[mapserver-commits] r8087 - trunk/docs/references/compilation
Mon Nov 24 20:14:34 EST 2008
Author: hobu
Date: 2008-11-24 20:14:33 -0500 (Mon, 24 Nov 2008)
New Revision: 8087
   trunk/docs/references/compilation/win32.txt
convert to ReST. Thanks crschmidt\!
Modified: trunk/docs/references/compilation/win32.txt
--- trunk/docs/references/compilation/win32.txt	2008-11-25 00:42:04 UTC (rev 8086)
+++ trunk/docs/references/compilation/win32.txt	2008-11-25 01:14:33 UTC (rev 8087)
@@ -1,19 +1,33 @@
-<div class="toc"><p><b>Table of Contents</b></p><dl><dt><a href="#intro">Introduction</a></dt><dt><a href="#compile">Compiling</a></dt><dd><dl><dt><a href="#dir">Set up a Project Directory</a></dt><dt><a href="#download">Download MapServer Source Code and Supporting Libraries</a></dt><dd><dl><dt><a href="#source">The MapServer source code</a></dt></dl></dd><dt><a href="#options">Set Compilation Options</a></dt><dt><a href="#complib">Compile the Libraries</a></dt><dt><a href="#compmapserv">Compile MapServer</a></dt><dt><a href="#errors">Common Compiling Errors</a></dt></dl></dd><dt><a href="#install">Installation</a></dt><dt><a href="#other">Other Helpful Information</a></dt><dt><a href="#docinfo">About This Document</a></dt><dd><dl><dt><a href="#copyright">Copyright Information</a></dt><dt><a href="#disclaimer">Disclaimer</a></dt><dt><a href="#ack">Acknowledgements</a></dt><dt><a href="#feedback">Feedback</a></dt></dl></dd></dl></div><div class="sect1"><div class="titlepage"><div><h2 class="title"><a name="intro"></a>Introduction<br /></h2></div></div><p>
+.. _win32:
+ Win32 Compilation and Installation
+:Author:  Pericles Nacionales
+iRevision: $Revision$
+:Date: $Date$
+:Last Updated: 2005/12/20
+.. contents:: Table of Contents
+    :depth: 2
+    :backlinks: top
+Introduction
+This document provides a simple set of compilation procedures for MapServer on Win32 platforms.
 If you've made it this far, chances are you already know about MapServer and
-are at least tempted to try compiling it for yourself. If you've never heard
-of MapServer before or what it does, then may I suggest going to its web site
-at <a href="http://mapserver.gis.umn.edu/" target="_top">
-http://mapserver.gis.umn.edu</a>.
-</p><p>
+are at least tempted to try compiling it for yourself.
 Pre-compiled binaries for MapServer are available from a variety of
-sources.  Refer to <a href="http://mapserver.gis.umn.edu/win32binaries.html" target="_top">http://mapserver.gis.umn.edu/win32binaries.html</a>.  Building MapServer
+sources.  Refer to `Win32 Binaries`_.  Building MapServer
 for win32 platforms can be a daunting task, so if existing binaries are
 sufficient for your needs, it is strongly advised that they be used in
+preference to trying to build everything from source.
-preference to trying to build everything from source.
-</p><p>
+.. _`Win32 Binaries`: http://mapserver.gis.umn.edu/win32binaries.html
 However, there can be a variety of reasons to want to build MapServer from
 source on win32.  Reasons include the need to enable specific options, to
 build with alternate versions of support libraries (such as GDAL), the
@@ -24,7 +38,11 @@
 examples. Each example is a continuation of the previous one and in the end
 will produce the MapServer DLL (libmap.dll), the CGI program (the
 mapserv.exe), and utility programs.
-</p></div><div class="sect1"><div class="titlepage"><div><h2 class="title"><a name="compile"></a>Compiling</h2></div></div><p>If you are new to Windows programming, please follow this
+Compiling
+If you are new to Windows programming, please follow this
 document carefully. The compilation steps are fairly simple but I've added a
 few blurbs in each step to help you understand how MapServer compiles. For
 the more experienced programmers, perhaps reading the README.Win32
@@ -32,155 +50,325 @@
 who are antsy, compiling MapServer involves download and unpacking the source
 codes, editing the make files, and invoking Microsoft's Visual C++ compiler
 from the command prompt. The resulting mapserv.exe is the CGI program that
-installs in the cgi-bin directory of your web server.</p><p>For those who are willing to take the time, the compilation steps follow.</p><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="dir"></a>Set up a Project Directory</h3></div></div><p>Before you start to compile MapServer, I recommend creating a directory
+installs in the cgi-bin directory of your web server.
