[mapserver-commits] r9241 - trunk/mapserver
Mon Aug 3 10:23:34 EDT 2009
Author: dmorissette
Date: 2009-08-03 10:23:34 -0400 (Mon, 03 Aug 2009)
New Revision: 9241
   trunk/mapserver/mapows.c
   trunk/mapserver/mapows.h
Moved msOWSLookupMetadata() outside of #ifdef to solve issue with compiling without OGC services but with libxml2 enabled
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2009-08-03 14:16:34 UTC (rev 9240)
+++ trunk/mapserver/mapows.c	2009-08-03 14:23:34 UTC (rev 9241)
@@ -134,6 +134,115 @@
                       * since we're not in force_ows_mode*/
+** msOWSLookupMetadata()
+** Attempts to lookup a given metadata name in multiple OWS namespaces.
+** 'namespaces' is a string with a letter for each namespace to lookup
+** in the order they should be looked up. e.g. "MO" to lookup wms_ and ows_
+** If namespaces is NULL then this function just does a regular metadata
+** lookup.
+const char *msOWSLookupMetadata(hashTableObj *metadata,
+                                const char *namespaces, const char *name)
+    const char *value = NULL;
+    if (namespaces == NULL)
+        value = msLookupHashTable(metadata, (char*)name);
+    else
+        char buf[100] = "ows_";
+        strncpy(buf+4, name, 95);
+        buf[99] = '\0';
+        while (value == NULL && *namespaces != '\0')
+            switch (*namespaces)
+              case 'O':         /* ows_... */
+                buf[0] = 'o';
+                buf[1] = 'w';
+                buf[2] = 's';
+                break;
+              case 'M':         /* wms_... */
+                buf[0] = 'w';
+                buf[1] = 'm';
+                buf[2] = 's';
+                break;
+              case 'F':         /* wfs_... */
+                buf[0] = 'w';
+                buf[1] = 'f';
+                buf[2] = 's';
+                break;
+              case 'C':         /* wcs_... */
+                buf[0] = 'w';
+                buf[1] = 'c';
+                buf[2] = 's';
+                break;
+              case 'G':         /* gml_... */
+                buf[0] = 'g';
+                buf[1] = 'm';
+                buf[2] = 'l';
+                break;
+                case 'S':         /* sos_... */
+                buf[0] = 's';
+                buf[1] = 'o';
+                buf[2] = 's';
+                break;
+              default:
+                /* We should never get here unless an invalid code (typo) is */
+                /* present in the code, but since this happened before... */
+                msSetError(MS_WMSERR,
+                           "Unsupported metadata namespace code (%c).",
+                           "msOWSLookupMetadata()", *namespaces );
+                assert(MS_FALSE);
+                return NULL;
+            value = msLookupHashTable(metadata, buf);
+            namespaces++;
+    return value;
+** msOWSLookupMetadata2()
+** Attempts to lookup a given metadata name in multiple hashTables, and
+** in multiple OWS namespaces within each. First searches the primary
+** table and if no result is found, attempts the search using the
+** secondary (fallback) table.
+** lookup.
+const char *msOWSLookupMetadata2(hashTableObj *pri,
+                                        hashTableObj *sec,
+                                        const char *name)
+    const char *result;
+    if ((result = msOWSLookupMetadata(pri, namespaces, name)) == NULL)
+        /* Try the secondary table */
+        result = msOWSLookupMetadata(sec, namespaces, name);
+    return result;
 #if defined(USE_WMS_SVR) || defined (USE_WFS_SVR) || defined (USE_WCS_SVR) || defined(USE_SOS_SVR) || defined(USE_WMS_LYR) || defined(USE_WFS_LYR)
 #if !defined(USE_PROJ)
@@ -467,113 +576,6 @@
-** msOWSLookupMetadata()
-** Attempts to lookup a given metadata name in multiple OWS namespaces.
