[mapserver-commits] r9615 - in trunk/docs: de/ogc en/ogc
Fri Dec 11 13:33:40 EST 2009
Author: assefa
Date: 2009-12-11 13:33:39 -0500 (Fri, 11 Dec 2009)
New Revision: 9615
   trunk/docs/de/ogc/sld.txt
   trunk/docs/en/ogc/sld.txt
Indicate MapServer version for a feature
Modified: trunk/docs/de/ogc/sld.txt
--- trunk/docs/de/ogc/sld.txt	2009-12-11 14:37:35 UTC (rev 9614)
+++ trunk/docs/de/ogc/sld.txt	2009-12-11 18:33:39 UTC (rev 9615)
@@ -427,7 +427,7 @@
   Position in MapServer) Displacement (which is translated to Offset) and Angle
   (which is translated to Angle).
-- Angle setting: by default the angle parameter is set to AUTO. For point features,
+- Angle setting (MapServer version >=5.4): by default the angle parameter is set to AUTO. For point features,
   users can use the PointPlacement to alter the value. For line features, the user can
   add a LinePlacement: If an 'empty' LinePlacement is part of the SLD, the angle will be
   set to  FOLLOW, If a LinePlacement contains the PerpendicualarOffset parameter, the
Modified: trunk/docs/en/ogc/sld.txt
--- trunk/docs/en/ogc/sld.txt	2009-12-11 14:37:35 UTC (rev 9614)
+++ trunk/docs/en/ogc/sld.txt	2009-12-11 18:33:39 UTC (rev 9615)
@@ -427,7 +427,7 @@
