[mapserver-commits] r9257 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sun Aug 16 23:26:37 EDT 2009
Author: sdlime
Date: 2009-08-16 23:26:36 -0400 (Sun, 16 Aug 2009)
New Revision: 9257
trunk/mapserver/mapdraw.c
trunk/mapserver/mapgml.c
trunk/mapserver/mapquery.c
trunk/mapserver/maptemplate.c
trunk/mapserver/mapwms.c
Core plumbing for RFC 52 put in place. Query maps are broken for certain types and I didn't replace code in the OGC filter support nor the SOS support as yet.
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c 2009-08-16 15:55:09 UTC (rev 9256)
+++ trunk/mapserver/mapdraw.c 2009-08-17 03:26:36 UTC (rev 9257)
@@ -1121,7 +1121,7 @@
int *mindistancebuffer = NULL;
if(!layer->resultcache || map->querymap.style == MS_NORMAL)
- return(msDrawLayer(map, layer, image));
+ return(msDrawLayer(map, layer, image)); /* FIX ME! */
if(!layer->data && !layer->tileindex && !layer->connection && !layer->features)
return(MS_SUCCESS); /* no data associated with this layer, not an error since layer may be used as a template from MapScript */
@@ -1133,8 +1133,7 @@
return MS_FAILURE;
- if(map->querymap.style == MS_HILITE) { /* first, draw normally, but don't return */
+ if(map->querymap.style == MS_HILITE) { /* first, draw normally, but don't return (FIX ME!) */
status = msDrawLayer(map, layer, image);
if(status != MS_SUCCESS) return(MS_FAILURE); /* oops */
@@ -1200,21 +1199,10 @@
- /* open this layer */
- status = msLayerOpen(layer);
- if(status != MS_SUCCESS) {
- msFree(colorbuffer);
- msFree(mindistancebuffer);
- return(MS_FAILURE);
+ ** Layer was opened as part of the query process, msLayerWhichItems() has also been run, shapes have been classified - start processing!
- /* build item list */
- status = msLayerWhichItems(layer, MS_FALSE, NULL); /* FIX: results have already been classified (this may change) */
#ifdef USE_AGG
if(MS_RENDERER_AGG(map->outputformat))
msAlphaGD2AGG(image);
@@ -1223,7 +1211,7 @@
msInitShape(&shape);
for(i=0; i<layer->resultcache->numresults; i++) {
- status = msLayerGetShape(layer, &shape, layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+ status = msLayerResultsGetShape(layer, &shape, layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
@@ -1320,7 +1308,7 @@
- msLayerClose(layer);
+ /* msLayerClose(layer); */
return(MS_SUCCESS);
Modified: trunk/mapserver/mapgml.c
--- trunk/mapserver/mapgml.c 2009-08-16 15:55:09 UTC (rev 9256)
+++ trunk/mapserver/mapgml.c 2009-08-17 03:26:36 UTC (rev 9257)
@@ -1261,14 +1261,6 @@
msOWSPrintValidateMetadata(stream, &(lp->metadata), namespaces, "layername", OWS_NOERR, "\t<%s>\n", value);
msFree(value);
- /* actually open the layer */
- status = msLayerOpen(lp);
- if(status != MS_SUCCESS) return(status);
- /* retrieve all the item names */
- status = msLayerGetItems(lp);
/* populate item and group metadata structures (TODO: test for NULLs here, shouldn't happen) */
itemList = msGMLGetItems(lp, "G");
constantList = msGMLGetConstants(lp, "G");
@@ -1276,7 +1268,7 @@
geometryList = msGMLGetGeometries(lp, "G");
for(j=0; j<lp->resultcache->numresults; j++) {
- status = msLayerGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+ status = msLayerResultsGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
#ifdef USE_PROJ
@@ -1351,7 +1343,7 @@
msGMLFreeItems(itemList);
msGMLFreeGeometries(geometryList);
- msLayerClose(lp);
+ /* msLayerClose(lp); */
} /* next layer */
@@ -1408,14 +1400,6 @@
const char *value;
int featureIdIndex=-1; /* no feature id */