+For those who are willing to take the time, the compilation steps follow.
+Set up a Project Directory
+Before you start to compile MapServer, I recommend creating a directory
 called "projects" where you can put the source code for MapServer and its
 supporting libraries. Since you will be working with DOS-style commands,
 you might as well get used to the Windows command prompt. For Windows 95/98
 users the command processor would be called command.com. For Windows
 NT/2000/XP, it would be cmd.exe. So fire up the old command prompt and go to
-the drive where you want to create the project directory.</p><p>Here is an example of how to create a directory called projects on the C: drive:</p><b>C:\Users&gt;mkdir C:\Projects</b><p>To go to that directory:
+the drive where you want to create the project directory.
-</p><pre class="screen">C:\Users&gt; cd \Projects<br />C:\Projects&gt;<br /></pre>
+Here is an example of how to create a directory called projects on the C: drive:
+  C:\Users> mkdir C:\Projects
+To go to that directory:
+  C:\Users> cd \Projects
+  C:\Projects>
 From the projects directory, you can extract the source codes for MapServer
-and its libraries. Now you're ready to download the source codes.<p></p></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="download"></a>Download MapServer Source Code and Supporting Libraries</h3></div></div><p>After creating a project directory, download the MapServer source code
+and its libraries. Now you're ready to download the source codes.
+Download MapServer Source Code and Supporting Libraries
+After creating a project directory, download the MapServer source code
 and the codes for the supporting libraries and save the source code packages
 in the newly created "projects" directory. These source codes are usually
 packaged as ZIP, or as UNIX TAR and GZIP files.  You'll need a software that
-can unzip these packages. <a href="http://www.winzip.com/" target="_top">WinZIP</a>
-is an example of software that can handle these files.
+can unzip these packages. `WinZIP`_ is an example of software that can handle
+these files.
+.. _`WinZIP`: http://www.winzip.com/
 Cygwin is a free, open-source software package which is a port of these tools
 on Windows. You can use the gzip and tar utilities from this tool collection.
 Cygwin is available from
-<a href="http://www.cygwin.com/" target="_top">http://www.cygwin.com</a>.</p><p>In order to compile the MapServer CGI program, you must download a few
+http://www.cygwin.com.
+In order to compile the MapServer CGI program, you must download a few
 required and optional libraries. At its simplest configuration, MapServer
 only requires the GD (to provide the image output) and REGEX (to provide
 regular expression support) libraries. This configuration allows the
 developer/data provider to use shapefiles as input and, depending on the
 version of GD library used, GIF or PNG images as output.  Additional
 libraries are needed for input data in alternative formats. The libraries
-that work with MapServer are listed below.</p><div class="sect3"><div class="titlepage"><div><h4 class="title"><a name="source"></a>The MapServer source code</h4></div></div><p>The MapServer source code can be downloaded from <a href="http://mapserver.gis.umn.edu/dload.html" target="_top">
+that work with MapServer are listed below.
-http://mapserver.gis.umn.edu/dload.html</a>.
-If you'd like to get the current development version of the software,
-following the nightly snapshot link under the Interim Builds title.
-The absolute latest copy of the source code can be obtained from
-<a href="http://mapserver.gis.umn.edu/cvs.html" target="_top">CVS</a>; however, the
-CVS respository does not contain several important source files (maplexer.c,
-mapparser.c and mapparser.h) normally generated on unix, so if possible,
-using a nightly snaphot is substantially easier than working directly from
-CVS.</p></div><div class="variablelist"><p class="title"><b>Required Libraries</b></p><dl><dt><a href="http://www.boutell.com/gd/" target="_top">GD Library</a> :</dt><dd><p>MapServer uses the GD graphics library for rendering map
-images in GIF, PNG and JPEG format. These map images are displayed in web
-browser clients using the MapServer CGI. The current official version of GD
-is 2.0.33.  The distributed makefiles are setup to use the prebuilt GD Win32 DLL binaries which include GD, libjpeg, libpng, libz, libgif and FreeType 2
-all within one DLL.  This package is generally listed as "Windows DLL .zip"
-and the latest version is normally available at
-<a href="http://www.boutell.com/gd/http/gdwin32.zip" target="_top">
-http://www.boutell.com/gd/http/gdwin32.zip</a>.
