[mapserver-commits] r9600 - trunk/msautotest/wxs
Tue Dec 8 21:15:04 EST 2009
Author: tomkralidis
Date: 2009-12-08 21:15:03 -0500 (Tue, 08 Dec 2009)
New Revision: 9600
   trunk/msautotest/wxs/wfs_misc.map
fix line feeds
Modified: trunk/msautotest/wxs/wfs_misc.map
--- trunk/msautotest/wxs/wfs_misc.map	2009-12-08 02:28:55 UTC (rev 9599)
+++ trunk/msautotest/wxs/wfs_misc.map	2009-12-09 02:15:03 UTC (rev 9600)
@@ -1,181 +1,181 @@
-# Test WFS
-# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WFS GEOS
-# wfs paging using startIndex
-# RUN_PARMS: wfs_filter_startindex.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=popplace&propertyname=(NAME)&maxfeatures=10&startindex=0" > [RESULT]
-# RUN_PARMS: wfs_filter_startindex2.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=popplace&propertyname=(NAME)&maxfeatures=10&startindex=10" > [RESULT]
-#wfs test valid for 2 type names
-# RUN_PARMS: wfs_getfeature_twotypenames1.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=province,popplace&resulttype=hits" > [RESULT]
-# RUN_PARMS: wfs_getfeature_twotypenames2.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=popplace,province&resulttype=hits" > [RESULT]
-MAP
-NAME WFS_FILTER
-STATUS ON
-SIZE 400 300
-#EXTENT   2018000 -73300 3410396 647400
-#UNITS METERS
-EXTENT -67.5725 42 -58.9275 48.5
-UNITS DD
-IMAGECOLOR 255 255 255
-SHAPEPATH ./data
-SYMBOLSET etc/symbols.sym
-FONTSET etc/fonts.txt
-OUTPUTFORMAT
-  NAME GDPNG
-  DRIVER "GD/PNG"
-  MIMETYPE "image/png"
-  IMAGEMODE RGB
-  EXTENSION "png"
-END
-# Start of web interface definition
-WEB
- IMAGEPATH "/tmp/ms_tmp/"
- IMAGEURL "/ms_tmp/"
-  METADATA
-    "ows_updatesequence"   "123"
-    "wfs_title"		   "Test simple wfs"
-    "wfs_onlineresource"   "http://localhost/path/to/wfs_simple?"
-    "wfs_srs"		   "EPSG:4326 EPSG:4269"
-    "ows_schemas_location" "http://ogc.dmsolutions.ca"
-  END
-END
-PROJECTION
-  "init=epsg:4326"
-END
-# Start of layer definitions
-LAYER
-  NAME province
-  DATA province
-  METADATA
-    "wfs_title"         "province"
-    "wfs_description"   "province"
-    "wfs_result_fields" "NAME_E YEAR_EST AREA_KMSQ"
-    "gml_include_items" "all"
-  END
-  TYPE POINT
-  STATUS ON
-  PROJECTION
-    "init=./data/epsg2:42304"
-  END
-  DUMP TRUE
-  CLASSITEM "Name_e"
-  CLASS
-    NAME "Province"
-    COLOR 200 255 0
-    OUTLINECOLOR 120 120 120
-  END
-END # Layer
-LAYER
-  NAME park
-  DATA park
-  METADATA
-    "wfs_title"             "park"
-    "wfs_version"           "1.0.0"
-    "wfs_description"	    "Parks"
-   END
-  TYPE POLYGON
-  STATUS ON
-  PROJECTION
-  END
-  DUMP TRUE
-  CLASS
-    NAME "Parks"
-    COLOR 200 255 0
-  END
-END # Layer
-LAYER
-  NAME popplace
-  DATA popplace
-  METADATA
-    "wfs_title"         "popplace"
-    "wfs_description"   "Cities"
-    "wfs_result_fields" "NAME"
-   END
-  TYPE POINT
-  STATUS ON
-  PROJECTION
-  END
-  DUMP TRUE
-  LabelItem "Name"
-  CLASSITEM "Capital"
-  CLASS
-    EXPRESSION /./
-    SYMBOL 2
-    SIZE 8
-    NAME "Cities"
-    LABEL
-      COLOR  0 0 0
-      FONT Vera
-      TYPE truetype
-      SIZE 8
-      POSITION AUTO
-      PARTIALS FALSE
-      OUTLINECOLOR 255 255 255
-    END
-    COLOR 0 0 0
-  END
-END # Layer
-LAYER
-  NAME road
-  DATA road
-  METADATA
