[mapserver-commits] r9642 - in trunk/docs: . en en/images en/mapfile en/mapfile/symbology en/mapscript/php
Tue Dec 29 22:12:28 EST 2009
Author: hobu
Date: 2009-12-29 22:12:27 -0500 (Tue, 29 Dec 2009)
New Revision: 9642
   trunk/docs/conf.py
   trunk/docs/en/images/copyright-image.png
   trunk/docs/en/introduction.txt
   trunk/docs/en/mapfile/label.txt
   trunk/docs/en/mapfile/outputformat.txt
   trunk/docs/en/mapfile/symbology/examples.txt
   trunk/docs/en/mapscript/php/by_example.txt
formatting fixups
Modified: trunk/docs/conf.py
--- trunk/docs/conf.py	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/conf.py	2009-12-30 03:12:27 UTC (rev 9642)
@@ -23,7 +23,7 @@
 # Add any Sphinx extension module names here, as strings. They can be extensions
 # coming with Sphinx (named 'sphinx.ext.*') or your custom ones.
-extensions = ['labels']
+extensions = ['rst2pdf.pdfbuilder']
 # Add any paths that contain templates here, relative to this directory.
 templates_path = ['_templates']
@@ -189,6 +189,37 @@
 #latex_use_modindex = True
+# -- Options for PDF output ---------------------------------------
+    # Grouping the document tree into PDF files. List of tuples
+    # (source start file, target name, title, author).
+pdf_documents = [
+    ('documentation', u'MapServer', u'MapServer Documentation', u'The MapServer Team'),
+# A comma-separated list of custom stylesheets. Example:
+pdf_stylesheets = ['sphinx','kerning','a4']
+# Create a compressed PDF
+# Use True/False or 1/0
+# Example: compressed=True
+#pdf_compressed=False
+# A colon-separated list of folders to search for fonts. Example:
+# pdf_font_path=['/usr/share/fonts', '/usr/share/texmf-dist/fonts/']
+# Language to be used for hyphenation support
+#pdf_language="en_EN"
+# If false, no index is generated.
+#pdf_use_index = True
+# If false, no modindex is generated.
+#pdf_use_modindex = True
+# If false, no coverpage is generated.
+#pdf_use_coverpage = True
 from pygments.lexer import RegexLexer, bygroups,combined, include
 from pygments.token import *
 from pygments import highlight
@@ -226,14 +257,14 @@
             r'LEFT|LINE|LL|LR|MEDIUM|METERS|MILES|MITER|MULTIPLE|NONE|'
             r'NORMAL|OFF|OGR|ON|ONE-TO-ONE|ONE-TO-MANY|ORACLESPATIAL|'
             r'PERCENTAGES|PIXMAP|PIXELS|POINT|POLYGON|POSTGIS|MYGIS|'
-            r'PLUGIN|QUERY|RASTER|RIGHT|ROUNDE|SDE|SELECTED|SIMPLE|SINGLE|'
+            r'PLUGIN|QUERY|RASTER|RIGHT|ROUND|SDE|SELECTED|SIMPLE|SINGLE|'
             r'SMALL|SQUARE|TINY|TRIANGLE|TRUE|TRUETYPE|UC|UL|UR|VECTOR|'
             r'WFS|WMS|ALPHA|'
             r'GIF|JPEG|JPG|PNG|WBMP|SWF|PDF|GTIFF|PC256|RGB|RGBA|INT16|FLOAT32|GD|AGG'
             r')\b')
 keywords = (r'(ALIGN|'
-            r'ALPHACOLOR|ANGLE|ANTIALIAS|BACKGROUNDCOLOR|BACKGROUNDSHADOWCOLOR|'
+            r'ALPHACOLOR|ANGLE|ANTIALIAS|AUTHOR|BACKGROUNDCOLOR|BACKGROUNDSHADOWCOLOR|'
             r'BACKGROUNDSHADOWSIZE|BANDSITEM|BROWSEFORMAT|BUFFER|CHARACTER|CLASS|CLASSITEM|'
             r'CLASSGROUP|COLOR|CONFIG|CONNECTION|CONNECTIONTYPE|DATA|DATAPATTERN|DEBUG|'
             r'DRIVER|DUMP|EMPTY|ENCODING|END|ERROR|EXPRESSION|EXTENT|EXTENSION|FEATURE|'
@@ -280,7 +311,6 @@
 #            (r"""[]{}:(),;[]""", Punctuation),
             # (r'(MAP)\b', Generic.Heading),
             (keywords, Keyword),
-            # (r'(PRIMEM|UNIT|TOWGS84)\b', Keyword.Constant),
             (builtins, Name.Builtin),
             (r'[0-9][0-9]*\.[0-9]+([eE][0-9]+)?[fd]?', Number.Float),
             (r'[0-9]+', Number.Integer),
Modified: trunk/docs/en/images/copyright-image.png
(Binary files differ)
Modified: trunk/docs/en/introduction.txt
