[mapserver-commits] r8544 - trunk/mapserver
Thu Feb 12 19:01:37 EST 2009
Author: assefa
Date: 2009-02-12 19:01:37 -0500 (Thu, 12 Feb 2009)
New Revision: 8544
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapows.c
   trunk/mapserver/mapows.h
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapwms.c
Initial WMS 1.3.0 commit
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2009-02-12 22:53:42 UTC (rev 8543)
+++ trunk/mapserver/mapfile.c	2009-02-13 00:01:37 UTC (rev 8544)
@@ -1081,6 +1081,42 @@
 #endif
+/*                         msLoadProjectionStringESPG                   */
+/*      Checks fro EPSG type projection and set the axes for a          */
+/*      certain code ranges.                                            */
+/*      Use for now in WMS 1.3.0                                        */
+int msLoadProjectionStringESPG(projectionObj *p, char *value)
+    p->gt.need_geotransform = MS_FALSE;
+    if (strncasecmp(value, "EPSG:", 5) == 0)
+        char init_string[100];
+        /* translate into PROJ.4 format. */
+        sprintf( init_string, "init=epsg:%s", value+5 );
+        p->args = (char**)malloc(sizeof(char*) * 2);
+        p->args[0] = strdup(init_string);
+        p->numargs = 1;
+        if( atoi(value+5) >= 4000 && atoi(value+5) < 5000 )
+            p->args[1] = strdup("+epsgaxis=ne");
+            p->numargs = 2;
+        return msProcessProjection( p );
+    return msLoadProjectionString(p, value);
 int msLoadProjectionString(projectionObj *p, char *value)
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2009-02-12 22:53:42 UTC (rev 8543)
+++ trunk/mapserver/mapows.c	2009-02-13 00:01:37 UTC (rev 8544)
@@ -1160,7 +1160,40 @@
     return status;
+** msOWSPrintEX_GeographicBoundingBox()
+** Print a EX_GeographicBoundingBox tag for WMS1.3.0
+void msOWSPrintEX_GeographicBoundingBox(FILE *stream, const char *tabspace,
+                                        rectObj *extent, projectionObj *srcproj)
+  const char *pszTag = "EX_GeographicBoundingBox";  /* The default for WMS */
+  rectObj ext;
+  ext = *extent;
+  /* always project to lat long */
+  if (srcproj->numargs > 0 && !pj_is_latlong(srcproj->proj)) {
+      msProjectRect(srcproj, NULL, &ext);
+  msIO_fprintf(stream, "%s<%s>\n", tabspace, pszTag);
+  msIO_fprintf(stream, "%s    <westBoundLongitude>%g</westBoundLongitude>\n", tabspace, ext.minx);
+  msIO_fprintf(stream, "%s    <eastBoundLongitude>%g</eastBoundLongitude>\n", tabspace, ext.maxx);
+  msIO_fprintf(stream, "%s    <southBoundLatitude>%g</southBoundLatitude>\n", tabspace, ext.miny);
+  msIO_fprintf(stream, "%s    <northBoundLatitude>%g</northBoundLatitude>\n", tabspace, ext.maxy);
+  msIO_fprintf(stream, "%s</%s>\n", tabspace, pszTag);
+  //msIO_fprintf(stream, "%s<%s minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\" />\n",
+  //      tabspace, pszTag, ext.minx, ext.miny, ext.maxx, ext.maxy);
 ** msOWSPrintLatLonBoundingBox()
 ** Print a LatLonBoundingBox tag for WMS, or LatLongBoundingBox for WFS
@@ -1201,24 +1234,48 @@
                            rectObj *extent,
                            projectionObj *srcproj,
                            hashTableObj *metadata,
-                           const char *namespaces)
+                           const char *namespaces,
+                           int wms_version)
     const char	*value, *resx, *resy;
     char *encoded, *encoded_resx, *encoded_resy;
+    projectionObj proj;
     /* Look for EPSG code in PROJECTION block only.  "wms_srs" metadata cannot be
      * used to establish the native projection of a layer for BoundingBox purposes.