- /* retrieve all the item names. (Note : there might be no attributes) */
- /* if(status != MS_SUCCESS) return(status); */
/* setup namespace, a layer can override the default */
namespace_prefix = (char*) msOWSLookupMetadata(&(lp->metadata), "OFG", "namespace_prefix");
if(!namespace_prefix) namespace_prefix = default_namespace_prefix;
@@ -1448,7 +1432,7 @@
return(status);
@@ -1525,7 +1509,7 @@
- msLayerClose(lp);
if (maxfeatures > 0 && features == maxfeatures)
Modified: trunk/mapserver/mapquery.c
--- trunk/mapserver/mapquery.c 2009-08-16 15:55:09 UTC (rev 9256)
+++ trunk/mapserver/mapquery.c 2009-08-17 03:26:36 UTC (rev 9257)
@@ -196,7 +196,7 @@
+ /* build item list, we want *all* items */
status = msLayerWhichItems(lp, MS_TRUE, NULL);
@@ -207,6 +207,7 @@
lp->resultcache->bounds.minx = lp->resultcache->bounds.miny = lp->resultcache->bounds.maxx = lp->resultcache->bounds.maxy = -1;
+ /* todo: will this work with the pseudo single pass query */
status = msLayerGetShape(lp, &shape, tileindex, shapeindex);
msSetError(MS_NOTFOUND, "Not valid record request.", "msQueryByIndex()");
@@ -217,11 +218,13 @@
if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
msSetError(MS_NOTFOUND, "Shape %d not valid against layer classification.", "msQueryByIndex()", shapeindex);
msFreeShape(&shape);
+ msLayerClose(lp);
return(MS_FAILURE);
if(!(lp->template) && !(lp->class[shape.classindex]->template)) { /* no valid template */
+ msLayerClose(lp);
msSetError(MS_NOTFOUND, "Shape does not have a valid template, no way to present results.", "msQueryByIndex()");
return(MS_FAILURE);
@@ -233,7 +236,6 @@
msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
- msLayerClose(lp);
return(MS_SUCCESS);
@@ -335,20 +337,18 @@
- /* Manually reset the filter */
- msRestoreOldFilter(lp,old_filtertype,old_filteritem,old_filterstring);
+ msRestoreOldFilter(lp, old_filtertype, old_filteritem, old_filterstring); /* manually reset the filter */
+ return(MS_FAILURE);
- /* identify target shapes */
+ /* identify candidate shapes */
searchrect = map->extent;
#ifdef USE_PROJ
if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
@@ -359,14 +359,12 @@
status = msLayerWhichShapes(lp, searchrect);
if(status == MS_DONE) { /* no overlap */
msLayerClose(lp);
msSetError(MS_NOTFOUND, "No matching record(s) found, layer and area of interest do not overlap.", "msQueryByAttributes()");
return(MS_FAILURE);
} else if(status != MS_SUCCESS) {
msLayerClose(lp);
return(MS_FAILURE);
@@ -379,11 +377,11 @@
nclasses = 0;
classgroup = NULL;
if (lp->classgroup && lp->numclasses > 0)
- classgroup = msAllocateValidClassGroups(lp, &nclasses);
+ classgroup = msAllocateValidClassGroups(lp, &nclasses);
while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
- shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, classgroup, nclasses );
+ shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, classgroup, nclasses);
continue;
@@ -419,21 +417,18 @@
if (classgroup)
msFree(classgroup);
- if(status != MS_DONE){
+ if(status != MS_DONE) {
+ msLayerClose(lp);
- msLayerClose(lp);
- /* was anything found? */
+ /* was anything found? (if yes, don't close the layer) */
if(lp->resultcache && lp->resultcache->numresults > 0)
return(MS_SUCCESS);
+ msLayerClose(lp);
msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByAttributes()");
return(MS_FAILURE);
@@ -501,11 +496,11 @@
searchrect = rect;
#ifdef USE_PROJ
@@ -536,13 +531,13 @@
- msFreeShape(&shape);
- continue;
+ msFreeShape(&shape);
