[mapserver-commits] r9255 - trunk/docs/en/mapfile
Fri Aug 14 13:16:26 EDT 2009
Author: warmerdam
Date: 2009-08-14 13:16:26 -0400 (Fri, 14 Aug 2009)
New Revision: 9255
   trunk/docs/en/mapfile/map.txt
removed the non-existant MS_PROJ_LIB config var (#3094)
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt	2009-08-14 17:12:55 UTC (rev 9254)
+++ trunk/docs/en/mapfile/map.txt	2009-08-14 17:16:26 UTC (rev 9255)
@@ -53,10 +53,6 @@
     MS_NONSQUARE [yes|no]
        The CONFIG parameter can be used to allow non-square WMS requests.
-    MS_PROJ_LIB [path]
-       The CONFIG parameter can be used to define the location of your EPSG
-       files. For more info see the 'PROJ_LIB' parameter below.
     ON_MISSING_DATA [FAIL|LOG|IGNORE]
        The CONFIG parameter can be used to tell MapServer how to handle
        missing data in tile indexes (as of MapServer 5.3-dev, r8015). Previous