-    "wfs_title"       "road"
-    "wfs_description" "Roads"
-  END
-  TYPE LINE
-  STATUS ON
-  PROJECTION
-  END
-  DUMP TRUE
-  CLASS
-    NAME "Roads"
-    SYMBOL 0
-    COLOR 220 0 0
-  END
-END # Layer
-END # Map File
+# Test WFS
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WFS GEOS
+# wfs paging using startIndex
+# RUN_PARMS: wfs_filter_startindex.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=popplace&propertyname=(NAME)&maxfeatures=10&startindex=0" > [RESULT]
+# RUN_PARMS: wfs_filter_startindex2.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=popplace&propertyname=(NAME)&maxfeatures=10&startindex=10" > [RESULT]
+#wfs test valid for 2 type names
+# RUN_PARMS: wfs_getfeature_twotypenames1.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=province,popplace&resulttype=hits" > [RESULT]
+# RUN_PARMS: wfs_getfeature_twotypenames2.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=popplace,province&resulttype=hits" > [RESULT]
+MAP
+NAME WFS_FILTER
+STATUS ON
+SIZE 400 300
+#EXTENT   2018000 -73300 3410396 647400
+#UNITS METERS
+EXTENT -67.5725 42 -58.9275 48.5
+UNITS DD
+IMAGECOLOR 255 255 255
+SHAPEPATH ./data
+SYMBOLSET etc/symbols.sym
+FONTSET etc/fonts.txt
+OUTPUTFORMAT
+  NAME GDPNG
+  DRIVER "GD/PNG"
+  MIMETYPE "image/png"
+  IMAGEMODE RGB
+  EXTENSION "png"
+END
+# Start of web interface definition
+WEB
+ IMAGEPATH "/tmp/ms_tmp/"
+ IMAGEURL "/ms_tmp/"
+  METADATA
+    "ows_updatesequence"   "123"
+    "wfs_title"		   "Test simple wfs"
+    "wfs_onlineresource"   "http://localhost/path/to/wfs_simple?"
+    "wfs_srs"		   "EPSG:4326 EPSG:4269"
+    "ows_schemas_location" "http://ogc.dmsolutions.ca"
+  END
+END
+PROJECTION
+  "init=epsg:4326"
+END
+# Start of layer definitions
+LAYER
+  NAME province
+  DATA province
+  METADATA
+    "wfs_title"         "province"
+    "wfs_description"   "province"
+    "wfs_result_fields" "NAME_E YEAR_EST AREA_KMSQ"
+    "gml_include_items" "all"
+  END
+  TYPE POINT
+  STATUS ON
+  PROJECTION
+    "init=./data/epsg2:42304"
+  END
+  DUMP TRUE
+  CLASSITEM "Name_e"
+  CLASS
+    NAME "Province"
+    COLOR 200 255 0
+    OUTLINECOLOR 120 120 120
+  END
+END # Layer
+LAYER
+  NAME park
+  DATA park
+  METADATA
+    "wfs_title"             "park"
+    "wfs_version"           "1.0.0"
+    "wfs_description"	    "Parks"
+   END
+  TYPE POLYGON
+  STATUS ON
+  PROJECTION
+  END
+  DUMP TRUE
+  CLASS
+    NAME "Parks"
+    COLOR 200 255 0
+  END
+END # Layer
+LAYER
+  NAME popplace
+  DATA popplace
+  METADATA
+    "wfs_title"         "popplace"
+    "wfs_description"   "Cities"
+    "wfs_result_fields" "NAME"
+   END
+  TYPE POINT
+  STATUS ON
+  PROJECTION
+  END
+  DUMP TRUE
+  LabelItem "Name"
+  CLASSITEM "Capital"
+  CLASS
+    EXPRESSION /./
+    SYMBOL 2
+    SIZE 8
+    NAME "Cities"
+    LABEL
+      COLOR  0 0 0
+      FONT Vera
+      TYPE truetype
+      SIZE 8
+      POSITION AUTO
+      PARTIALS FALSE
+      OUTLINECOLOR 255 255 255
+    END
+    COLOR 0 0 0
+  END
+END # Layer
+LAYER
+  NAME road
+  DATA road
+  METADATA
+    "wfs_title"       "road"
+    "wfs_description" "Roads"
+  END
+  TYPE LINE
+  STATUS ON
+  PROJECTION
+  END
+  DUMP TRUE
+  CLASS
+    NAME "Roads"
+    SYMBOL 0
+    COLOR 220 0 0
+  END
+END # Layer
+END # Map File
