[mapserver-commits] r8519 - trunk/docs/ogc
Mon Feb 9 11:58:44 EST 2009
Author: jmckenna
Date: 2009-02-09 11:58:44 -0500 (Mon, 09 Feb 2009)
New Revision: 8519
   trunk/docs/ogc/wms_server.txt
update various links
Modified: trunk/docs/ogc/wms_server.txt
--- trunk/docs/ogc/wms_server.txt	2009-02-08 23:43:39 UTC (rev 8518)
+++ trunk/docs/ogc/wms_server.txt	2009-02-09 16:58:44 UTC (rev 8519)
@@ -8,7 +8,6 @@
 :Contact: jmckenna at gatewaygeomatics.com
 :Revision: $Revision$
 :Date: $Date$
-:Last Updated: 2006/01/09
 .. contents:: Table of Contents
     :depth: 2
@@ -39,8 +38,6 @@
 - `WMS 1.1.1 specification`_
 - `Open Geospatial Consortium (OGC)`_ home page
 - `WMS-Dev mailing list and archive`_
-- `WMS FAQ`_
-- `WMS XML Capabilities validator`_
 - `WMS Cookbook`_
 - `MapServer OGC Web Services Workshop`_ package
 - :ref:`MapServer Styled Layer Descriptor (SLD) Howto <sld>`
@@ -406,17 +403,17 @@
 - MapServer itself can be used as a WMS client, see the :ref:`MapServer WMS Client Howto <wms_client>`.
-- `Deegree`_ provides a WMS client.
+- `Quantum GIS`_ is a full GIS package which includes WMS client support. (recommended)
-- MapLab's `MapBrowser`_ is a web-based WMS client.
 - `OpenJUMP`_ is a desktop GIS package which includes WMS client support.
+- `uDig`_ is a desktop package that allows users to add WMS layers.
+- `Deegree`_ provides a WMS client.
 - `owsview`_ Viewer Client Generator is an online application that allows users
   to add WMS layers.
-- `uDig`_ is a desktop package that allows users to add WMS layers.
 This list is not exhaustive, there are several Open Source or proprietary packages
 that offer WMS support and could be used to interact with your new MapServer WMS
 server instance.
@@ -1167,7 +1164,7 @@
     :ref:`error documentation <errors>` to see if your exact error is discussed.
     If you don't have the "epsg" file then you can get it as part of the PROJ4 distribution
-    at http://www.remotesensing.org/proj/ or you can download it at
+    at http://trac.osgeo.org/proj/ or you can download it at
     http://www.maptools.org/dl/proj4-epsg.zip.
@@ -1208,21 +1205,19 @@
 .. #### rST Link Section ####
-.. _`Web Map Server Interfaces Implementation Specification v1.1.1`: http://www.opengeospatial.org/docs/01-068r2.pdf
-.. _`WMS 1.1.1 specification`: http://www.opengeospatial.org/docs/01-068r2.pdf
+.. _`Web Map Server Interfaces Implementation Specification v1.1.1`: http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf
+.. _`WMS 1.1.1 specification`: http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf
 .. _`Open Geospatial Consortium (OGC)`: http://www.opengeospatial.org/
-.. _`WMS-Dev mailing list and archive`: http://www.intl-interfaces.net/mailman/listinfo/wms-dev
-.. _`WMS FAQ`: http://www.intl-interfaces.net/cookbook/WMS/faq/faqw.py?req=home
-.. _`WMS XML Capabilities validator`: http://www.digitalearth.gov/wmt/xml/validator.html
-.. _`WMS Cookbook`: http://www.intl-interfaces.net/cookbook/WMS/
+.. _`WMS-Dev mailing list and archive`: http://lists.eogeo.org/mailman/listinfo/wms-dev
+.. _`WMS Cookbook`: http://www.intl-interfaces.com/cookbook/WMS/
 .. _`MapServer OGC Web Services Workshop`: http://ms-ogc-workshop.maptools.org/
 .. _`MS4W`: http://www.maptools.org/ms4w/
-.. _`MapBrowser`: http://www.maptools.org/maplab/
+.. _`Quantum GIS`: http://www.qgis.org/
 .. _`OpenJUMP`: http://www.openjump.org
-.. _`Deegree`: http://deegree.sourceforge.net/
+.. _`Deegree`: http://www.deegree.org/
 .. _`owsview`: http://devgeo.cciw.ca/owsview
-.. _`uDig`: http://udig.refractions.net/confluence/display/UDIG/Home
-.. _`WMS 1.1.1 section 6.2.2`: http://www.opengeospatial.org/docs/01-068r2.pdf
+.. _`uDig`: http://udig.refractions.net/
+.. _`WMS 1.1.1 section 6.2.2`: http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf
 .. _`valid request`: http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&layers=park,popplace&STYLES=&SRS=EPSG:4326&BBOX=-173.537,35.8775,-11.9603,83.8009&WIDTH=400&HEIGHT=300&FORMAT=image/png
 .. _`text/plain`: http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?&SERVICE=wms&VERSION=1.1.1&REQUEST=getfeatureinfo&LAYERS=popplace&QUERY_LAYERS=popplace&x=305&y=200&INFO_FORMAT=text/plain
 .. _`text/html`: http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?&SERVICE=wms&VERSION=1.1.1&REQUEST=getfeatureinfo&LAYERS=popplace&QUERY_LAYERS=popplace&x=305&y=200&INFO_FORMAT=text/html
