[mapserver-commits] r9272 - in trunk/docs: de/ogc en/ogc
Tue Aug 25 18:01:15 EDT 2009
Author: tomkralidis
Date: 2009-08-25 18:01:14 -0400 (Tue, 25 Aug 2009)
New Revision: 9272
   trunk/docs/de/ogc/mapcontext.txt
   trunk/docs/de/ogc/wfs_server.txt
   trunk/docs/de/ogc/wms_client.txt
   trunk/docs/de/ogc/wms_server.txt
   trunk/docs/en/ogc/mapcontext.txt
   trunk/docs/en/ogc/wfs_server.txt
   trunk/docs/en/ogc/wms_client.txt
   trunk/docs/en/ogc/wms_server.txt
update various links
Modified: trunk/docs/de/ogc/mapcontext.txt
--- trunk/docs/de/ogc/mapcontext.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/de/ogc/mapcontext.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -85,7 +85,7 @@
 - *ows_schemas_location* : Location of XML schema document. Default is
-  http://schemas.opengeospatial.net. See http://ogc.dmsolutions.ca for an example
+  http://schemas.opengis.net. See http://ogc.dmsolutions.ca for an example
   of a valid schema tree.
 - *wms_abstract* : A blurb of text providing more information about the WMS server.
Modified: trunk/docs/de/ogc/wfs_server.txt
--- trunk/docs/de/ogc/wfs_server.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/de/ogc/wfs_server.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -299,7 +299,7 @@
   this is because all OGC Web Services (OWS) use the same metadata) Root of the
   web tree where the family of OGC WFS XMLSchema files are located. This must be a
   valid URL where the actual .xsd files are located if you want your WFS output to
-  validate in a validating XML parser. Default is http://schemas.opengeospatial.net.
+  validate in a validating XML parser. Default is http://schemas.opengis.net.
   See http://ogc.dmsolutions.ca for an example of a valid schema tree.
 **wfs_abstract**
Modified: trunk/docs/de/ogc/wms_client.txt
--- trunk/docs/de/ogc/wms_client.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/de/ogc/wms_client.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -308,7 +308,7 @@
     Tue Jan 17 18:05:13 2006 - msDrawWMSLayerLow(): WMS server error. WMS GetMap
     request got XML exception for layer 'prov_bound': <?xml version='1.0'
     encoding="ISO-8859-1" standalone="no" ?><!DOCTYPE ServiceExceptionReport
-    SYSTEM "http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
+    SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
     <ServiceExceptionReport version="1.1.1"><ServiceException code="LayerNotDefined">
     msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
     </ServiceException>
Modified: trunk/docs/de/ogc/wms_server.txt
--- trunk/docs/de/ogc/wms_server.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/de/ogc/wms_server.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -688,7 +688,7 @@
   is because all OGC Web Services (OWS) use the same metadata) Root of the web tree
   where the family of OGC WMS XMLSchema files are located. This must be a valid URL
   where the actual .xsd files are located if you want your WMS output to validate in
-  a validating XML parser. Default is http://schemas.opengeospatial.net. See
+  a validating XML parser. Default is http://schemas.opengis.net. See
 **wms_abstract**
Modified: trunk/docs/en/ogc/mapcontext.txt
--- trunk/docs/en/ogc/mapcontext.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/en/ogc/mapcontext.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -85,7 +85,7 @@
Modified: trunk/docs/en/ogc/wfs_server.txt
--- trunk/docs/en/ogc/wfs_server.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/en/ogc/wfs_server.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -299,7 +299,7 @@
 **wfs_abstract**
@@ -531,8 +531,8 @@
   of the same geometry type (point, line, polygon). This works fine for shapefiles,
   but some data source formats supported by MapServer allow mixed geometry
   types in a single layer and this goes against the WFS spec. Suggestions on
-  how to handle this are welcome (send suggestions to the MapServer-dev list,
-  which you can join at http://lists.umn.edu/archives/mapserver-dev.html).
+  how to handle this are welcome (send suggestions to the
+  :ref:`mapserver-dev mailing list <lists>`.
 .. #### rST Link Section ####
Modified: trunk/docs/en/ogc/wms_client.txt
--- trunk/docs/en/ogc/wms_client.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/en/ogc/wms_client.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -308,7 +308,7 @@
     </ServiceException>
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2009-08-25 19:46:48 UTC (rev 9271)
+++ trunk/docs/en/ogc/wms_server.txt	2009-08-25 22:01:14 UTC (rev 9272)
@@ -695,7 +695,7 @@
 **wms_abstract**