--- trunk/docs/en/introduction.txt	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/en/introduction.txt	2009-12-30 03:12:27 UTC (rev 9642)
@@ -335,10 +335,10 @@
 .. code-block:: mapfile
     LAYER
-        NAME bathymetry
+        NAME "bathymetry"
         TYPE RASTER
         STATUS DEFAULT
-        DATA bath_mapserver.tif
+        DATA "bath_mapserver.tif"
     END
 .. seealso::
Modified: trunk/docs/en/mapfile/label.txt
--- trunk/docs/en/mapfile/label.txt	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/en/mapfile/label.txt	2009-12-30 03:12:27 UTC (rev 9642)
@@ -27,7 +27,7 @@
         LABEL
           COLOR  150 150 150
           OUTLINECOLOR 255 255 255
-          FONT sans
+          FONT "sans"
           TYPE truetype
           SIZE 6
           ANGLE [MYANGLE]
@@ -71,7 +71,7 @@
         LABEL
           COLOR  [MYCOLOR]
-          FONT sans
+          FONT "sans"
           TYPE truetype
           SIZE 6
           POSITION AUTO
@@ -151,7 +151,7 @@
         LABEL
           COLOR  150 150 150
           OUTLINECOLOR [MYOUTCOLOR]
-          FONT sans
+          FONT "sans"
           TYPE truetype
           SIZE 6
           POSITION AUTO
@@ -221,7 +221,7 @@
         LABEL
           COLOR  150 150 150
-          FONT sans
+          FONT "sans"
           TYPE truetype
           SIZE [MYSIZE]
           POSITION AUTO
Modified: trunk/docs/en/mapfile/outputformat.txt
--- trunk/docs/en/mapfile/outputformat.txt	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/en/mapfile/outputformat.txt	2009-12-30 03:12:27 UTC (rev 9642)
@@ -17,7 +17,7 @@
     OUTPUTFORMAT
-      NAME aggpng24
+      NAME "aggpng24"
       DRIVER AGG/PNG
       MIMETYPE "image/png"
       IMAGEMODE RGB
Modified: trunk/docs/en/mapfile/symbology/examples.txt
--- trunk/docs/en/mapfile/symbology/examples.txt	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/en/mapfile/symbology/examples.txt	2009-12-30 03:12:27 UTC (rev 9642)
@@ -41,7 +41,7 @@
   SYMBOL
     NAME "natcap"
     TYPE TRUETYPE
-    FONT geo
+    FONT "geo"
     FILLED true
     ANTIALIAS true
     CHARACTER "r"
Modified: trunk/docs/en/mapscript/php/by_example.txt
--- trunk/docs/en/mapscript/php/by_example.txt	2009-12-26 18:22:14 UTC (rev 9641)
+++ trunk/docs/en/mapscript/php/by_example.txt	2009-12-30 03:12:27 UTC (rev 9642)
@@ -148,7 +148,8 @@
 Here's the map file:
+.. code-block:: mapfile
+    :linenos:
         NAME "Europe in purple"
         SIZE 400 400
@@ -205,28 +206,29 @@
 The code looks like this:
+.. code-block:: php
+    :linenos:
-        1 <?php
+        <?php
-        2 dl('php_mapscript.so');
+        dl('php_mapscript.so');
-        3 $map_path="/var/www/html/ms/map_files/";
+        $map_path="/var/www/html/ms/map_files/";
-        4 $map = ms_newMapObj($map_path."europe.map");
-        5 $image=$map->draw();
-        6 $image_url=$image->saveWebImage();
+        $map = ms_newMapObj($map_path."europe.map");
+        $image=$map->draw();
+        $image_url=$image->saveWebImage();
-        7 ?>
-        8  <HTML>
-        9   <HEAD>
-        10      <TITLE>Example 1: Displaying a map</TITLE>
-        11  </HEAD>
-        12  <BODY>
-        13      <IMG SRC=<?php echo $image_url; ?> >
-        14  </BODY>
-        15 </HTML>
+         <HTML>
+          <HEAD>
+              <TITLE>Example 1: Displaying a map</TITLE>
+          </HEAD>
+          <BODY>
+              <IMG SRC=<?php echo $image_url; ?> >
+          </BODY>
+         </HTML>
 The code I will present through the rest of this document will follow the
@@ -299,129 +301,130 @@
 Here I present the new code.
