[mapserver-commits] r8528 - trunk/docs/development/rfc
Wed Feb 11 17:49:12 EST 2009
Author: assefa
Date: 2009-02-11 17:49:12 -0500 (Wed, 11 Feb 2009)
New Revision: 8528
   trunk/docs/development/rfc/ms-rfc-30.txt
Update RFC with more info
Modified: trunk/docs/development/rfc/ms-rfc-30.txt
--- trunk/docs/development/rfc/ms-rfc-30.txt	2009-02-11 18:45:03 UTC (rev 8527)
+++ trunk/docs/development/rfc/ms-rfc-30.txt	2009-02-11 22:49:12 UTC (rev 8528)
@@ -7,9 +7,11 @@
 :Date: 2007/06/15
 :Author: Daniel Morissette
 :Contact: dmorissette at mapgears.com
-:Last Edited: 2007/09/05
+:Author: Yewondwossen Assefa
+:Contact: yassefa at dmsolutions.ca
+:Last Edited: 2009/02/11
 :Status: Draft
-:Version: MapServer 5.2
+:Version: MapServer 5.4
 :Id: $Id$
 Overview
@@ -27,8 +29,8 @@
 This RFC is mostly to document those changes and the way MapServer deals
 with them.
-Technical Solution
+Coordinate Systems and Axis Orientation
 The main issue introduced by WMS 1.3.0 is the change in the way it handles
 axis order for several SRS. This has an impact on the way the
@@ -48,17 +50,65 @@
 information about the axis order of all EPSG SRS codes and treat them
 using the correct axis order.
-New SRS codes in the CRS:xxxx space have also been added by WMS 1.3.0
-that will need to be supported by MapServer
+New CRS codes such as CRS:xxxx and AUTO2:xxxx have also been added by WMS 1.3.0
+that will need to be supported by MapServer. Note the wo types of Layer CRS
+identifiers are supported by the specification: “label” and “URL” identifiers.
+The intention is to support at this point the label types CRS.
+List of CRS planned to be supported are:
+- CRS:84 (WGS 84 longitude-latitude) CRS:83 (NAD83 longitude-latitude)
+CRS:27 (NAD27 longitude-latitude) CRS:1 (pixel coordinates)
+- AUTO2:42001 AUTO2:42002 AUTO2:42003 AUTO2:42004 AUTO2:42005
+EPSG codes: when advertising (such as BoundingBox for a layer elemnt) or using
+a CRS element in a request such as GetMap/GetFeatureInfo, elements using epsg code >=4000
+and <5000 will be assumed to have a reverse axes.
 All the above need to be done in a way that allows continued support for
 older versions of the WMS specification (1.0.0 to 1.1.1) and will have
 the least impact on existing WMS services.
-At this point the exact implementation details have not all been sorted out.
-They will be documented here as we refine them.
+Implementation for the reverse axis will follow closely to what was already
+done for WCS1.1 support (http://mapserver.org/development/rfc/ms-rfc-41.html)
+WMS and SLD
+All references to SLD support has been removed from the WMS 1.3.0 specifications.
+It has been replaced by two specifications:
+- Styled Layer Descriptor profile of the Web Map Service
+- Symbology Encoding Implementation Specification
+The Styled Layer Descriptor profile allows:
+- to extend the WMS to support additional operations (DescribeLayer, GetLegendGraphic)
+- addtional parameters related to the SLD for the GetMap support
+- advertise SLD support.
+This specification will be supported in the current implementation.
+Note that the GetStyles operation (available in WMS 1.1.1) might not be supported
+in the first phase
+The Symbology Encoding Implementation represent basically the definitions for the
+different symbolizers. We need to upgrade the current SLD support to support this
+specification.
+HTTP Post support
+HTTP Post support is optional and currently supported by Mapserver WMS 1.1.1.
+WMS 1.3.0 defines that if POST is supported, the the request message is formulated
+as an XML document.
+Although this is highly deirable, the first implemenation of the WMS 1.3.0 might
+not support the XML Post requests.
 MapScript Implications
@@ -71,9 +121,10 @@
  mapwms.c
  mapwmslayer.c
+ mapfile.c
+ mapows.c/h
+ mapogcsld.c
 Backwards compatibility issues