-</p></dd><dt>Regex:</dt><dd><p>Regex is the regular expression library used by MapServer. It can be downloaded at
-<a href="ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz" target="_top">ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz</a>.</p></dd></dl></div><div class="variablelist"><p class="title"><b>Optional Libraries</b></p><dl><dt><a href="http://www.ijg.org/" target="_top">JPEG library</a>:</dt><dd><p>This library is required by GD to render JPEG images, if
-building GD from source.  You may download this library at
+The MapServer source code
-<a href="http://www.ijg.org/files/jpegsrc.v6b.tar.gz" target="_top">http://www.ijg.org/files/jpegsrc.v6b.tar.gz</a>.</p></dd><dt><a href="http://www.libpng.org/pub/png/" target="_top">PNG library</a>:</dt><dd><p>This library is required by GD to render PNG images, if
-<a href="http://sourceforge.net/projects/libpng/" target="_top">http://sourceforge.net/projects/libpng/</a>.</p></dd><dt><a href="http://www.gzip.org/zlib/" target="_top">Zlib</a>:</dt><dd><p>This library is required by libpng to provide graphics
-compression support.  It can be downloaded along with the PNG library, or at
-<a href="http://www.gzip.org/zlib.zip" target="_top">http://www.gzip.org/zlib.zip</a>.
-</p></dd><dt><a href="http://www.freetype.org/" target="_top">FreeType 2</a>: </dt><dd><p>FreeType provides TrueType support in MapServer via GD.  We
-only need to build FreeType seperately if building GD from source.  It can be
-downloaded at
-<a href="ftp://freetype.sourceforge.net/pub/freetype/freetype2/" target="_top">
-ftp://freetype.sourceforge.net/pub/freetype/freetype2/</a>.  The most current version is 2.1.9.</p></dd><dt><a href="http://www.remotesensing.org/proj/" target="_top">PROJ.4</a>: </dt><dd><p>Proj.4 provides on-the-fly projection support to MapServer.
-Users whose data are in different projection systems can use this library to
-reproject into a common projection.  It is also required for WMS, WFS or
-WCS services.  The current version is 4.4.9 and
-can be downloaded at <a href="ftp://ftp.remotesensing.org/pub/proj/proj-4.4.9.zip" target="_top">ftp://ftp.remotesensing.org/pub/proj/proj-4.4.9.zip</a>.</p></dd><dt><a href="http://www.gdal.org/gdal/" target="_top">GDAL/OGR</a>: </dt><dd><p>The GDAL/OGR library allows MapServer to read a variety of
-geospatial raster formast (GDAL) and vector formats (OGR).  It can be
-downloaded at <a href="http://www.gdal.org/dl/" target="_top">
+The MapServer source code can be downloaded from
+http://mapserver.gis.umn.edu/dload.html .  If you'd like to get the current
+development version of the software, following the nightly snapshot link under
+the Interim Builds title.  The absolute latest copy of the source code can be
+obtained from SVN; however, the SVN respository does not contain several
+important source files (maplexer.c, mapparser.c and mapparser.h) normally
+generated on unix, so if possible, using a nightly snaphot is substantially
+easier than working directly from CVS.
-http://www.gdal.org/dl/</a>.  The 1.2.5 version is known to work well
-with MapServer 4.4.</p></dd><dt><a href="http://www.esri.com/software/sde/index.html" target="_top">ArcSDE</a>: </dt><dd><p>ArcSDE is an ESRI proprietary spatial database engine.  Most
-users will not have access to it but if you have ArcSDE license, you can use
-its libraries to give MapServer access to SDE databases.</p></dd><dt><a href="http://www.mnplan.state.mn.us/EPPL7/" target="_top">EPPL7</a>:</dt><dd><p>This library allows MapServer to read EPPL7 datasets, as well as the older Erdas LAN/GIS files. This
-library is set as a default library in MapServer so there's no special source code to download.</p></dd></dl></div><p>Now that you have reviewed the libraries that provide support to MapServer, it is time to decide which
-ones to compile and use.   We will work with the pre-built GD distributed
-on Boutell.com with PNG, GIF, JPEG, and FreeType "built in".   If you want
-to provide OGC Web Services (ie. WMS, WFS) or want to perform on the fly
-reprojection then the PROJ.4 library will be needed.  If you need additional
-raster and vector data sources consider including GDAL/OGR support.  GDAL
-is also required for WCS service. </p><p>Our example calls for the required libraries and on-the-fly projection
-support so we need to download GD, regex, and Proj.4 libraries.  Go ahead and
-get those libraries.</p></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="options"></a>Set Compilation Options</h3></div></div><p>MapServer, like many of it's support libraries, comes with a Visual C++
+**Required Libraries**
+.. _`GD Library`: http://www.boutell.com/gd/
+`GD Library`_:
+   MapServer uses the GD graphics library for rendering map images in GIF, PNG
+   and JPEG format. These map images are displayed in web browser clients using
+   the MapServer CGI. The current official version of GD is 2.0.33.  The
+   distributed makefiles are setup to use the prebuilt GD Win32 DLL binaries
+   which include GD, libjpeg, libpng, libz, libgif and FreeType 2 all within one
+   DLL.  This package is generally listed as "Windows DLL .zip"
+   and the latest version is normally available at
+   http://www.boutell.com/gd/http/gdwin32.zip.
