[mapserver-commits] r8000 - in trunk/mapserver: . mapscript/php3 mapscript/python/tests/cases mapscript/swiginc
Fri Oct 24 11:42:15 EDT 2008
Author: aboudreault
Date: 2008-10-24 11:42:15 -0400 (Fri, 24 Oct 2008)
New Revision: 8000
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/php3/README
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapscript/python/tests/cases/labeltest.py
   trunk/mapserver/mapscript/python/tests/cases/styletest.py
   trunk/mapserver/mapscript/swiginc/label.i
   trunk/mapserver/mapscript/swiginc/style.i
MapScript: Added getBinding method to in label and style object (#2670)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/HISTORY.TXT	2008-10-24 15:42:15 UTC (rev 8000)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- MapScript: Added getBinding method to label and style object (#2670)
 - mapowscommon.c: use strcasecmp to check for language value
 - raster query fix for tileindex with relative paths (#2722)
Modified: trunk/mapserver/mapscript/php3/README
--- trunk/mapserver/mapscript/php3/README	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/php3/README	2008-10-24 15:42:15 UTC (rev 8000)
@@ -1116,6 +1116,14 @@
            This would bind the color parameter with the data (ie will extract
            the value of the color from the field called "FIELD_NAME_COLOR"
+   string getBinding(const labelbinding)
+       Get the attribute binding for a specfiled label property. Returns null if there
+       is no binding for this property.
+        Example:
+           $oLabel->setbinding(MS_LABEL_BINDING_COLOR, "FIELD_NAME_COLOR");
+           echo $oLabel->getbinding(MS_LABEL_BINDING_COLOR); // FIELD_NAME_COLOR
    int removeBinding(const labelbinding)
         Remove the attribute binding for a specfiled style property. Returns true on success.
         Example:
@@ -1727,7 +1735,15 @@
            $oStyle->setbinding(MS_STYLE_BINDING_COLOR, "FIELD_NAME_COLOR");
+   string getBinding(const stylebinding)
+       Get the attribute binding for a specfiled style property. Returns null if there
+        Example:
+           $oStyle->setbinding(MS_STYLE_BINDING_COLOR, "FIELD_NAME_COLOR");
+           echo $oStyle->getbinding(MS_STYLE_BINDING_COLOR); // FIELD_NAME_COLOR
    int removeBinding(const stylebinding)
         Added in MapServer 5.0.
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2008-10-24 15:42:15 UTC (rev 8000)
@@ -239,6 +239,7 @@
 DLEXPORT void php3_ms_label_setProperty(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_label_setBinding(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_label_getBinding(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_label_removeBinding(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_color_setRGB(INTERNAL_FUNCTION_PARAMETERS);
@@ -332,6 +333,7 @@
 DLEXPORT void php3_ms_style_setProperty(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_style_clone(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_style_setBinding(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_style_getBinding(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_style_removeBinding(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_grid_new(INTERNAL_FUNCTION_PARAMETERS);
@@ -801,6 +803,7 @@
 function_entry php_label_class_functions[] = {
     {"set",             php3_ms_label_setProperty,      NULL},
     {"setbinding",      php3_ms_label_setBinding,      NULL},
+    {"getbinding",      php3_ms_label_getBinding,      NULL},
     {"removebinding",   php3_ms_label_removeBinding,      NULL},
     {NULL, NULL, NULL}
@@ -903,6 +906,7 @@
     {"set",             php3_ms_style_setProperty,      NULL},
     {"clone",           php3_ms_style_clone,            NULL},
     {"setbinding",      php3_ms_style_setBinding,       NULL},
+    {"getbinding",      php3_ms_style_getBinding,       NULL},
     {"removebinding",      php3_ms_style_removeBinding,       NULL},
     {NULL, NULL, NULL}
@@ -8818,7 +8822,47 @@
     RETURN_TRUE;
+/* {{{ proto int label.getbinding(const bindingid)
+   Get the value of a attribute binding for a specfiled label property.
