[mapserver-commits] r8496 - trunk/mapserver/mapscript/php3
Wed Feb 4 11:46:24 EST 2009
Author: assefa
Date: 2009-02-04 11:46:23 -0500 (Wed, 04 Feb 2009)
New Revision: 8496
   trunk/mapserver/mapscript/php3/Makefile.vc
   trunk/mapserver/mapscript/php3/nmake.opt
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapscript/php3/php_proj.c
add request type member for owsrequest #1488
Modified: trunk/mapserver/mapscript/php3/Makefile.vc
--- trunk/mapserver/mapscript/php3/Makefile.vc	2009-02-04 16:24:44 UTC (rev 8495)
+++ trunk/mapserver/mapscript/php3/Makefile.vc	2009-02-04 16:46:23 UTC (rev 8496)
@@ -20,11 +20,15 @@
 PDB_FILE=/Fdphpms.pdb
 PHP4_FLAGS=/DZEND_WIN32 /DPHP_WIN32 /DPHP4 /DZTS
-OPTFLAGS =	/nologo /Zi $(WARNING_LEVEL) $(DEBUG) $(PDB_FILE)
-BASE_CFLAGS = 	$(OPTFLAGS) -DWIN32 -D_WIN32 $(PHP4_FLAGS)
+#OPTFLAGS =	/nologo /Zi $(WARNING_LEVEL) $(DEBUG) $(PDB_FILE)
+#BASE_CFLAGS = 	$(OPTFLAGS) -DWIN32 -D_WIN32 $(PHP4_FLAGS)
 #LDFLAGS =	/NODEFAULTLIB:msvcrt /dll $(LDEBUG)
-LDFLAGS =	/NODEFAULTLIB:libcd /dll $(LDEBUG)
+#LDFLAGS =	/NODEFAULTLIB:libcd /dll $(LDEBUG)
+BASE_CFLAGS = 	$(OPTFLAGS) -DWIN32 -D_WIN32 $(PHP4_FLAGS)
+OPTFLAGS = /nologo /Zi /MD $(WARNING_LEVEL) $(DEBUG) /EHsc
+LDFLAGS =       /NODEFAULTLIB:libc /dll /FORCE:MULTIPLE $(LDEBUG)
 # Set PHP_HOME to point to the root of the PHP source tree
Modified: trunk/mapserver/mapscript/php3/nmake.opt
--- trunk/mapserver/mapscript/php3/nmake.opt	2009-02-04 16:24:44 UTC (rev 8495)
+++ trunk/mapserver/mapscript/php3/nmake.opt	2009-02-04 16:46:23 UTC (rev 8496)
@@ -20,7 +20,7 @@
 #name of the file that will be used when doing make install
 #it will be copied in the directory specified by the
-PHP_INSTALL_DLL_NAME = php_mapscript_48.dll
+PHP_INSTALL_DLL_NAME = php_mapscript.dll
 !IFDEF PHP4
 # Install directory for PHP4
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2009-02-04 16:24:44 UTC (rev 8495)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2009-02-04 16:46:23 UTC (rev 8496)
@@ -1323,6 +1323,9 @@
     REGISTER_LONG_CONSTANT("MS_LABEL_BINDING_FONT",  MS_LABEL_BINDING_FONT, const_flag);
     REGISTER_LONG_CONSTANT("MS_LABEL_BINDING_PRIORITY", MS_LABEL_BINDING_PRIORITY, const_flag);
+    /*cgi request types*/
+    REGISTER_LONG_CONSTANT("MS_GET_REQUEST", MS_GET_REQUEST, const_flag);
+    REGISTER_LONG_CONSTANT("MS_POST_REQUEST", MS_POST_REQUEST, const_flag);
     INIT_CLASS_ENTRY(tmp_class_entry, "ms_map_obj", php_map_class_functions);
     map_class_entry_ptr = zend_register_internal_class(&tmp_class_entry TSRMLS_CC);
@@ -15863,6 +15866,7 @@
                        PHP4_CLASS_ENTRY(cgirequest_class_entry_ptr) TSRMLS_CC);
     add_property_long(return_value,   "numparams",     prequest->NumParams);
+    add_property_long(return_value,   "type",     prequest->type);
     return id;
@@ -15911,6 +15915,7 @@
       cgirequestObj_loadParams(self);
      /* sync the class member*/
      _phpms_set_property_long(pThis,"numparams", self->NumParams, E_ERROR TSRMLS_CC);
+     _phpms_set_property_long(pThis,"type", self->type, E_ERROR TSRMLS_CC);
      RETURN_LONG(self->NumParams);
Modified: trunk/mapserver/mapscript/php3/php_proj.c
--- trunk/mapserver/mapscript/php3/php_proj.c	2009-02-04 16:24:44 UTC (rev 8495)
+++ trunk/mapserver/mapscript/php3/php_proj.c	2009-02-04 16:46:23 UTC (rev 8496)
@@ -14,16 +14,16 @@
  * the rights to use, copy, modify, merge, publish, distribute, sublicense,
  * and/or sell copies of the Software, and to permit persons to whom the
  * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
  * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
  * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
  * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
  * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
  * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
  * DEALINGS IN THE SOFTWARE.