+Regex:
+   Regex is the regular expression library used by MapServer. It can be downloaded at
+   ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
+Optional Libraries
+.. _`JPEG Library`: http://www.ijg.org/
+`JPEG library`_:
+   This library is required by GD to render JPEG images, if building GD from
+   source.  You may download this library at
+   http://www.ijg.org/files/jpegsrc.v6b.tar.gz
+.. _`PNG library`: http://www.libpng.org/pub/png/
+`PNG library`_:
+   This library is required by GD to render PNG images, if building GD from
+   http://sourceforge.net/projects/libpng/
+.. _`Zlib`:  http://www.gzip.org/zlib/
+`Zlib`_:
+   This library is required by libpng to provide graphics
+   compression support.  It can be downloaded along with the PNG library, or at
+   http://www.gzip.org/zlib.zip .
+.. _`FreeType 2`: http://www.freetype.org/
+`FreeType 2`_:
+   FreeType provides TrueType support in MapServer via GD.  We only need to
+   build FreeType seperately if building GD from source.  It can be downloaded
+   at ftp://freetype.sourceforge.net/pub/freetype/freetype2/ .  The most
+   current version is 2.1.9.
+.. _`PROJ.4`: http://www.remotesensing.org/proj/
+`PROJ.4`_:
+  Proj.4 provides on-the-fly projection support to MapServer.  Users whose data
+  are in different projection systems can use this library to reproject into a
+  common projection.  It is also required for WMS, WFS or WCS services.  The
+  current version is 4.4.9 and can be downloaded at
+  ftp://ftp.remotesensing.org/pub/proj/proj-4.4.9.zip
+.. _`GDAL/OGR`: http://www.gdal.org/gdal/
+`GDAL/OGR`_:
+    The GDAL/OGR library allows MapServer to read a variety of geospatial
+    raster formast (GDAL) and vector formats (OGR).  It can be downloaded at
+    http://www.gdal.org/dl/.  The 1.2.5 version is known to work well with
+    MapServer 4.4.
+.. _`ArcSDE`: http://www.esri.com/software/sde/index.html
+`ArcSDE`_:
+    ArcSDE is an ESRI proprietary spatial database engine.  Most users will not
+    have access to it but if you have ArcSDE license, you can use its libraries
+    to give MapServer access to SDE databases.
+.. _`EPPL7`: http://www.mnplan.state.mn.us/EPPL7/
+`EPPL7`_:
+    This library allows MapServer to read EPPL7 datasets, as well as the older
+    Erdas LAN/GIS files. This library is set as a default library in MapServer
+    so there's no special source code to download.
+Now that you have reviewed the libraries that provide support to MapServer, it
+is time to decide which ones to compile and use.   We will work with the
+pre-built GD distributed on Boutell.com with PNG, GIF, JPEG, and FreeType
+"built in".   If you want to provide OGC Web Services (ie. WMS, WFS) or want to
+perform on the fly reprojection then the PROJ.4 library will be needed.  If you
+need additional raster and vector data sources consider including GDAL/OGR
+support.  GDAL is also required for WCS service.
+Our example calls for the required libraries and on-the-fly projection support
+so we need to download GD, regex, and Proj.4 libraries.  Go ahead and get those
+libraries.
+Set Compilation Options
+MapServer, like many of it's support libraries, comes with a Visual C++
 makefile called Makefile.vc.  It includes the file nmake.opt which contains
 many of the site specific definitions.  We will only need to edit the nmake.opt
 file to configure the build for our local site options, and support libraries.
-The Makefile.vc, and nmake.opt template file have been provided by
-Assefa Yewondwossen, and the DM Solutions folks.
-</p><p>
+The Makefile.vc, and nmake.opt template file have been provided by Assefa
+Yewondwossen, and the DM Solutions folks.
 As of MapServer 4.4, the default MapServer build options only include
 GD, and regex.  MapServer is built using the /MD option (which means
 MSVCRT.DLL should be used), so if any support libraries are being built
 statically (rather than as DLLs) we need to use /MD when building them as
 well.  By default modern PROJ.4 builds use /MD so we should be able to
 use the default PROJ.4 build without tweaking.