+   Returns the string value if exist, else null. */
+    pval  *pThis = NULL;
+    labelObj *self = NULL;
+    HashTable   *list=NULL;
+    pval   *pBindingId;
+    char   *pszValue=NULL;
+    pThis = getThis();
+    if (pThis == NULL ||
+        getParameters(ht, 1, &pBindingId) != SUCCESS)
+        WRONG_PARAM_COUNT;
+    self = (labelObj *)_phpms_fetch_handle(pThis,
+                                           PHPMS_GLOBAL(le_mslabel),
+                                           list TSRMLS_CC);
+    if (self == NULL)
+       php3_error(E_ERROR, "Invalid label object.");
+    convert_to_long(pBindingId);
+    if (pBindingId->value.lval < 0 || pBindingId->value.lval > MS_LABEL_BINDING_LENGTH)
+       php3_error(E_ERROR, "Invalid binding id given for getbinding function.");
+    if( (pszValue = self->bindings[pBindingId->value.lval].item) != NULL)
+       RETURN_STRING(pszValue, 1);
+    return;
 /* {{{ proto int label.removebinding(const bindingid)
    Remove attribute binding for a specfiled label property. Returns true on success. */
@@ -8846,7 +8890,7 @@
-       php3_error(E_ERROR, "Invalid binding id given for setbinding function.");
+       php3_error(E_ERROR, "Invalid binding id given for removebinding function.");
     if(self->bindings[pBindingId->value.lval].item)
@@ -14148,7 +14192,47 @@
     RETURN_TRUE;
+/* {{{ proto int style.getbinding(const bindingid)
+   Get the value of a attribute binding for a specfiled style property.
+    styleObj *self = NULL;
+    pval   *pBindingId;
+    self = (styleObj *)_phpms_fetch_handle(pThis,
+                                           PHPMS_GLOBAL(le_msstyle),
+                                           list TSRMLS_CC);
+    if (self == NULL)
+       php3_error(E_ERROR, "Invalid style object.");
+    if (pBindingId->value.lval < 0 || pBindingId->value.lval > MS_STYLE_BINDING_LENGTH)
+    return;
 /* {{{ proto int style.removebinding(const bindingid)
    Remove attribute binding for a specfiled style property. Returns true on success. */
Modified: trunk/mapserver/mapscript/python/tests/cases/labeltest.py
--- trunk/mapserver/mapscript/python/tests/cases/labeltest.py	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/python/tests/cases/labeltest.py	2008-10-24 15:42:15 UTC (rev 8000)
@@ -41,6 +41,15 @@
 # Test begins now
+class NewLabelsTestCase(MapTestCase):
+    def testLabelBinding(self):
+        """attribute binding can be set and get"""
+        new_label = mapscript.labelObj()
+        assert (not new_label.getBinding(mapscript.MS_LABEL_BINDING_COLOR))
+        new_label.setBinding(mapscript.MS_LABEL_BINDING_COLOR,"NEW_BINDING")
+        assert (new_label.getBinding(mapscript.MS_LABEL_BINDING_COLOR) == "NEW_BINDING")
 class LabelCacheMemberTestCase(MapTestCase):
     def testCacheMemberText(self):
Modified: trunk/mapserver/mapscript/python/tests/cases/styletest.py
--- trunk/mapserver/mapscript/python/tests/cases/styletest.py	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/python/tests/cases/styletest.py	2008-10-24 15:42:15 UTC (rev 8000)
@@ -84,6 +84,13 @@
         assert new_style.color.green == 2
         assert new_style.color.blue == 3
+    def testStyleBinding(self):
+        new_style = mapscript.styleObj()
+        assert (not new_style.getBinding(mapscript.MS_STYLE_BINDING_COLOR))
+        new_style.setBinding(mapscript.MS_STYLE_BINDING_COLOR,"NEW_BINDING")
+        assert (new_style.getBinding(mapscript.MS_STYLE_BINDING_COLOR) == "NEW_BINDING")
     def testAppendNewStyle(self):
         """a new style can be appended properly"""
         p_layer = self.map.getLayerByName('POINT')
Modified: trunk/mapserver/mapscript/swiginc/label.i
--- trunk/mapserver/mapscript/swiginc/label.i	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/swiginc/label.i	2008-10-24 15:42:15 UTC (rev 8000)
@@ -48,6 +48,13 @@
     return MS_SUCCESS;
+  char *getBinding(int binding)
+    if(binding < 0 || binding >= MS_LABEL_BINDING_LENGTH) return NULL;
+    return self->bindings[binding].item;
   int setBinding(int binding, char *item)
     if(!item) return MS_FAILURE;
Modified: trunk/mapserver/mapscript/swiginc/style.i
--- trunk/mapserver/mapscript/swiginc/style.i	2008-10-23 03:36:07 UTC (rev 7999)
+++ trunk/mapserver/mapscript/swiginc/style.i	2008-10-24 15:42:15 UTC (rev 8000)
@@ -153,4 +153,11 @@
     return MS_SUCCESS;
+    if(binding < 0 || binding >= MS_STYLE_BINDING_LENGTH) return NULL;
