[mapserver-commits] r9259 - in trunk/msautotest/gdal: . data expected
Mon Aug 17 15:47:46 EDT 2009
Author: warmerdam
Date: 2009-08-17 15:47:44 -0400 (Mon, 17 Aug 2009)
New Revision: 9259
Added:
   trunk/msautotest/gdal/data/rgb16.tif
   trunk/msautotest/gdal/data/rgb16.wld
   trunk/msautotest/gdal/expected/lut_float.png
   trunk/msautotest/gdal/expected/rgb_16bit.png
   trunk/msautotest/gdal/lut_float.map
   trunk/msautotest/gdal/rgb_16bit.map
added testing for 16bit rgb images, and luts on non-8bit data
Added: trunk/msautotest/gdal/data/rgb16.tif
(Binary files differ)
Property changes on: trunk/msautotest/gdal/data/rgb16.tif
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/msautotest/gdal/data/rgb16.wld
--- trunk/msautotest/gdal/data/rgb16.wld	                        (rev 0)
+++ trunk/msautotest/gdal/data/rgb16.wld	2009-08-17 19:47:44 UTC (rev 9259)
@@ -0,0 +1,6 @@
+10
+0
+0
+-10
+5
+295
Added: trunk/msautotest/gdal/expected/lut_float.png
Property changes on: trunk/msautotest/gdal/expected/lut_float.png
Added: trunk/msautotest/gdal/expected/rgb_16bit.png
Property changes on: trunk/msautotest/gdal/expected/rgb_16bit.png
Added: trunk/msautotest/gdal/lut_float.map
--- trunk/msautotest/gdal/lut_float.map	                        (rev 0)
+++ trunk/msautotest/gdal/lut_float.map	2009-08-17 19:47:44 UTC (rev 9259)
@@ -0,0 +1,23 @@
+# Test an inline curve on a one band floating point file.   The LUT is
+# applied *after* scaling to 8bit.
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+EXTENT 0.5 0.5 399.5 299.5
+IMAGECOLOR 255 255 0
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS default
+  DATA data/float.tif
+  PROCESSING "SCALE=0,60"
+  PROCESSING "LUT_1=0:0,127:255"
+END
+END # of map file
Added: trunk/msautotest/gdal/rgb_16bit.map
--- trunk/msautotest/gdal/rgb_16bit.map	                        (rev 0)
+++ trunk/msautotest/gdal/rgb_16bit.map	2009-08-17 19:47:44 UTC (rev 9259)
@@ -0,0 +1,29 @@
+# Test a multiband scaled image (16bit).
+MAP
+NAME TEST
+STATUS ON
+SIZE 400 300
+OUTPUTFORMAT
+  NAME png24_t
+  DRIVER "GDAL/PNG"
+  IMAGEMODE RGB
+  TRANSPARENT OFF
+END
+LAYER
+  NAME rgb
+  TYPE raster
+  STATUS default
+  DATA data/rgb16.tif
+  OFFSITE 111 222 111
+  PROCESSING "SCALE=200,900"
+END
+END # of map file