-</p><p>The example will compile with the GDWin32 pre-built DLL as well as
-regex-0.12, and PROJ.4.   The PROJ.4 support will ensure we can enable
+The example will compile with the GDWin32 pre-built DLL as well as regex-0.12,
+and PROJ.4.   The PROJ.4 support will ensure we can enable
 MapServer OGC-WMS compatibility.  Use notepad or another text editor to open
-the nmake.opt file and make the following changes.</p><div class="note"><h3 class="title">Comments</h3><p> Use the pound sign ( # ) to comment out
+the nmake.opt file and make the following changes.
+Comments
+Use the pound sign ( # ) to comment out
 the lines that you want to disable, or remove the pound sign to enable
-an option for NMAKE.</p></div><p>A. Enable PROJ.4 support, and update the path to the PROJ.4
+an option for NMAKE.
+A. Enable PROJ.4 support, and update the path to the PROJ.4
 directory.   Uncomment the PROJ= line, and the PROJ_DIR= line as follows,
 and update the PROJ_DIR path to point to your PROJ build.
-</p><pre class="programlisting"># Reprojecting.<br /># If you would like mapserver to be able to reproject data from one<br /># geographic projection to another, uncomment the following flag<br /># Proj.4 distribution (cartographic projection routines).  PROJ.4 is<br /># also required for all OGC services (WMS, WFS, and WCS). <br />#<br /># For PROJ_DIR use full path to Proj.4 distribution<br />PROJ=-DUSE_PROJ -DUSE_PROJ_API_H<br />PROJ_DIR=c:\projects\proj-4.4.9<br /></pre>
+  # Reprojecting.
+  # If you would like mapserver to be able to reproject data from one
+  # geographic projection to another, uncomment the following flag
+  # Proj.4 distribution (cartographic projection routines).  PROJ.4 is
+  # also required for all OGC services (WMS, WFS, and WCS).
+  # For PROJ_DIR use full path to Proj.4 distribution
+  PROJ=-DUSE_PROJ -DUSE_PROJ_API_H
+  PROJ_DIR=c:\projects\proj-4.4.9
 If you look down later in the file, you can see that once PROJ is enabled,
 MapServer will be linked with proj_i.lib, the PROJ.4 stub library, meaning
 that MapServer will be using the PROJ.DLL as opposed to statically linking
 in PROJ.4.
-<p></p><p>B. Uncomment the WMS option.
-</p><pre class="programlisting"># Use this flag to compile with WMS Server support.<br /># To find out more about the OpenGIS Web Map Server Specification go to<br /># http://www.opengis.org/<br />WMS=-DUSE_WMS_SVR<br /></pre>
-<p></p><p>C. Update to use GD.  Here's what it should look like in our example.
-</p><pre class="programlisting">GD_DIR=c:/projects/gdwin32<br />GD_LIB=$(GD_DIR)/bgd.lib<br /></pre>
-<p></p><div class="note"><h3 class="title">Note</h3><p>As distributed the GDWin32 binary build does not include the
-bgd.lib stub library.  It is necessary to run the <b>makemsvcimport.bat
-</b>
+B. Uncomment the WMS option.
+  # Use this flag to compile with WMS Server support.
+  # To find out more about the OpenGIS Web Map Server Specification go to
+  # http://www.opengis.org/
+  WMS=-DUSE_WMS_SVR
+C. Update to use GD.  Here's what it should look like in our example.
+  GD_DIR=c:/projects/gdwin32
+  GD_LIB=$(GD_DIR)/bgd.lib
+**Note**: As distributed the GDWin32 binary build does not include the
+bgd.lib stub library.  It is necessary to run the **makemsvcimport.bat**
 script in the gdwin32 directory first.
-</p></div><p>D. Make sure the regex path is set correctly.  In order for the
+D. Make sure the regex path is set correctly.  In order for the
 "delete" command in the "nmake /f makefile.vc clean" target to work properly
 it is necessary to use backslashes in the REGEX_DIR definition.
-</p><pre class="programlisting"># REGEX Libary<br /># <br /># VC++ does not include the REGEX library... so we must provide our one.<br /># The following definitions will try to build GNU regex-0.12 located in the<br /># regex-0.12 sub-directory.<br /># If it was not included in the source distribution, then you can get it from:<br />#    ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz<br /># Provide the full path to the REGEX project directory<br /># You do not need this library if you are compiling for PHP mapscript.<br /># In that case the PHP regex library will be used instead<br />!IFNDEF PHP<br />REGEX_DIR=c:\projects\regex-0.12<br />!ENDIF<br /></pre>
-<p></p><p>Your Makefile is now set.</p></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="complib"></a>Compile the Libraries</h3></div></div><p>Before compiling MapServer, you must first compile its supporting
+  # REGEX Libary
+  # VC++ does not include the REGEX library... so we must provide our one.