@@ -64,15 +64,15 @@
  *         PHP PROJ4 Module
- *  This is a PHP module that gives acces to basic PROJ4 projection
+ *  This is a PHP module that gives acces to basic PROJ4 projection
  *  functionalities.
  * There following functions available in this module :
  * 1) pj_init : create and initializes a projection structures
  *    PJ pj_init(array_of_parameters)
  *    Example : $projarray[0] = "proj=lcc";
  *              $projarray[1] = "ellps=GRS80";
  *              $projarray[2] = "lat_0=49";
@@ -84,7 +84,7 @@
  * 2) pj_fwd : Performs a projection from lat/long coordinates to
  *             cartesian coordinates.
  * retrun_array pj_fwd(double lat, double long, PJ pj)
  *   Example :  $lat = 45.25;
@@ -96,7 +96,7 @@
  * 3) pj_inv : Performs a projection from cartesian coordinates to
  *             lat/long  coordinates .
  * retrun_array pj_fwd(double geox, double geoy, PJ pj)
  *   Example :  $ingeox = 1537490.335842;
@@ -108,7 +108,7 @@
  * 4) pj_transform : pj_transform(PJ pjsrc, PJ pjdst, double x, double y)
- *      transforms coordinates from source projection to
+ *      transforms coordinates from source projection to
  *                   destination projection.
@@ -129,9 +129,9 @@
  *              $ret = pj_transform($pjlcc, $pjlat, $ingeox, $ingeoy);
  * 5) pj_free : frees PJ structure
- *  void pj_free(PJ pj);
+ *  void pj_free(PJ pj);
 #ifdef USE_PROJ
@@ -161,7 +161,7 @@
 #define ZEND_DEBUG 0
 #endif
-#ifndef DLEXPORT
+#ifndef DLEXPORT
 #define DLEXPORT ZEND_DLEXPORT
 #endif
@@ -192,14 +192,14 @@
 #if defined (PHP4) || defined (PHP5)
 static zend_class_entry *proj_class_entry_ptr;
-#endif
+#endif
 #define PHPMS_GLOBAL(a) a
 static int le_projobj;
 function_entry php_proj_functions[] = {
     {"pj_fwd",  php_proj_pj_fwd,   NULL},
-    {"pj_inv",  php_proj_pj_inv,   NULL},
+    {"pj_inv",  php_proj_pj_inv,   NULL},
     {"pj_init",  php_proj_pj_init,   NULL},
     {"pj_transform",  php_proj_pj_transform,   NULL},
     {"pj_datum_transform",  php_proj_pj_datum_transform,   NULL},
@@ -213,23 +213,23 @@
     STANDARD_MODULE_HEADER,
 #endif
     "PHPPROJ", php_proj_functions, php_init_proj, php_end_proj,
-    NULL, NULL,
+    NULL, NULL,
 #ifdef ZEND_VERSION
     PHP_MINFO(phpproj),
 #else
-    php_info_proj,
+    php_info_proj,
 #endif
 #if ZEND_MODULE_API_NO >= 20010901
     "phpproj, php4.1version",          /* extension version number (string) */
 #endif
-    STANDARD_MODULE_PROPERTIES
+    STANDARD_MODULE_PROPERTIES
 #if COMPILE_DL
-DLEXPORT php3_module_entry *get_module(void)
-    return &php_proj_module_entry;
+DLEXPORT php3_module_entry *get_module(void)
+    return &php_proj_module_entry;
 #endif
@@ -243,10 +243,10 @@
-#ifdef ZEND_VERSION
+#ifdef ZEND_VERSION
 PHP_MINFO_FUNCTION(phpproj)
 #else
-DLEXPORT void php_info_proj(void)
+DLEXPORT void php_info_proj(void)
 #endif
     php3_printf(" Version %s<br>\n", PHP_PROJ_VERSION);
@@ -260,7 +260,7 @@
     zend_class_entry tmp_class_entry;
 #endif