     value = msOWSGetEPSGProj(srcproj, NULL, namespaces, MS_TRUE);
+    /*for wms 1.3.0 we need to make sure that we present the BBOX with
+      a revered axes for some espg codes*/
+    if (wms_version >= OWS_1_3_0 && value && strncasecmp(value, "EPSG:", 5) == 0)
+        msInitProjection(&proj);
+        if (msLoadProjectionStringESPG(&proj, (char *)value) == 0)
+            msAxisNormalizePoints( &proj, 1, &extent->minx, &extent->miny );
+            msAxisNormalizePoints( &proj, 1, &extent->maxx, &extent->maxy );
+        msFreeProjection( &proj );
     if( value != NULL )
         encoded = msEncodeHTMLEntities(value);
-        msIO_fprintf(stream, "%s<BoundingBox SRS=\"%s\"\n"
+        if (wms_version >= OWS_1_3_0)
+          msIO_fprintf(stream, "%s<BoundingBox CRS=\"%s\"\n"
                "%s            minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\"",
                tabspace, encoded,
                tabspace, extent->minx, extent->miny,
                extent->maxx, extent->maxy);
+        else
+          msIO_fprintf(stream, "%s<BoundingBox SRS=\"%s\"\n"
+               "%s            minx=\"%g\" miny=\"%g\" maxx=\"%g\" maxy=\"%g\"",
+               tabspace, encoded,
+               tabspace, extent->minx, extent->miny,
+               extent->maxx, extent->maxy);
         msFree(encoded);
         if( (resx = msOWSLookupMetadata( metadata, "MFO", "resx" )) != NULL &&
@@ -1559,7 +1616,8 @@
   } else if (proj && proj->numargs > 0 && (value = strstr(proj->args[0], "init=epsg:")) != NULL && strlen(value) < 20) {
     sprintf(epsgCode, "EPSG:%s", value+10);
     return epsgCode;
-  } else if (proj && proj->numargs > 0 && strncasecmp(proj->args[0], "AUTO:", 5) == 0 ) {
+  } else if (proj && proj->numargs > 0 && (strncasecmp(proj->args[0], "AUTO:", 5) == 0 ||
+                                           strncasecmp(proj->args[0], "AUTO2:", 6) == 0)) {
     return proj->args[0];
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2009-02-12 22:53:42 UTC (rev 8543)
+++ trunk/mapserver/mapows.h	2009-02-13 00:01:37 UTC (rev 8544)
@@ -187,6 +187,7 @@
 #define OWS_1_0_8   0x010008
 #define OWS_1_1_0   0x010100
 #define OWS_1_1_1   0x010101
+#define OWS_1_3_0   0x010300
 #define OWS_VERSION_MAXLEN   20  /* Buffer size for msOWSGetVersionString() */
 #define OWS_VERSION_NOTSET    -1
 #define OWS_VERSION_BADFORMAT -2
@@ -266,11 +267,15 @@
 void msOWSPrintLatLonBoundingBox(FILE *stream, const char *tabspace,
                                  rectObj *extent, projectionObj *srcproj,
                                  projectionObj *wfsproj, int nService);
+                                        rectObj *extent, projectionObj *srcproj);
 void msOWSPrintBoundingBox(FILE *stream, const char *tabspace,
                            rectObj *extent,
-                           const char *namespaces);
+                           int wms_version);
 void msOWSPrintContactInfo( FILE *stream, const char *tabspace,
                             int nVersion, hashTableObj *metadata,
                             const char *namespaces  );
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2009-02-12 22:53:42 UTC (rev 8543)
+++ trunk/mapserver/mapserver.h	2009-02-13 00:01:37 UTC (rev 8544)
@@ -107,6 +107,7 @@
 #include <pdflib.h>
 #endif
 #include <sys/types.h> /* regular expression support */
 /* The regex lib from the system and the regex lib from PHP needs to
@@ -1491,6 +1492,7 @@
 MS_DLL_EXPORT void freeFeatureList(featureListNodeObjPtr list);