+    :linenos:
-        1 <?php
+        <?php
-        3 // Default values and configuration
+        // Default values and configuration
-        4 $val_zsize=3;
-        5 $check_pan="CHECKED";
-        6 $map_path="/var/www/html/ms/map_files/";
-        7 $map_file="europe.map";
+        $val_zsize=3;
+        $check_pan="CHECKED";
+        $map_file="europe.map";
-        8 $map = ms_newMapObj($map_path.$map_file);
+        $map = ms_newMapObj($map_path.$map_file);
-        9 if ( isset($_POST["mapa_x"]) && isset($_POST["mapa_y"])
-        10      && !isset($_POST["full"]) ) {
+        if ( isset($_POST["mapa_x"]) && isset($_POST["mapa_y"])
+              && !isset($_POST["full"]) ) {
-        11      $extent_to_set = explode(" ",$_POST["extent"]);
+              $extent_to_set = explode(" ",$_POST["extent"]);
-        12      $map->setextent($extent_to_set[0],$extent_to_set[1],
-        13                      $extent_to_set[2],$extent_to_set[3]);
+              $map->setextent($extent_to_set[0],$extent_to_set[1],
+                              $extent_to_set[2],$extent_to_set[3]);
-        14      $my_point = ms_newpointObj();
-        15      $my_point->setXY($_POST["mapa_x"],$_POST["mapa_y"]);
+              $my_point = ms_newpointObj();
+              $my_point->setXY($_POST["mapa_x"],$_POST["mapa_y"]);
-        16      $my_extent = ms_newrectObj();
+              $my_extent = ms_newrectObj();
-        17      $my_extent->setextent($extent_to_set[0],$extent_to_set[1],
-        18                              $extent_to_set[2],$extent_to_set[3]);
+              $my_extent->setextent($extent_to_set[0],$extent_to_set[1],
-        19      $zoom_factor = $_POST["zoom"]*$_POST["zsize"];
-        20      if ($zoom_factor == 0) {
-        21              $zoom_factor = 1;
-        22              $check_pan = "CHECKED";
-        23              $check_zout = "";
-        24              $check_zin = "";
-        25      } else if ($zoom_factor < 0) {
-        26              $check_pan = "";
-        27              $check_zout = "CHECKED";
-        28              $check_zin = "";
-        29      } else {
-        30              $check_pan = "";
-        31              $check_zout = "";
-        32              $check_zin = "CHECKED";
-        33      }
+              $zoom_factor = $_POST["zoom"]*$_POST["zsize"];
+              if ($zoom_factor == 0) {
+                      $zoom_factor = 1;
+                      $check_pan = "CHECKED";
+                      $check_zout = "";
+                      $check_zin = "";
+              } else if ($zoom_factor < 0) {
+                      $check_pan = "";
+                      $check_zout = "CHECKED";
+                      $check_zin = "";
+              } else {
+                      $check_pan = "";
+                      $check_zout = "";
+                      $check_zin = "CHECKED";
-        34      $val_zsize = abs($zoom_factor);
+              $val_zsize = abs($zoom_factor);
-        35      $map->zoompoint($zoom_factor,$my_point,$map->width,$map->height,
-        36                      $my_extent);
+              $map->zoompoint($zoom_factor,$my_point,$map->width,$map->height,
+                              $my_extent);
-        37 }
-        38 $image=$map->draw();
-        39 $image_url=$image->saveWebImage();
-        40 $extent_to_html = $map->extent->minx." ".$map->extent->miny." "
-        41              .$map->extent->maxx." ".$map->extent->maxy;
+         $extent_to_html = $map->extent->minx." ".$map->extent->miny." "
+                      .$map->extent->maxx." ".$map->extent->maxy;
-        42 ?>