-    PHPMS_GLOBAL(le_projobj)  =
+    PHPMS_GLOBAL(le_projobj)  =
         register_list_destructors(php_proj_pj_free,
                                   NULL);
@@ -342,7 +342,7 @@
     int         nParamCount = 0;
     int         i = 0;
     PJ          *pj = NULL;
     char        **papszBuf = NULL;
 //    char        *strttt = NULL;
@@ -353,7 +353,7 @@
 /*      extract parameters.                                             */
     if (getParameters(ht, 1, &pArrayOfParams) != SUCCESS)
         WRONG_PARAM_COUNT;
@@ -366,10 +366,10 @@
       RETURN_LONG(-1);
     papszBuf = (char **) malloc((nParamCount+2)*sizeof(char *));
-    for (i = 0; i < nParamCount; i++)
+    for (i = 0; i < nParamCount; i++)
-        if (_php3_hash_index_find(pArrayOfParams->value.ht, i,
+        if (_php3_hash_index_find(pArrayOfParams->value.ht, i,
                                   (void **)&pParam) != FAILURE)
@@ -386,8 +386,8 @@
      papszBuf[i] = NULL;
     pj = pj_init(nParamCount, papszBuf);
-    _php_proj_build_proj_object(pj, list, return_value TSRMLS_CC);
+    _php_proj_build_proj_object(pj, list, return_value TSRMLS_CC);
@@ -426,22 +426,22 @@
     if (getParameters(ht, 3, &p1, &p2, &pj) != SUCCESS)
         WRONG_PARAM_COUNT;
 /*      initilize return array.                                         */
-    if (array_init(return_value) == FAILURE)
+    if (array_init(return_value) == FAILURE)
         RETURN_FALSE;
     convert_to_double(p1);
     convert_to_double(p2);
-    popj = (PJ *)_phpms_fetch_handle(pj,
+    popj = (PJ *)_phpms_fetch_handle(pj,
                                      PHPMS_GLOBAL(le_projobj), list TSRMLS_CC);
     if (popj)
@@ -495,14 +495,14 @@
         WRONG_PARAM_COUNT;
         RETURN_FALSE;
@@ -510,7 +510,7 @@
     if (popj)
@@ -557,39 +557,39 @@
     if (getParameters(ht, 4, &pjin , &pjout, &p1, &p2) != SUCCESS)
         WRONG_PARAM_COUNT;
         RETURN_FALSE;
-    in = (PJ *)_phpms_fetch_handle(pjin,
+    in = (PJ *)_phpms_fetch_handle(pjin,
-    out = (PJ *)_phpms_fetch_handle(pjout,
+    out = (PJ *)_phpms_fetch_handle(pjout,
     if (in && out)
         pnt.u = p1->value.dval;
         pnt.v = p2->value.dval;
         if( pj_is_latlong(in) )
             pnt.u *= DEG_TO_RAD;
             pnt.v *= DEG_TO_RAD;
-        error = pj_transform(in, out, 1, 0,
+        error = pj_transform(in, out, 1, 0,
                              &(pnt.u), &(pnt.v), &z );
         if( pj_is_latlong(out) )
@@ -601,8 +601,8 @@
     if (error)
-        php_error(E_ERROR,"Error in pj_transform");
+        php_error(E_ERROR,"Error in pj_transform");
         RETURN_LONG(-1);
     else
@@ -645,39 +645,39 @@
         WRONG_PARAM_COUNT;
         RETURN_FALSE;
     if (in && out)
         if (!error)
@@ -693,7 +693,7 @@
     if (error)
         php_error(E_ERROR,"Error in pj_datum_transform");
         RETURN_LONG(-1);
     else
@@ -724,11 +724,11 @@
     if (getParameters(ht, 1, &pj) != SUCCESS)
         WRONG_PARAM_COUNT;
     if (popj)
