[mapserver-commits] r9283 - branches/branch-5-4/mapserver
trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Mon Aug 31 13:13:45 EDT 2009
Author: tomkralidis
Date: 2009-08-31 13:13:45 -0400 (Mon, 31 Aug 2009)
New Revision: 9283
branches/branch-5-4/mapserver/HISTORY.TXT
branches/branch-5-4/mapserver/mapcontext.c
trunk/mapserver/HISTORY.TXT
trunk/mapserver/mapcontext.c
Fix WMC XML output when Dimension is used (#3110)
Modified: branches/branch-5-4/mapserver/HISTORY.TXT
--- branches/branch-5-4/mapserver/HISTORY.TXT 2009-08-31 14:14:00 UTC (rev 9282)
+++ branches/branch-5-4/mapserver/HISTORY.TXT 2009-08-31 17:13:45 UTC (rev 9283)
@@ -14,6 +14,8 @@
Current Version:
+- Fix WMC XML output when Dimension is used (#3110)
- Fix output for valid WCS 1.1 XML (#3086)
- Avoid double free with postgresql joins. (#2936)
Modified: branches/branch-5-4/mapserver/mapcontext.c
--- branches/branch-5-4/mapserver/mapcontext.c 2009-08-31 14:14:00 UTC (rev 9282)
+++ branches/branch-5-4/mapserver/mapcontext.c 2009-08-31 17:13:45 UTC (rev 9283)
@@ -2157,7 +2157,10 @@
if(bDimensionList)
msIO_fprintf( stream, " </DimensionList>\n");
+ bDimensionList = 0;
msIO_fprintf(stream, " </Layer>\n");
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT 2009-08-31 14:14:00 UTC (rev 9282)
+++ trunk/mapserver/HISTORY.TXT 2009-08-31 17:13:45 UTC (rev 9283)
@@ -14,6 +14,8 @@
Current Version (SVN trunk):
- Enable LOAD_WHOLE_IMAGE processing option by default when rendering
WMS client layer images (#3111).
Modified: trunk/mapserver/mapcontext.c
--- trunk/mapserver/mapcontext.c 2009-08-31 14:14:00 UTC (rev 9282)
+++ trunk/mapserver/mapcontext.c 2009-08-31 17:13:45 UTC (rev 9283)
if(bDimensionList)
More information about the mapserver-commits
