[mapserver-commits] r8488 - trunk/mapserver
Tue Feb 3 10:04:16 EST 2009
Author: assefa
Date: 2009-02-03 10:04:16 -0500 (Tue, 03 Feb 2009)
New Revision: 8488
   trunk/mapserver/maperror.c
   trunk/mapserver/mapwms.c
wms exception might be sent in GIF format when map is set with AGG driver #2874
Modified: trunk/mapserver/maperror.c
--- trunk/mapserver/maperror.c	2009-02-02 20:01:42 UTC (rev 8487)
+++ trunk/mapserver/maperror.c	2009-02-03 15:04:16 UTC (rev 8488)
@@ -393,6 +393,8 @@
   int nBlack = 0;
   outputFormatObj *format = NULL;
   char *errormsg = msGetErrorString("; ");
+  char *pFormatBuffer;
+  char cGDFormat[128];
   if (map) {
       if( map->width != -1 && map->height != -1 )
@@ -403,7 +405,7 @@
   /* Default to GIF if no suitable GD output format set */
-  if (format == NULL || !MS_DRIVER_GD(format))
+  if (format == NULL || (!MS_DRIVER_GD(format) && !MS_DRIVER_AGG(format)))
     format = msCreateDefaultOutputFormat( NULL, "GD/PC256" );
   img = gdImageCreate(width, height);
@@ -466,7 +468,17 @@
   /* actually write the image */
   if(!filename)
       msIO_printf("Content-type: %s%c%c", MS_IMAGE_MIME_TYPE(format), 10,10);
-  msSaveImageGD(img, filename, format);
+  if (MS_DRIVER_GD(format))
+    msSaveImageGD(img, filename, format);
+  else
+      strcpy(cGDFormat, "gd/");
+      strcat(cGDFormat, &(format->driver[4]));
+      format->driver = &cGDFormat[0];
+      format->driver = pFormatBuffer;
   gdImageDestroy(img);
   if (format->refcount == 0)
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-02-02 20:01:42 UTC (rev 8487)
+++ trunk/mapserver/mapwms.c	2009-02-03 15:04:16 UTC (rev 8488)
@@ -417,7 +417,7 @@
       int  j, k, iLayer;
       layers = msStringSplit(values[i], ',', &numlayers);
-      if (layers==NULL || numlayers < 1) {
+      if (layers==NULL || strlen(values[i]) <=0 ||   numlayers < 1) {
         msSetError(MS_WMSERR, "At least one layer name required in LAYERS.",
                    "msWMSLoadGetMapParams()");
         return msWMSException(map, nVersion, NULL);
@@ -2218,6 +2218,7 @@
   if (msSaveImage(map, img, NULL) != MS_SUCCESS)
   msFreeImage(img);
   return(MS_SUCCESS);