+ continue;
- continue;
+ continue;
#ifdef USE_PROJ
@@ -553,7 +548,7 @@
#endif
if(msRectContained(&shape.bounds, &rect) == MS_TRUE) { /* if the whole shape is in, don't intersect */
- status = MS_TRUE;
+ status = MS_TRUE;
} else {
switch(shape.type) { /* make sure shape actually intersects the rect (ADD FUNCTIONS SPECIFIC TO RECTOBJ) */
case MS_SHAPE_POINT:
@@ -587,7 +582,7 @@
if(status != MS_DONE) return(MS_FAILURE);
- msLayerClose(lp);
+ if(lp->resultcache->numresults == 0) msLayerClose(lp); /* no need to keep the layer open */
} /* next layer */
msFreeShape(&searchshape);
@@ -625,12 +620,9 @@
int nclasses = 0;
int *classgroup = NULL;
- msInitShape(&shape);
- msInitShape(&selectshape);
+ if(map->debug)
+ msDebug("in msQueryByFeatures()\n");
- if( map->debug )
- msDebug( "in msQueryByFeatures()\n" );
/* is the selection layer valid and has it been queried */
if(slayer < 0 || slayer >= map->numlayers) {
msSetError(MS_QUERYERR, "Invalid selection layer index.", "msQueryByFeatures()");
@@ -651,9 +643,13 @@
else
start = stop = qlayer;
- status = msLayerOpen(slp);
- if(status != MS_SUCCESS) return(MS_FAILURE);
+ /* selection layers should already be open */
+ /* status = msLayerOpen(slp);
+ if(status != MS_SUCCESS) return(MS_FAILURE); */
+ msInitShape(&shape); /* initialize a few things */
+ msInitShape(&selectshape);
for(l=start; l>=stop; l--) {
if(l == slayer) continue; /* skip the selection layer */
@@ -672,7 +668,7 @@
if(!msIsLayerQueryable(lp)) continue;
if(lp->status == MS_OFF) continue;
if(map->scaledenom > 0) {
if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom)) continue;
if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom)) continue;
@@ -683,8 +679,7 @@
if((lp->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < lp->mingeowidth)) continue;
- /* Get the layer tolerance
- default is 3 for point and line layers, 0 for others */
+ /* Get the layer tolerance default is 3 for point and line layers, 0 for others */
if(lp->tolerance == -1) {
if(lp->type == MS_LAYER_POINT || lp->type == MS_LAYER_LINE)
layer_tolerance = 3;
@@ -702,14 +697,14 @@
/* for each selection shape */
for(i=0; i<slp->resultcache->numresults; i++) {
- status = msLayerGetShape(slp, &selectshape, slp->resultcache->results[i].tileindex, slp->resultcache->results[i].shapeindex);
+ status = msLayerResultsGetShape(slp, &selectshape, slp->resultcache->results[i].tileindex, slp->resultcache->results[i].shapeindex);
msLayerClose(lp);
msLayerClose(slp);
@@ -879,17 +874,13 @@
msFreeShape(&selectshape);
} /* next selection shape */
- msLayerClose(lp);
} /* next layer */
- msLayerClose(slp);
- if(GET_LAYER(map, l)->resultcache && GET_LAYER(map, l)->resultcache->numresults > 0)
- return(MS_SUCCESS);
+ if(GET_LAYER(map, l)->resultcache && GET_LAYER(map, l)->resultcache->numresults > 0) return(MS_SUCCESS);
msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByFeatures()");
@@ -962,21 +953,19 @@
/* Raster layers are handled specially. */
if( lp->type == MS_LAYER_RASTER ) {
- if( msRasterQueryByPoint( map, lp, mode, p, buffer )
- == MS_FAILURE )
- return MS_FAILURE;
- continue;
+ if( msRasterQueryByPoint( map, lp, mode, p, buffer ) == MS_FAILURE )
+ return MS_FAILURE;
+ continue;
- if(lp->tolerance == -1)
- if(lp->type == MS_LAYER_POINT || lp->type == MS_LAYER_LINE)
- layer_tolerance = 3;
- else
- layer_tolerance = 0;
- else
- layer_tolerance = lp->tolerance;
+ if(lp->tolerance == -1) {
+ if(lp->type == MS_LAYER_POINT || lp->type == MS_LAYER_LINE)