+  # The following definitions will try to build GNU regex-0.12 located in the
+  # regex-0.12 sub-directory.
+  # If it was not included in the source distribution, then you can get it from:
+  #    ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
+  # Provide the full path to the REGEX project directory
+  # You do not need this library if you are compiling for PHP mapscript.
+  # In that case the PHP regex library will be used instead
+  !IFNDEF PHP
+  REGEX_DIR=c:\projects\regex-0.12
+  !ENDIF
+Your Makefile is now set.
+Compile the Libraries
+Before compiling MapServer, you must first compile its supporting
 libraries.  How this is done varies for each library.  For the PROJ.4 library
-a <b>nmake /f makefile.vc</b> command in the proj-4.4.9\src
+a **nmake /f makefile.vc** command in the proj-4.4.9\src
 directory should be sufficient.  The regex-0.12 code is actually built by
-the MapServer build process, so you don't need to do anything there. </p>
-<div class="variablelist"><p class="title"><b>Note: Compiling libcurl</b></p></div>
-<p>Previously, curl libraries can be compiled using the following command:
-<pre>nmake /f makefile.vc6 CFG=release</pre>
-This creates a static library, libcurl.lib, to which you compile against.  Versions newer than version 7.10.x should be compiled as dynamic library.  This is accomplished using the command:
-<pre>nmake /f makefile.vc6 CFG=release-dll</pre>
+the MapServer build process, so you don't need to do anything there.
+Compiling libcurl
+Previously, curl libraries can be compiled using the following command:
+  nmake /f makefile.vc6 CFG=release
+This creates a static library, libcurl.lib, to which you compile against.
+Versions newer than version 7.10.x should be compiled as dynamic library.  This
+is accomplished using the command:
+  nmake /f makefile.vc6 CFG=release-dll
 You will then need to edit MapServer's nmake.opt to replace the CURL_LIB variable with this line:
-<pre>CURL_LIB = $(CURL_DIR)/lib/libcurl_imp.lib</pre></p>
-</div>
-<div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="compmapserv"></a>Compile MapServer</h3></div></div><p>Once you have compiled the supporting libraries successfully, you are
-ready to take the final compilation step.  If you have not already
-done so, open a command prompt and set the VC++ environment variables by
-running the vcvars32.bat usually located in
-C:\Program Files\Microsoft Visual Studio\VC98\bin\vcvars32.bat.
-</p><pre class="screen">C:\Users&gt;cd \projects\mapserver<br />C:\Projects\mapserver&gt;"C:\Program Files\Microsoft Visual Studio\VC98\Bin\vcvars32.bat"<br />C:\Projects\mapserver&gt;<br /><br />Setting environment for using Microsoft Visual C++ tool.<br />C:\Projects\mapserver&gt;</pre>
-<p></p><p>Now issue the command: <b>nmake /f Makefile.vc</b> and wait
+  CURL_LIB = $(CURL_DIR)/lib/libcurl_imp.lib
+Compile MapServer
+Once you have compiled the supporting libraries successfully, you are ready to
+take the final compilation step.  If you have not already done so, open a
+command prompt and set the VC++ environment variables by running the
+vcvars32.bat usually located in **C:\Program Files\Microsoft Visual Studio\VC98\bin\vcvars32.bat**.
+  C:\Users> cd \projects\mapserver
+  C:\Projects\mapserver&> C:\Program Files\Microsoft Visual Studio\VC98\Bin\vcvars32.bat"
+  C:\Projects\mapserver>
+  Setting environment for using Microsoft Visual C++ tool.
+Now issue the command: **nmake /f Makefile.vc** and wait
 for it to finish compiling. If it compiles successfully, you should get
 mapserver.lib, libmap.dll, mapserv.exe, and other .EXE files.  That's it for
 the compilation process. If you run into problems, read section 4 about
 compiling errors. You can also ask for help from the helpful folks in the
-MapServer-dev e-mail list.</p></div>
-<div class="variablelist"><p class="title"><b>Compiling MapServer with PostGIS support</b></p>
-<p>To compile PostGIS support into MapServer, here's what you need to do:
-<pre>
+MapServer-dev e-mail list.
