the value of MS_MAXSYMBOLS at the
-  top of the file.  As of MapServer 5.0 there is no symbol limit.
-- More information can be found in the :ref:`Construction of Cartographic Symbols <sym_construction>`
-  document.
Deleted: trunk/docs/references/symbology/syntax.txt
--- trunk/docs/references/symbology/syntax.txt	2008-11-24 20:03:05 UTC (rev 8081)
+++ trunk/docs/references/symbology/syntax.txt	2008-11-24 20:23:30 UTC (rev 8082)
@@ -1,89 +0,0 @@
-.. _symbol:
- SYMBOL
-ANTIALIAS [true|false]
-    Should TrueType fonts be antialiased.
-CHARACTER [char]
-    Character used to reference a particular TrueType font character.
-    You'll need to figure out the mapping from the keyboard character
-    to font character.
-FILLED [true|false]
-    Sets the symbol to be filled with a user defined color (See the
-    :ref:`CLASS` object). For marker symbols, if OUTLINECOLOR was specified
-    then the symbol is outlined with it.
-FONT [string]
-    Name of TrueType font to use as defined in the :ref:`FONTSET`.
-GAP [int]
-    Given in pixels. This defines a distance between symbols for
-    TrueType lines.  As of MapServer 5.0 this also applies to PixMap symbols.
-    When drawing the symbol along a line segment, a negative GAP will will add
-    180 degress to the angle. The TrueType and PixMap symbols are always oriented
-    along the line.  A GAP of 0 (the default value) will cause MapServer to use
-    the symbol as a brush to draw the line.
-IMAGE [string]
-    Image (GIF or PNG) to use as a marker or brush for type PIXMAP symbols.
-NAME [string]
-    Alias for this font to be used in :ref:`CLASS` objects
-LINECAP [butt|round|square|triangle]
-    Sets the line cap type for the cartoline symbol. Default is butt. Works
-    with the CARTOLINE symbol only!
-LINEJOIN [round|miter|bevel]
-    Sets the line join type for the cartoline symbol. Default is "none" -
-    lines will not be joined . Works with the CARTOLINE symbol only!
-LINEJOINMAXSIZE [int]
-    Sets the max length of the miter line join type. The value represents a
-    coefficient which multiplies a current symbol size. Default is 3.
-    Works with the CARTOLINE symbol only!
-PATTERN [num on] [num off] [num on] ... END
-    Defines a dash style or pattern.  Implemented in MapServer 5.0,
-    to replace the deprecated STYLE parameter.
-POINTS [x y] [x y] ... END
-    Signifies the start of the definition of points that make up a vector
-    symbol or that define the x and y radius of an ellipse symbol. The end
-    of this section is signified with the keyword END. Coordinates are given
-    in pixels and define the default size of the symbol before any scaling.
-    You can create non-contiguous paths by inserting negative coordinates at
-    the appropriate place. For ellipse symbols you provide a single point that
-    defines the x and y radius of an ellipse. Circles are created when x and
-    y are equal.
-.. note::
-    If a class using this symbol doesn't contain an explicit size, then the
-    default symbol size will be based on the range of "y" values in the point
-    coordinates. e.g. if the y coordinates of the points in the symbol range
-    from 0 to 5, then the default size for this symbol will be assumed to be 5.
-STYLE [num on] [num off] [num on] ... END -deprecated
-    Since MapServer 5.0 the proper parameter to use is PATTERN instead.
-    The deprecated STYLE parameter defines a dash style or pattern.
-TRANSPARENT [color index]
-    Sets a transparent color for the input GIF image for pixmap symbols, or
-    determines whether all shade symbols should have a transparent background.
-    For shade symbols it may be desirable to have background features
-    "show through" a transparent hatching pattern, creating a more complex map.
-    By default a symbol's background is the same as the parent image (i.e.
-    color 0). This is user configurable.
-TYPE [vector|ellipse|pixmap|truetype|simple|cartoline|hatch]
-        *  vector: a simple drawing is used to define the shape of the symbol.
-        *  ellipse: radius values in the x and y directions define an ellipse.
-        *  pixmap: a user supplied GIF image will be used as the symbol.
-        *  truetype: TrueType font to use as defined in the FONTSET.
-        *  cartoline: allows for different designs of line ends (mitered, rounded, beveled). More information can be found in the :ref:`Cartographic Symbols document <sym_construction>`.
-        *  hatch: produces hatched lines throughout the shape.