+ layer_tolerance = 3;
+ else
+ layer_tolerance = 0;
+ } else
+ layer_tolerance = lp->tolerance;
if(buffer <= 0) { /* use layer tolerance */
if(lp->toleranceunits == MS_PIXELS)
@@ -995,7 +984,7 @@
@@ -1064,11 +1053,10 @@
- if (mode == MS_MULTIPLE && maxresults > 0 && lp->resultcache->numresults == maxresults) {
- status = MS_DONE; /* got enough results for this layer */
- break;
+ if(mode == MS_MULTIPLE && maxresults > 0 && lp->resultcache->numresults == maxresults) {
+ status = MS_DONE; /* got enough results for this layer */
+ break;
} /* next shape */
if (classgroup)
@@ -1076,7 +1064,7 @@
- msLayerClose(lp);
if((lp->resultcache->numresults > 0) && (mode == MS_SINGLE) && (maxresults == 0))
break; /* no need to search any further */
@@ -1147,24 +1135,20 @@
- if( lp->type == MS_LAYER_RASTER )
- if( msRasterQueryByShape( map, lp, selectshape )
- == MS_FAILURE )
- continue;
+ if( lp->type == MS_LAYER_RASTER ) {
+ if( msRasterQueryByShape(map, lp, selectshape) == MS_FAILURE )
+ continue;
- else
- else
+ else
+ } else
tolerance = layer_tolerance * msAdjustExtent(&(map->extent), map->width, map->height);
@@ -1175,7 +1159,7 @@
@@ -1275,7 +1259,7 @@
- msLayerClose(lp);
} /* next layer */
@@ -1292,91 +1276,86 @@
/* msQueryByOperator */
-/* query using a shape and a valid operator : all queries are */
+/* query using a shape and a valid operator : all queries are */
/* done using geos. */
-int msQueryByOperator(mapObj *map, int qlayer, shapeObj *selectshape,
- int geos_operator)
+int msQueryByOperator(mapObj *map, int qlayer, shapeObj *selectshape, int geos_operator)
#ifdef USE_GEOS
- int start, stop=0, l;
- shapeObj shape;
- layerObj *lp;
- int status;
- rectObj searchrect;
+ int start, stop=0, l;
+ shapeObj shape;
+ layerObj *lp;
+ int status;
+ rectObj searchrect;
- int nclasses = 0;
- int *classgroup = NULL;
- double dfValue;
+ int nclasses = 0;
+ int *classgroup = NULL;
+ double dfValue;
- /* this should not be a necessary test for uries using geos*/
- if(selectshape->type != MS_SHAPE_POLYGON) {
+ /* this should not be a necessary test for queries using geos */
+ if(selectshape->type != MS_SHAPE_POLYGON) {
msSetError(MS_QUERYERR, "Search shape MUST be a polygon.", "msQueryByShape()");
return(MS_FAILURE);
- if(qlayer < 0 || qlayer >= map->numlayers)
- start = map->numlayers-1;
- else
- start = stop = qlayer;
+ if(qlayer < 0 || qlayer >= map->numlayers)
+ start = map->numlayers-1;
+ else
+ start = stop = qlayer;
- msComputeBounds(selectshape); /* make sure an accurate extent exists */
+ msComputeBounds(selectshape); /* make sure an accurate extent exists */
- for(l=start; l>=stop; l--) { /* each layer */
- lp = (GET_LAYER(map, l));
+ for(l=start; l>=stop; l--) { /* each layer */
+ lp = (GET_LAYER(map, l));
- /* conditions may have changed since this layer last drawn, so set
- layer->project true to recheck projection needs (Bug #673) */
- lp->project = MS_TRUE;
+ /* conditions may have changed since this layer last drawn, so set
+ layer->project true to recheck projection needs (Bug #673) */
+ lp->project = MS_TRUE;
- /* free any previous search results, do it now in case one of the next few tests fail */
- if(lp->resultcache) {
- if(lp->resultcache->results) free(lp->resultcache->results);
- free(lp->resultcache);
- lp->resultcache = NULL;
+ /* free any previous search results, do it now in case one of the next few tests fail */
+ if(lp->resultcache) {
+ if(lp->resultcache->results) free(lp->resultcache->results);