+Compiling MapServer with PostGIS support
+To compile PostGIS support into MapServer, here's what you need to do:
 1. download the PostgreSQL 8.0.1 sources (postgresql-8.0.1.tar.gz) eg from:
-ftp://ftp.heanet.ie/pub/postgresql/source/v8.0.1/postgresql-8.0.1.tar.gz
+   ftp://ftp.heanet.ie/pub/postgresql/source/v8.0.1/postgresql-8.0.1.tar.gz
 2. I extracted them to C:\projects\postgresql-8.0.1
 3. download the Microsoft Platform SDK (250 Mb!) from
    http://www.microsoft.com/msdownload/platformsdk/sdkupdate/
@@ -197,81 +385,115 @@
 8. don't forget to copy libpq.dll (from
    C:\projects\postgresql-8.0.1\src\interfaces\libpq\release)
    into a location where Mapserver can find it.
-</pre></p></div>
-<div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="errors"></a>Common Compiling Errors</h3></div></div><p>
+Common Compiling Errors
 Following are a few common errors you may encounter while trying to build
 MapServer.
-</p><div class="itemizedlist"><ul type="disc"><li><p>
-Visual C++ Tools Not Properly Initialized.
-</p><pre class="screen">C:\projects\mapserver&gt;nmake -f /makefile.vc<br />'nmake' is not recognized as an internal or external command,<br />operable program or batch file.<br /></pre>
+ * Visual C++ Tools Not Properly Initialized.
+    C:\projects\mapserver> nmake -f /makefile.vc
+    'nmake' is not recognized as an internal or external command,
+    operable program or batch file.
-This occurs if you have not properly defined the path and other
-environment variables required to use MS VisualC++ from the command shell.
-Invoke the VCVARS32.BAT script, usually with the command
-<b>C:\Program Files\Microsoft Visual Studio\VC98\bin\vcvars32.bat</b> or something similar if visual studio was installed in an alternate
-location.  To test if VC++ is available, just type "nmake" or "cl" in the
-command shell and ensure it is found.
+   This occurs if you have not properly defined the path and other environment
+   variables required to use MS VisualC++ from the command shell.  Invoke the
+   VCVARS32.BAT script, usually with the command **C:\Program Files\Microsoft
+   Visual Studio\VC98\bin\vcvars32.bat** or something similar if visual studio was
+   installed in an alternate location.  To test if VC++ is available, just type
+   "nmake" or "cl" in the command shell and ensure it is found.
-<p></p></li><li><p>
-Regex Build Problems.
+ * Regex Build Problems.
+     regex.obj : error LNK2001: unresolved external symbol _printchar
+     libmap.dll : fatal error LNK1120: 1 unresolved externals
+     NMAKE : fatal error U1077: 'link' : return code '0x460'
+     Stop.
-</p><pre class="screen">regex.obj : error LNK2001: unresolved external symbol _printchar<br />libmap.dll : fatal error LNK1120: 1 unresolved externals<br />NMAKE : fatal error U1077: 'link' : return code '0x460'<br />Stop.<br /></pre>
+   This occurs if you use the stock regex-0.12 we referenced.  I work around
+   this by commenting out the "extern" statement for the printchar() function,
+   and replacing it with a stub implementation in regex-0.12\regex.c.
-This occurs if you use the stock regex-0.12 we referenced.  I work around this
-by commenting out the "extern" statement for the printchar() function, and
-replacing it with a stub implementation in regex-0.12\regex.c.
+     //extern void printchar ();
+     void printchar( int i ) {}
-<pre class="screen">//extern void printchar ();<br />void printchar( int i ) {}<br /></pre>
-GD Import Library Missing.
+ * GD Import Library Missing.
-</p><pre class="screen">LINK : fatal error LNK1104: cannot open file 'c:/projects/gdwin32/bgd.lib'<br />NMAKE : fatal error U1077: 'link' : return code '0x450'<br />Stop.<br /></pre>
-If you are using the pre-built GD binaries, you still need to run the
-<b>makemsvcimport.bat</b> script in the gdwin32 directory to
-create a VC++ compatible stub library (bgd.lib).
-<p></p></li></ul></div></div></div><div class="sect1"><div class="titlepage"><div><h2 class="title"><a name="install"></a>Installation</h2></div></div><p>The file we are most interested in is mapserv.exe. The other executable files are the MapServer utility programs.
-Visit the MapServer utility page at <a href="http://mapserver.gis.umn.edu/utils.html" target="_top">http://mapserver.gis.umn.edu/utils.html
+     LINK : fatal error LNK1104: cannot open file 'c:/projects/gdwin32/bgd.lib'
+     NMAKE : fatal error U1077: 'link' : return code '0x450'
+     Stop.
-</a> to learn more about these utilities.</p><p>To test that the CGI program is working, type mapserv.exe at the
-command prompt. You should see the following message:
-</p><pre class="screen">This script can only be used to decode form results and<br />should be initiated as a CGI process via a httpd server.</pre><p></p><p>
+   If you are using the pre-built GD binaries, you still need to run the
+   **makemsvcimport.bat** script in the gdwin32 directory to
+   create a VC++ compatible stub library (bgd.lib).