 MS_DLL_EXPORT int msLoadProjectionString(projectionObj *p, char *value);
+MS_DLL_EXPORT int msLoadProjectionStringEPSG(projectionObj *p, char *value);
 /* To be used *only* within the mapfile loading phase */
 MS_DLL_EXPORT int loadExpressionString(expressionObj *exp, char *value);
@@ -1973,6 +1975,7 @@
 int msGetTruetypeTextBBoxAGG(imageObj *img, char *font, double size, char *string, rectObj *rect, double **advances);
 int msGetRasterTextBBoxAGG(imageObj *img, int size, char *string, rectObj *rect);
 MS_DLL_EXPORT int msDrawTextAGG(imageObj *imgage, pointObj labelPnt, char *string, labelObj *label, fontSetObj *fontset, double scalefactor);
 MS_DLL_EXPORT int msDrawTextLineAGG(imageObj *image, char *string, labelObj *label, labelPathObj *labelpath, fontSetObj *fontset, double scalefactor);
 MS_DLL_EXPORT void msTransformShapeAGG(shapeObj *shape, rectObj extent, double cellsize);
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-02-12 22:53:42 UTC (rev 8543)
+++ trunk/mapserver/mapwms.c	2009-02-13 00:01:37 UTC (rev 8544)
@@ -84,8 +84,10 @@
         wms_exception_format = "INIMAGE";  /* WMS 1.0.0 */
       else if (nVersion <= OWS_1_0_7)
         wms_exception_format = "SE_XML";   /* WMS 1.0.1 to 1.0.7 */
+      else if (nVersion <= OWS_1_1_1)
+        wms_exception_format = "application/vnd.ogc.se_xml"; /* WMS 1.1.0 and later */
       else
-        wms_exception_format = "application/vnd.ogc.se_xml"; /* WMS 1.1.0 and later */
+        wms_exception_format = "text/xml";
   if (strcasecmp(wms_exception_format, "INIMAGE") == 0 ||
@@ -143,7 +145,7 @@
       msIO_printf("<ServiceExceptionReport version=\"1.1.0\">\n");
-    else /* 1.1.1 */
+    else if (nVersion <= OWS_1_1_1)/* 1.1.1 */
         msIO_printf("Content-type: application/vnd.ogc.se_xml%c%c",10,10);
@@ -154,8 +156,22 @@
         msIO_printf("<!DOCTYPE ServiceExceptionReport SYSTEM \"%s/wms/1.1.1/exception_1_1_1.dtd\">\n", schemalocation);
         msIO_printf("<ServiceExceptionReport version=\"1.1.1\">\n");
+    else /*1.3.0*/
+        if (strcasecmp(wms_exception_format, "application/vnd.ogc.se_xml") == 0)
+          msIO_printf("Content-type: application/vnd.ogc.se_xml%c%c",10,10);
+        else
+          msIO_printf("Content-type: text/xml%c%c",10,10);
+        msOWSPrintEncodeMetadata(stdout, &(map->web.metadata),
+                                 "MO", "encoding", OWS_NOERR,
+                  "<?xml version='1.0' encoding=\"%s\" standalone=\"no\" ?>\n",
+                           "ISO-8859-1");
+        msIO_printf("<ServiceExceptionReport version=\"1.3.0\" xmlns=\"http://www.opengis.net/ogc\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:schemaLocation=\"http://www.opengis.net/ogc %s/wms/1.3.0/exceptions_1_3_0.xsd\">\n",
+                    schemalocation);
     if (exception_code)
       msIO_printf("<ServiceException code=\"%s\">\n", exception_code);
     else
@@ -1081,6 +1097,26 @@
 ** msWMSPrintScaleHint()
+** Print a Min/MaxScaleDenominator tag for the layer if applicable.
+** used for WMS >=1.3.0
+void msWMSPrintScaleDenominator(const char *tabspace, double minscaledenom,
+                                double maxscaledenom)
+    if (minscaledenom > 0)
+      msIO_printf("%s<MinScaleDenominator>%g</MinScaleDenominator>\n",
+                  tabspace, minscaledenom);
+    if (maxscaledenom > 0)
+      msIO_printf("%s<MaxScaleDenominator>%g</MaxScaleDenominator>\n",
+                  tabspace, maxscaledenom);
+** msWMSPrintScaleHint()
