[mapserver-commits] r8493 - trunk/docs/ogc
Tue Feb 3 18:22:33 EST 2009
Author: tomkralidis
Date: 2009-02-03 18:22:33 -0500 (Tue, 03 Feb 2009)
New Revision: 8493
   trunk/docs/ogc/mapcontext.txt
add info for WMS GetContext (#481)
Modified: trunk/docs/ogc/mapcontext.txt
--- trunk/docs/ogc/mapcontext.txt	2009-02-03 22:21:35 UTC (rev 8492)
+++ trunk/docs/ogc/mapcontext.txt	2009-02-03 23:22:33 UTC (rev 8493)
@@ -485,7 +485,29 @@
       IMAGEURL "/ms_tmp/"
     END
     END # Map File
+Map Context Support Through WMS
+MapServer can also output your WMS layers as a Context document.  MapServer
+extends the WMS standard by adding a request=GetContext operation that allows
+you to retrieve a context for a WMS-based mapfile with a call
+like:
+    http://localhost/mapserver.cgi?map=/path/to/mapfile.map&service=WMS&
+    request=GetContext&version=1.1.0
+The VERSION parameter controls the version of context document to return.
+GetContext is disabled by default because it could be
+considered a security issue: it could publicly expose the URLs of WMS layers
+used (cascaded) by a mapfile.
+To enable it, set the "wms_getcontext_enabled" web metadata to "1" in your
+WMS server's mapfile.
 .. #### rST Link Section ####
 .. _`Web Map Context Specification v1.0.0`: http://www.opengeospatial.org/docs/03-036r2.pdf
