[mapserver-commits] r9252 - trunk/msautotest/gdal
Fri Aug 14 12:08:27 EDT 2009
Author: warmerdam
Date: 2009-08-14 12:08:26 -0400 (Fri, 14 Aug 2009)
New Revision: 9252
   trunk/msautotest/gdal/average_rgb.map
   trunk/msautotest/gdal/bilinear_float.map
   trunk/msautotest/gdal/ows_extent.map
   trunk/msautotest/gdal/wld_upsidedown.map
add some missing REQUIRES directives
Modified: trunk/msautotest/gdal/average_rgb.map
--- trunk/msautotest/gdal/average_rgb.map	2009-08-13 13:47:19 UTC (rev 9251)
+++ trunk/msautotest/gdal/average_rgb.map	2009-08-14 16:08:26 UTC (rev 9252)
@@ -2,6 +2,8 @@
 # Test averaged resampling.  Results currently depend on the 2x oversampling
 # for mapresample.c.
+# REQUIRES: SUPPORTS=PROJ
 MAP
 NAME TEST
Modified: trunk/msautotest/gdal/bilinear_float.map
--- trunk/msautotest/gdal/bilinear_float.map	2009-08-13 13:47:19 UTC (rev 9251)
+++ trunk/msautotest/gdal/bilinear_float.map	2009-08-14 16:08:26 UTC (rev 9252)
@@ -1,6 +1,7 @@
 # Test bilinear resampling on floating point "raw" data format.
 MAP
 NAME TEST
Modified: trunk/msautotest/gdal/ows_extent.map
--- trunk/msautotest/gdal/ows_extent.map	2009-08-13 13:47:19 UTC (rev 9251)
+++ trunk/msautotest/gdal/ows_extent.map	2009-08-14 16:08:26 UTC (rev 9252)
@@ -1,6 +1,8 @@
 # Tests support for getting image extents from OWS extents metadata.
+# REQUIRES: SUPPORTS=WMS_SERVER
 MAP
 NAME TEST
Modified: trunk/msautotest/gdal/wld_upsidedown.map
--- trunk/msautotest/gdal/wld_upsidedown.map	2009-08-13 13:47:19 UTC (rev 9251)
+++ trunk/msautotest/gdal/wld_upsidedown.map	2009-08-14 16:08:26 UTC (rev 9252)
@@ -1,6 +1,8 @@
 # Tests support for upside-down images (like bug 1904).
 MAP
 NAME TEST
