[mapserver-commits] r9589 - trunk/mapserver
Mon Dec 7 12:18:29 EST 2009
Author: aboudreault
Date: 2009-12-07 12:18:29 -0500 (Mon, 07 Dec 2009)
New Revision: 9589
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapcrypto.c
   trunk/mapserver/mapjoin.c
   trunk/mapserver/mappostgresql.c
Fixed joins do not accept crypted passwords (#2912)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-12-07 17:00:41 UTC (rev 9588)
+++ trunk/mapserver/HISTORY.TXT	2009-12-07 17:18:29 UTC (rev 9589)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Fixed joins do not accept crypted passwords (#2912)
 - Fixed HTML legend image samples truncated (#2636)
 - WMS GetFeatureInfo should respect the scale like GetMap does (#842)
Modified: trunk/mapserver/mapcrypto.c
--- trunk/mapserver/mapcrypto.c	2009-12-07 17:00:41 UTC (rev 9588)
+++ trunk/mapserver/mapcrypto.c	2009-12-07 17:18:29 UTC (rev 9589)
@@ -487,9 +487,10 @@
                 pszTmp[pszEnd-pszStart] = '\0';
                 msDecryptStringWithKey(map->encryption_key, pszTmp, out);
                 out += strlen(out);
                 in = pszEnd+1;
+                free(pszTmp);
             else
Modified: trunk/mapserver/mapjoin.c
--- trunk/mapserver/mapjoin.c	2009-12-07 17:00:41 UTC (rev 9588)
+++ trunk/mapserver/mapjoin.c	2009-12-07 17:18:29 UTC (rev 9589)
@@ -1,5 +1,5 @@
- * $Id:$
+ * $Id$
  * Project:  MapServer
  * Purpose:  Implements MapServer joins.
@@ -549,6 +549,7 @@
 #else
   int i;
   char qbuf[4000];
+  char *conn_decrypted;
   msMySQLJoinInfo *joininfo;
   MYDEBUG if (setvbuf(stdout, NULL, _IONBF , 0)){printf("Whoops...");};
@@ -576,11 +577,20 @@
         return(MS_FAILURE);
+    conn_decrypted = msDecryptStringTokens(layer->map, join->connection);
+    if (conn_decrypted == NULL) {
+      msSetError(MS_QUERYERR, "Error parsing MYSQL JOIN: unable to decrypt CONNECTION statement.",
+                 "msMySQLJoinConnect()");
+      return(MS_FAILURE);
     delim = strdup(":");
-    DB_HOST = strdup(strtok(join->connection, delim));
+    DB_HOST = strdup(strtok(conn_decrypted, delim));
     DB_USER = strdup(strtok(NULL, delim));
     DB_PASSWD = strdup(strtok(NULL, delim));
     DB_DATABASE = strdup(strtok(NULL, delim));
+    free(conn_decrypted);
     if (DB_HOST == NULL || DB_USER == NULL || DB_PASSWD == NULL || DB_DATABASE == NULL)
Modified: trunk/mapserver/mappostgresql.c
--- trunk/mapserver/mappostgresql.c	2009-12-07 17:00:41 UTC (rev 9588)
+++ trunk/mapserver/mappostgresql.c	2009-12-07 17:18:29 UTC (rev 9589)
@@ -74,6 +74,7 @@
 int msPOSTGRESQLJoinConnect(layerObj *layer, joinObj *join) {
     char *maskeddata, *temp, *sql, *column;
     int i, count, test;
     PGresult *query_result;
     msPOSTGRESQLJoinInfo *joininfo;
@@ -117,7 +118,11 @@
     /* Establish database connection */
-    joininfo->conn = PQconnectdb(join->connection);
+    if (conn_decrypted != NULL) {
+      joininfo->conn = PQconnectdb(conn_decrypted);
     if(!joininfo->conn || PQstatus(joininfo->conn) == CONNECTION_BAD) {
         maskeddata = (char *)malloc(strlen(layer->connection) + 1);
         strcpy(maskeddata, join->connection);