+Installation
+The file we are most interested in is mapserv.exe. The other executable files are the MapServer utility programs.
+Visit the MapServer utility page at http://mapserver.gis.umn.edu/utils.html
+to learn more about these utilities.
+To test that the CGI program is working, type mapserv.exe at the command
+prompt. You should see the following message:
+  This script can only be used to decode form results and
+  should be initiated as a CGI process via a httpd server.
 You may instead get a popup indicating that a DLL (such as bgd.dll) is
 missing.  You will need to copy all the required DLLs (ie. bgd.dll, and
 proj.dll) to the same directory as the mapserv.exe program.
-</p><p>Now type mapserv -v at the command prompt to get this message:
-</p><pre class="screen">MapServer version 4.4.0-beta3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP <br />SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=SHAPEFILE <br />DEBUG=MSDEBUG<br /></pre><p></p><p>This tells us what data formats and other options are supported by
+Now type mapserv -v at the command prompt to get this message:
+  MapServer version 4.4.0-beta3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
+  SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=SHAPEFILE
+  DEBUG=MSDEBUG
+This tells us what data formats and other options are supported by
 mapserv.exe. Assuming you have your web server set up, copy
 mapserv.exe, libmap.dll, bgd.dll, proj.dll and any other required DLLs to the
-cgi-bin directory.</p><p>You are now ready to download the demo application and try out your own
+cgi-bin directory.
+You are now ready to download the demo application and try out your own
 MapServer CGI program. If you wish, you can also create a directory to store
 the utility programs.  I'd suggest making a subdirectory called "bin" under
 the directory "projects" and copy the executables to that subdirectory. You
 might find these programs useful as you develop MapServer applications.
-</p></div><div class="sect1"><div class="titlepage"><div><h2 class="title"><a name="other"></a>Other Helpful Information</h2></div></div><p>The MapServer Unix Compilation and Installation
-HOWTO has good descriptions of some MapServer compilation options and library issues. I will write more about
-those options and issues on the next revision of this HOWTO.</p><p>The README documents of each of the supporting libraries provide compilation instructions for Windows.</p><p>The MapServer User community has a collective knowledge of the nuances of MapServer compilation. Seek their
-advice wisely.</p></div><div class="sect1"><div class="titlepage"><div><h2 class="title"><a name="docinfo"></a>About This Document</h2></div></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="copyright"></a>Copyright Information</h3></div></div><p>
-                Copyright (c) 2001, Pericles S. Nacionales, University of
-		Minnesota
-            </p><p>
-                This documentation is covered by the same Open Source license as the
-                MapServer software itself.  See MapServer's
-                <a href="http://mapserver.gis.umn.edu/license.html" target="_top">License and
-                Credits</a> page for the complete text.
-            </p></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="disclaimer"></a>Disclaimer</h3></div></div><p>
-     				No liability for the contents of this document can be accepted.
-    				Use the concepts, examples and other content at your own risk.
-    				As this is a new edition of this document, there may be errors
-    				and inaccuracies that may be damaging to your system.
-    				Although this is highly unlikely, the author(s) do not take any
-    				responsibility for that:  proceed with caution.
-                 	</p></div><div class="sect2"><div class="titlepage"><div><h3 class="title"><a name="ack"></a>Acknowledgements</h3></div></div><p>Thanks to Assefa Yewondwossen for providing the Makefile.vc.
-                   I would not have been able to write this HOWTO without that file.
-                  </p>
-<p>Thanks to Bart van den Eijnden for the libcurl and PostGIS compilation info.<p>
-                  Thanks to the Steve Lime for developing MapServer and to the many
-                  developers who contribute time and effort in order to keep the MapServer
-                  project successful.
-   			</p></div></div>
\ No newline at end of file
+Other Helpful Information
+The MapServer Unix Compilation and Installation HOWTO has good descriptions of
+some MapServer compilation options and library issues. I will write more about
+those options and issues on the next revision of this HOWTO.
+The README documents of each of the supporting libraries provide compilation
+instructions for Windows.
+The MapServer User community has a collective knowledge of the nuances of
+MapServer compilation. Seek their advice wisely.
+Acknowledgements
+Thanks to Assefa Yewondwossen for providing the Makefile.vc.
+I would not have been able to write this HOWTO without that file.
+Thanks to Bart van den Eijnden for the libcurl and PostGIS compilation info.
+Thanks to the Steve Lime for developing MapServer and to the many
+developers who contribute time and effort in order to keep the MapServer
+project successful.
