[mapserver-commits] r7917 - trunk/mapserver
Mon Sep 22 13:53:20 EDT 2008
Author: Assefa
Date: 2008-09-22 13:53:19 -0400 (Mon, 22 Sep 2008)
New Revision: 7917
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapmssql2008.c
Correct allocation error in mapmssql2008.c (#2768)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2008-09-18 03:53:10 UTC (rev 7916)
+++ trunk/mapserver/HISTORY.TXT	2008-09-22 17:53:19 UTC (rev 7917)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- Correct allocation error in mapmssql2008.c
 - Add possibility  to use a full resolution setting for svg output (#1706)
 - Fixed GetFeature through tileindex bug: the tileindex of the shape found
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c	2008-09-18 03:53:10 UTC (rev 7916)
+++ trunk/mapserver/mapmssql2008.c	2008-09-22 17:53:19 UTC (rev 7917)
@@ -1285,7 +1285,7 @@
 				/* Set up to request the size of the buffer needed */
                 rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
-                /* allow space for coercion to geometry collection if needed
+                /* allow space for coercion to geometry collection if needed*/
                 wkbTemp = (char*)malloc(needLen+9);
                 /* write data above space allocated for geometry collection coercion */