-** 'namespaces' is a string with a letter for each namespace to lookup
-** in the order they should be looked up. e.g. "MO" to lookup wms_ and ows_
-** If namespaces is NULL then this function just does a regular metadata
-** lookup.
-const char *msOWSLookupMetadata(hashTableObj *metadata,
-                                const char *namespaces, const char *name)
-    const char *value = NULL;
-    if (namespaces == NULL)
-        value = msLookupHashTable(metadata, (char*)name);
-    else
-        char buf[100] = "ows_";
-        strncpy(buf+4, name, 95);
-        buf[99] = '\0';
-        while (value == NULL && *namespaces != '\0')
-            switch (*namespaces)
-              case 'O':         /* ows_... */
-                buf[0] = 'o';
-                buf[1] = 'w';
-                buf[2] = 's';
-                break;
-              case 'M':         /* wms_... */
-                buf[0] = 'w';
-                buf[1] = 'm';
-                buf[2] = 's';
-                break;
-              case 'F':         /* wfs_... */
-                buf[0] = 'w';
-                buf[1] = 'f';
-                buf[2] = 's';
-                break;
-              case 'C':         /* wcs_... */
-                buf[0] = 'w';
-                buf[1] = 'c';
-                buf[2] = 's';
-                break;
-              case 'G':         /* gml_... */
-                buf[0] = 'g';
-                buf[1] = 'm';
-                buf[2] = 'l';
-                break;
-                case 'S':         /* sos_... */
-                buf[0] = 's';
-                buf[1] = 'o';
-                buf[2] = 's';
-                break;
-              default:
-                /* We should never get here unless an invalid code (typo) is */
-                /* present in the code, but since this happened before... */
-                msSetError(MS_WMSERR,
-                           "Unsupported metadata namespace code (%c).",
-                           "msOWSLookupMetadata()", *namespaces );
-                assert(MS_FALSE);
-                return NULL;
-            value = msLookupHashTable(metadata, buf);
-            namespaces++;
-    return value;
-** msOWSLookupMetadata2()
-** Attempts to lookup a given metadata name in multiple hashTables, and
-** in multiple OWS namespaces within each. First searches the primary
-** table and if no result is found, attempts the search using the
-** secondary (fallback) table.
-** lookup.
-const char *msOWSLookupMetadata2(hashTableObj *pri,
-                                        hashTableObj *sec,
-                                        const char *name)
-    const char *result;
-    if ((result = msOWSLookupMetadata(pri, namespaces, name)) == NULL)
-        /* Try the secondary table */
-        result = msOWSLookupMetadata(sec, namespaces, name);
-    return result;
 ** msOWSPrintMetadata()
 ** Attempt to output a capability item.  If corresponding metadata is not
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2009-08-03 14:16:34 UTC (rev 9240)
+++ trunk/mapserver/mapows.h	2009-08-03 14:23:34 UTC (rev 9241)
@@ -167,6 +167,13 @@
 MS_DLL_EXPORT int msOWSDispatch(mapObj *map, cgiRequestObj *request, int force_ows_mode);
+MS_DLL_EXPORT const char * msOWSLookupMetadata(hashTableObj *metadata,
+                                    const char *namespaces, const char *name);
+MS_DLL_EXPORT const char * msOWSLookupMetadata2(hashTableObj *pri,
+                                                const char *name);
 MS_DLL_EXPORT int msOWSMakeAllLayersUnique(mapObj *map);
@@ -206,12 +213,6 @@
 #define OWS_WMS     1
 #define OWS_WFS     2
-MS_DLL_EXPORT const char * msOWSLookupMetadata(hashTableObj *metadata,
-                                    const char *namespaces, const char *name);
-MS_DLL_EXPORT const char * msOWSLookupMetadata2(hashTableObj *pri,
-                                                const char *name);
 MS_DLL_EXPORT int msOWSPrintMetadata(FILE *stream, hashTableObj *metadata,
                        const char *namespaces, const char *name,
                        int action_if_not_found, const char *format,