+ free(lp->resultcache);
+ lp->resultcache = NULL;
- if(!msIsLayerQueryable(lp)) continue;
- if(lp->status == MS_OFF) continue;
+ if(!msIsLayerQueryable(lp)) continue;
+ if(lp->status == MS_OFF) continue;
- if(map->scaledenom > 0) {
- if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom)) continue;
- if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom)) continue;
+ if(map->scaledenom > 0) {
+ if((lp->maxscaledenom > 0) && (map->scaledenom > lp->maxscaledenom)) continue;
+ if((lp->minscaledenom > 0) && (map->scaledenom <= lp->minscaledenom)) continue;
- if (lp->maxscaledenom <= 0 && lp->minscaledenom <= 0) {
- if((lp->maxgeowidth > 0) && ((map->extent.maxx - map->extent.minx) > lp->maxgeowidth)) continue;
- if((lp->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < lp->mingeowidth)) continue;
+ if (lp->maxscaledenom <= 0 && lp->minscaledenom <= 0) {
+ if((lp->maxgeowidth > 0) && ((map->extent.maxx - map->extent.minx) > lp->maxgeowidth)) continue;
+ if((lp->mingeowidth > 0) && ((map->extent.maxx - map->extent.minx) < lp->mingeowidth)) continue;
- /* Raster layers are handled specially. */
- == MS_FAILURE )
- continue;
+ /* Raster layers are handled specially. */
+ continue;
+ /* open this layer */
+ status = msLayerOpen(lp);
- status = msLayerWhichItems(lp, MS_TRUE, NULL);
+ status = msLayerWhichItems(lp, MS_TRUE, NULL);
-/* identify target shapes */
- searchrect.minx = map->extent.minx;
- searchrect.miny = map->extent.miny;
- searchrect.maxx = map->extent.maxx;
- searchrect.maxy = map->extent.maxy;
+ /* identify target shapes */
+ searchrect.minx = map->extent.minx;
+ searchrect.miny = map->extent.miny;
+ searchrect.maxx = map->extent.maxx;
+ searchrect.maxy = map->extent.maxy;
#ifdef USE_PROJ
@@ -1393,139 +1372,135 @@
return(MS_FAILURE);
- lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /* allocate and initialize the result cache */
- lp->resultcache->results = NULL;
- lp->resultcache->numresults = lp->resultcache->cachesize = 0;
- lp->resultcache->bounds.minx = lp->resultcache->bounds.miny = lp->resultcache->bounds.maxx = lp->resultcache->bounds.maxy = -1;
+ lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /* allocate and initialize the result cache */
+ lp->resultcache->results = NULL;
+ lp->resultcache->numresults = lp->resultcache->cachesize = 0;
+ lp->resultcache->bounds.minx = lp->resultcache->bounds.miny = lp->resultcache->bounds.maxx = lp->resultcache->bounds.maxy = -1;
- classgroup = NULL;
- if (lp->classgroup && lp->numclasses > 0)
+ classgroup = NULL;
+ if (lp->classgroup && lp->numclasses > 0)
- while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
+ while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
- shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, classgroup, nclasses);
- if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
- continue;
+ if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
+ continue;
- if(!(lp->template) && !(lp->class[shape.classindex]->template)) { /* no valid template */
- continue;
+ if(!(lp->template) && !(lp->class[shape.classindex]->template)) { /* no valid template */
+ continue;
#ifdef USE_PROJ
- if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
- msProjectShape(&(lp->projection), &(map->projection), &shape);
- else
- lp->project = MS_FALSE;
+ if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
+ msProjectShape(&(lp->projection), &(map->projection), &shape);
+ else
+ lp->project = MS_FALSE;
#endif
- switch(geos_operator)
