[mapserver-commits] r7905 - trunk/mapserver/mapscript/python/examples
Wed Sep 10 17:40:24 EDT 2008
Author: tomkralidis
Date: 2008-09-10 17:40:23 -0400 (Wed, 10 Sep 2008)
New Revision: 7905
Added:
   trunk/mapserver/mapscript/python/examples/geocode_addresses.py
Initial implementation
Added: trunk/mapserver/mapscript/python/examples/geocode_addresses.py
--- trunk/mapserver/mapscript/python/examples/geocode_addresses.py	                        (rev 0)
+++ trunk/mapserver/mapscript/python/examples/geocode_addresses.py	2008-09-10 21:40:23 UTC (rev 7905)
@@ -0,0 +1,88 @@
+#!/usr/bin/python
+# Script : geocode_addresses.py
+# Purpose: simple script to read a csv file, geocode the addresses
+# with the Google Maps API and write to a new shapefile
+# $Id$
+import sys
+import csv
+import mapscript
+import urllib
+import urllib2
+from lxml import etree
+# uses dbfpy http://pypi.python.org/pypi/dbfpy/2.2.1
+from dbfpy.dbf import *
+# example invocation
+# ./reproj.py ./foo.csv address_colnum, city_colnum, stateprov_colnum ./bar.csv
+# check input parameters
+if (len(sys.argv) != 6):
+    print sys.argv[0] + \
+    " <csvfile> <address_colnum> <city_colnum> <stateprov_colnum> <outfile>"
+    sys.exit(1)
+# geocoder base request URL
+sGeocoderUrl = "http://www.geocoder.ca/?geoit=xml&locate="
+# set csv record indices
+sAddress   = int(sys.argv[2])
+sCity      = int(sys.argv[3])
+sStateProv = int(sys.argv[4])
+# open file
+fCsv = open(sys.argv[1], 'r')
+# read csv
+csvIn = csv.reader(fCsv)
+# create output shp/shx
+msSFOut = mapscript.shapefileObj(sys.argv[-1], 1)
+# create output dbf
+dbfOut = Dbf(sys.argv[-1]+".dbf", new=True)
+# add fields
+dbfOut.addField(
+    ("address", 'C', 255),
+    ("city", 'C', 255),
+    ("stateprov", 'C', 255),
+    ("x", 'N', 6,2),
+    ("y", 'N', 7,2)
+for aRow in csvIn:
+    # concatenate request params
+    sRequest = aRow[sAddress] + "," + aRow[sCity] + "," + aRow[sStateProv]
+    # contatenate request params (escaped) and base URL
+    sRequest = sGeocoderUrl + urllib.quote(sRequest)
+    # make the HTTP request
+    ul2Response = urllib2.urlopen(sRequest)
+    # serialize into etree XML object
+    etTree = etree.parse(ul2Response)
+    sY = float(etTree.find('latt').text)
+    sX = float(etTree.find('longt').text)
+    # serialize mapscript pointObj and add to shapefile
+    msPoint = mapscript.pointObj(sX, sY)
+    msSFOut.addPoint(msPoint)
+    # add dbf record
+    dRec=dbfOut.newRecord()
+    dRec['address']   = aRow[sAddress]
+    dRec['city']      = aRow[sCity]
+    dRec['StateProv'] = aRow[sStateProv]
+    dRec['x']         = sX
+    dRec['y']         = sY
+    dRec.store()
+# close files
+fCsv.close()
+dbfOut.close()
Property changes on: trunk/mapserver/mapscript/python/examples/geocode_addresses.py
___________________________________________________________________
   + Author Id Date Revision