-        43 <HTML>
-        44 <HEAD>
-        45 <TITLE>Map 2</TITLE>
-        46 </HEAD>
-        47 <BODY>
-        48 <CENTER>
-        49 <FORM METHOD=POST ACTION=<?php echo $HTTP_SERVER_VARS['PHP_SELF']?>>
-        50 <TABLE>
-        51 <TR>
-        52      <TD>
-        53              <INPUT TYPE=IMAGE NAME="mapa" SRC="<?php echo $image_url?>">
-        54      </TD>
-        55 </TR>
-        56 <TR>
-        57      <TD>
-        58              Pan
-        59      </TD>
-        60      <TD>
-        61              <INPUT TYPE=RADIO NAME="zoom" VALUE=0 <?php echo $check_pan?>>
-        62      </TD>
-        63 </TR>
-        64 <TR>
-        65      <TD>
-        66              Zoom In
-        67      </TD>
-        68      <TD>
-        69              <INPUT TYPE=RADIO NAME="zoom" VALUE=1 <?php echo $check_zin?>>
-        70      </TD>
-        71 </TR>
-        72 <TR>
-        73      <TD>
-        74              Zoom Out
-        75      </TD>
-        76      <TD>
-        77              <INPUT TYPE=RADIO NAME="zoom" VALUE=-1 <?php echo $check_zout?>>
-        78      </TD>
-        79 </TR>
-        80 <TR>
-        81      <TD>
-        82              Zoom Size
-        83      </TD>
-        84      <TD>
-        85              <INPUT TYPE=TEXT NAME="zsize" VALUE="<?php echo $val_zsize?>"
-        86              SIZE=2>
-        87      </TD>
-        88 </TR>
-        89 <TR>
-        90      <TD>
-        91              Full Extent
-        92      </TD>
-        93      <TD>
-        94              <INPUT TYPE=SUBMIT NAME="full" VALUE="Go"
-        95              SIZE=2>
-        96      </TD>
-        97 </TABLE>
-        98 <INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
-        99 </FORM>
-        100 </CENTER>
-        101 </BODY>
-        102 </HMTL>
+         <HTML>
+         <HEAD>
+         <TITLE>Map 2</TITLE>
+         </HEAD>
+         <BODY>
+         <CENTER>
+         <FORM METHOD=POST ACTION=<?php echo $HTTP_SERVER_VARS['PHP_SELF']?>>
+         <TABLE>
+         <TR>
+              <TD>
+                      <INPUT TYPE=IMAGE NAME="mapa" SRC="<?php echo $image_url?>">
+              </TD>
+         </TR>
+         <TR>
+              <TD>
+                      Pan
+              </TD>
+              <TD>
+                      <INPUT TYPE=RADIO NAME="zoom" VALUE=0 <?php echo $check_pan?>>
+              </TD>
+         </TR>
+         <TR>
+              <TD>
+                      Zoom In
+              </TD>
+              <TD>
+                      <INPUT TYPE=RADIO NAME="zoom" VALUE=1 <?php echo $check_zin?>>
+              </TD>
+         </TR>
+         <TR>
+              <TD>
+                      Zoom Out
+              </TD>
+              <TD>
+                      <INPUT TYPE=RADIO NAME="zoom" VALUE=-1 <?php echo $check_zout?>>
+              </TD>
+         </TR>
+         <TR>
+              <TD>
+                      Zoom Size
+              </TD>
+              <TD>
+                      <INPUT TYPE=TEXT NAME="zsize" VALUE="<?php echo $val_zsize?>"
+                      SIZE=2>
+              </TD>
+         </TR>
+         <TR>
+              <TD>
+                      Full Extent
+              </TD>
+              <TD>
+                      <INPUT TYPE=SUBMIT NAME="full" VALUE="Go"
+                      SIZE=2>
+              </TD>
+         </TABLE>
+         <INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
+         </FORM>
+         </CENTER>
+         </BODY>
+         </HMTL>
 This code will zoom out, zoom in, pan, and restore to full extent the image
 displayed in the previous example.
