[mapserver-commits] r8538 - trunk/docs/ogc
Thu Feb 12 12:26:17 EST 2009
Author: tomkralidis
Date: 2009-02-12 12:26:17 -0500 (Thu, 12 Feb 2009)
New Revision: 8538
   trunk/docs/ogc/sos_server.txt
s/sensorid/procedure/
Modified: trunk/docs/ogc/sos_server.txt
--- trunk/docs/ogc/sos_server.txt	2009-02-12 17:22:34 UTC (rev 8537)
+++ trunk/docs/ogc/sos_server.txt	2009-02-12 17:26:17 UTC (rev 8538)
@@ -492,7 +492,7 @@
 - *Description:* (Required) This metadata item is only a temporary measure until the
   describe sensor is generated from MapServer. Right now when a DescribeSensor request is sent with a procedure (sensorid), it will redirect it to the url defined by this metadata item.
-- In MapServer 5.0, it is possible to use variable substituion on the url. For example "sos_describesensor_url" \"\http://foo/foo?mysensor=%procedure%\"\  will substitute the %procedure% in the metadata with the sensorid value coming from the request.
+- In MapServer 5.0, it is possible to use variable substituion on the url. For example "sos_describesensor_url" \"\http://foo/foo?mysensor=%procedure%\"\  will substitute the %procedure% in the metadata with the procedure value coming from the request.