- case MS_GEOS_EQUALS:
- status = msGEOSEquals(&shape, selectshape);
- if (status != MS_TRUE && status != MS_FALSE)
- status = MS_FALSE;
- break;
- case MS_GEOS_DISJOINT:
- status = msGEOSDisjoint(&shape, selectshape);
- break;
+ switch(geos_operator)
+ case MS_GEOS_EQUALS:
+ status = msGEOSEquals(&shape, selectshape);
+ if (status != MS_TRUE && status != MS_FALSE)
+ status = MS_FALSE;
+ break;
- case MS_GEOS_TOUCHES:
- status = msGEOSTouches(&shape, selectshape);
- break;
+ case MS_GEOS_DISJOINT:
+ status = msGEOSDisjoint(&shape, selectshape);
+ break;
- case MS_GEOS_OVERLAPS:
- status = msGEOSOverlaps(&shape, selectshape);
- break;
+ case MS_GEOS_TOUCHES:
+ status = msGEOSTouches(&shape, selectshape);
+ break;
- case MS_GEOS_CROSSES:
- status = msGEOSCrosses(&shape, selectshape);
- break;
- case MS_GEOS_INTERSECTS:
- status = msGEOSIntersects(&shape, selectshape);
- break;
+ case MS_GEOS_OVERLAPS:
+ status = msGEOSOverlaps(&shape, selectshape);
+ break;
- case MS_GEOS_WITHIN:
- status = msGEOSWithin(&shape, selectshape);
- break;
- case MS_GEOS_CONTAINS:
- status = msGEOSContains(selectshape, &shape);
- break;
+ case MS_GEOS_CROSSES:
+ status = msGEOSCrosses(&shape, selectshape);
+ break;
- /*beyond is opposite of dwithin use in filter encoding
- see ticket 2105, 2564*/
- case MS_GEOS_BEYOND:
+ case MS_GEOS_INTERSECTS:
+ status = msGEOSIntersects(&shape, selectshape);
status = MS_FALSE;
- dfValue = msGEOSDistance(&shape, selectshape);
- if (dfValue > 0.0)
- status = MS_TRUE;
break;
- /*dwithin is used with filter encoding (#2564)*/
- case MS_GEOS_DWITHIN:
+ case MS_GEOS_WITHIN:
+ status = msGEOSWithin(&shape, selectshape);
status = MS_FALSE;
- if (dfValue == 0.0)
- status = MS_TRUE;
+ break;
+ case MS_GEOS_CONTAINS:
+ status = msGEOSContains(selectshape, &shape);
break;
- default:
- msSetError(MS_QUERYERR, "Unknown GEOS Operator.", "msQueryByOperator()");
+ /* beyond is opposite of dwithin use in filter encoding see tickets #2105 and #2564 */
+ case MS_GEOS_BEYOND:
+ dfValue = msGEOSDistance(&shape, selectshape);
+ if (dfValue > 0.0)
+ status = MS_TRUE;
+ break;
- if(status == MS_TRUE) {
- addResult(lp->resultcache, shape.classindex, shape.index, shape.tileindex);
- if(lp->resultcache->numresults == 1)
- lp->resultcache->bounds = shape.bounds;
- else
- msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
+ /* dwithin is used with filter encoding (#2564) */
+ case MS_GEOS_DWITHIN:
+ if (dfValue == 0.0)
+ status = MS_TRUE;
+ break;
- } /* next shape */
+ default:
+ msSetError(MS_QUERYERR, "Unknown GEOS Operator.", "msQueryByOperator()");
- if(status != MS_DONE) return(MS_FAILURE);
+ if(status == MS_TRUE) {
+ addResult(lp->resultcache, shape.classindex, shape.index, shape.tileindex);
+ if(lp->resultcache->numresults == 1)
+ lp->resultcache->bounds = shape.bounds;
+ else
+ msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
- msLayerClose(lp);
- } /* next layer */
+ } /* next shape */
+ if(status != MS_DONE) return(MS_FAILURE);
+ } /* next layer */
+ /* was anything found? */
+ return(MS_SUCCESS);
- msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByOperator()");
+ msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByOperator()");
#else
msSetError(MS_GEOSERR, "GEOS support is not available.", "msQueryByOperator()");
return(MS_FAILURE);
#endif
/* msGetQueryResultBounds()
@@ -1561,7 +1536,6 @@
return found;
/* msQueryFree()
* Free layer's query results. If qlayer == -1, all layers will be treated.
