[mapserver-commits] r9623 - branches/branch-5-6/mapserver
Fri Dec 18 09:41:16 EST 2009
Author: dmorissette
Date: 2009-12-18 09:41:14 -0500 (Fri, 18 Dec 2009)
New Revision: 9623
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/mapfile.c
Avoid env. var. leak through msEvalRegex() (#2989)
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2009-12-18 14:35:51 UTC (rev 9622)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2009-12-18 14:41:14 UTC (rev 9623)
@@ -12,13 +12,11 @@
 For a complete change history, please see the Subversion log comments.
-Current Version (SVN branch-5-6):
-Version 5.6.0 (2009-12-04):
+Version 5.6.0 (2009-12-18):
+- Fixed potential leak of env. vars through msEvalRegex() (#2989)
 - WFS hits count is incorrect if the request contain 2 layers or more (#3244)
 - Fixed a problem with layer plugin where copyVirtualTable didn't copy
Modified: branches/branch-5-6/mapserver/mapfile.c
--- branches/branch-5-6/mapserver/mapfile.c	2009-12-18 14:35:51 UTC (rev 9622)
+++ branches/branch-5-6/mapserver/mapfile.c	2009-12-18 14:41:14 UTC (rev 9623)
@@ -105,7 +105,7 @@
   if(ms_regexec(&re, s, 0, NULL, 0) != 0) { /* no match */
     ms_regfree(&re);
-    msSetError(MS_REGEXERR, "String (%s) failed expression test.", "msEvalRegex()", s);
+    msSetError(MS_REGEXERR, "String failed expression test.", "msEvalRegex()");
     return(MS_FALSE);
   ms_regfree(&re);
@@ -5172,9 +5172,15 @@
   if(getenv("MS_MAPFILE_PATTERN")) { /* user override */
-    if(msEvalRegex(getenv("MS_MAPFILE_PATTERN"), filename) != MS_TRUE) return(NULL);
+    if(msEvalRegex(getenv("MS_MAPFILE_PATTERN"), filename) != MS_TRUE) {
+      msSetError(MS_REGEXERR, "MS_MAPFILE_PATTERN validation failed." , "msLoadMap()");
+      return(NULL);
   } else { /* check the default */
-    if(msEvalRegex(MS_DEFAULT_MAPFILE_PATTERN, filename) != MS_TRUE) return(NULL);
+    if(msEvalRegex(MS_DEFAULT_MAPFILE_PATTERN, filename) != MS_TRUE) {
+      msSetError(MS_REGEXERR, "MS_DEFAULT_MAPFILE_PATTERN validation failed." , "msLoadMap()");
+      return(NULL);
@@ -5497,11 +5503,17 @@
   ** Check map filename to make sure it's legal
+      return(NULL);
+      return(NULL);
   if((msyyin = fopen(filename,"r")) == NULL) {
     msSetError(MS_IOERR, "(%s)", "msTokenizeMap()", filename);
     return NULL;