@@ -1588,4 +1562,3 @@
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c 2009-08-16 15:55:09 UTC (rev 9256)
+++ trunk/mapserver/maptemplate.c 2009-08-17 03:26:36 UTC (rev 9257)
@@ -844,11 +844,11 @@
/* we know the layer has query results or we wouldn't be in this code */
- status = msLayerOpen(layer); /* open the layer */
- if(status != MS_SUCCESS) return status;
+ // status = msLayerOpen(layer); /* open the layer */
+ // if(status != MS_SUCCESS) return status;
- status = msLayerGetItems(layer); /* retrieve all the item names */
+ // status = msLayerGetItems(layer); /* retrieve all the item names */
if(layer->numjoins > 0) { /* initialize necessary JOINs here */
for(j=0; j<layer->numjoins; j++) {
@@ -867,7 +867,7 @@
limit = MS_MIN(limit, layer->resultcache->numresults);
for(i=0; i<limit; i++) {
- status = msLayerGetShape(layer, &(mapserv->resultshape), layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+ status = msLayerResultsGetShape(layer, &(mapserv->resultshape), layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
/* prepare any necessary JOINs here (one-to-one only) */
@@ -3632,13 +3632,13 @@
if(TEMPLATE_TYPE(template) == MS_URL) {
mapserv->resultlayer = lp;
+ // status = msLayerOpen(lp);
- status = msLayerGetItems(lp); /* retrieve all the item names */
+ // status = msLayerGetItems(lp); /* retrieve all the item names */
- status = msLayerGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[0].tileindex, lp->resultcache->results[0].shapeindex);
+ status = msLayerResultsGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[0].tileindex, lp->resultcache->results[0].shapeindex);
if(lp->numjoins > 0) {
@@ -3656,7 +3656,7 @@
msFreeShape(&(mapserv->resultshape));
- msLayerClose(lp);
+ // msLayerClose(lp);
mapserv->resultlayer = NULL;
return MS_SUCCESS;
@@ -3710,11 +3710,11 @@
mapserv->NLR = lp->resultcache->numresults;
- status = msLayerOpen(lp); /* open this layer */
+ // status = msLayerOpen(lp); /* open this layer */
if(lp->numjoins > 0) { /* open any necessary JOINs here */
for(k=0; k<lp->numjoins; k++) {
@@ -3729,7 +3729,7 @@
mapserv->LRN = 1; /* layer result number */
- status = msLayerGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+ status = msLayerResultsGetShape(lp, &(mapserv->resultshape), lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
@@ -3759,7 +3759,7 @@
if(msReturnPage(mapserv, lp->footer, BROWSE, papszBuffer) != MS_SUCCESS) return MS_FAILURE;
- msLayerClose(lp);
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c 2009-08-16 15:55:09 UTC (rev 9256)
+++ trunk/mapserver/mapwms.c 2009-08-17 03:26:36 UTC (rev 9257)
@@ -2614,8 +2614,8 @@
if(lp->status != MS_ON || lp->resultcache==NULL || lp->resultcache->numresults == 0)
continue;
- if(msLayerOpen(lp) != MS_SUCCESS || msLayerGetItems(lp) != MS_SUCCESS)
- return msWMSException(map, nVersion, NULL);
+ /* if(msLayerOpen(lp) != MS_SUCCESS || msLayerGetItems(lp) != MS_SUCCESS)
+ return msWMSException(map, nVersion, NULL); */
/* Use metadata to control which fields to output. We use the same
* metadata names as for GML:
@@ -2664,7 +2664,7 @@
shapeObj shape;
- if (msLayerGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex) != MS_SUCCESS)
+ if (msLayerResultsGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex) != MS_SUCCESS)
msFree(itemvisible);
@@ -2684,7 +2684,7 @@
- msLayerClose(lp);
return numresults;
More information about the mapserver-commits