 ** Print a ScaleHint tag for this layer if applicable.
 ** (see WMS 1.1.0 sect. 7.1.5.4) The WMS defines the scalehint values as
@@ -1125,7 +1161,8 @@
    char *pszMetadataName=NULL, *mimetype=NULL;
    char **classgroups = NULL;
    int iclassgroups=0 ,j=0;
+   char szVersionBuf[OWS_VERSION_MAXLEN];
    /* if the layer status is set to MS_DEFAULT, output a warning */
    if (lp->status == MS_DEFAULT)
      msIO_fprintf(stdout, "<!-- WARNING: This layer has its status set to DEFAULT and will always be displayed when doing a GetMap request even if it is not requested by the client. This is not in line with the expected behavior of a WMS server. Using status ON or OFF is recommended. -->\n");
@@ -1188,14 +1225,26 @@
        /* starting 1.1.1 SRS are given in individual tags */
        if (nVersion > OWS_1_1_0)
-           msOWSPrintEncodeParamList(stdout, "(at least one of) "
-                                     "MAP.PROJECTION, LAYER.PROJECTION "
-                                     "or wms_srs metadata",
-                                     msOWSGetEPSGProj(&(lp->projection),
+           if (nVersion >= OWS_1_3_0)
+             msOWSPrintEncodeParamList(stdout, "(at least one of) "
+                                       "MAP.PROJECTION, LAYER.PROJECTION "
+                                       "or wms_srs metadata",
+                                       msOWSGetEPSGProj(&(lp->projection),
                                                       &(lp->metadata),
                                                       "MO", MS_FALSE),
                                      OWS_WARN, ' ', NULL, NULL,
+                                     "        <CRS>%s</CRS>\n", NULL);
+           else
+                                                      &(lp->metadata),
+                                                      "MO", MS_FALSE),
+                                     OWS_WARN, ' ', NULL, NULL,
                                      "        <SRS>%s</SRS>\n", NULL);
        else
          /* If map has no proj then every layer MUST have one or produce a warning */
          msOWSPrintEncodeParam(stdout, "(at least one of) MAP.PROJECTION, "
@@ -1208,14 +1257,26 @@
                                                       &(lp->metadata),
                                                       "MO", MS_FALSE),
+           else
+                                                      &(lp->metadata),
+                                                      "MO", MS_FALSE),
        else
        /* No warning required in this case since there's at least a map proj. */
@@ -1230,22 +1291,34 @@
        if(lp->projection.numargs > 0)
-           msOWSPrintLatLonBoundingBox(stdout, "        ", &(ext),
-                                       &(lp->projection), NULL, OWS_WMS);
+             msOWSPrintEX_GeographicBoundingBox(stdout, "    ", &(ext),
+                                                &(lp->projection));
+           else
+             msOWSPrintLatLonBoundingBox(stdout, "        ", &(ext),
+                                         &(lp->projection), NULL, OWS_WMS);
            msOWSPrintBoundingBox( stdout,"        ", &(ext), &(lp->projection),
-                                  &(lp->metadata), "MO" );
+                                  &(lp->metadata), "MO", nVersion );
        else
-                                       &(map->projection), NULL, OWS_WMS);
+                                                &(map->projection));
+           else
+                                         &(map->projection), NULL, OWS_WMS);
            msOWSPrintBoundingBox(stdout,"        ", &(ext), &(map->projection),
-                                  &(map->web.metadata), "MO" );
+                                 &(map->web.metadata), "MO", nVersion );
    else
-       msIO_printf("        <!-- WARNING: Optional LatLonBoundingBox could not be established for this layer.  Consider setting LAYER.EXTENT or wms_extent metadata. Also check that your data exists in the DATA statement -->\n");
+         msIO_printf("        <!-- WARNING: Optional Ex_GeographicBoundingBox could not be established for this layer.  Consider setting LAYER.EXTENT or wms_extent metadata. Also check that your data exists in the DATA statement -->\n");
+       else
+         msIO_printf("        <!-- WARNING: Optional LatLonBoundingBox could not be established for this layer.  Consider setting LAYER.EXTENT or wms_extent metadata. Also check that your data exists in the DATA statement -->\n");
    /* time support */
@@ -1443,7 +1516,7 @@
                                char *name_encoded = msEncodeHTMLEntities(lp->name);
                                sprintf(legendurl, "%sversion=%s&amp;service=WMS&amp;request=GetLegendGraphic&amp;layer=%s&amp;format=%s&amp;STYLE=%s",
-                                       script_url_encoded,"1.1.1",name_encoded,
+                                       script_url_encoded,msOWSGetVersionString(nVersion, szVersionBuf),name_encoded,
                                        mimetype,  classgroups[i]);
                                msFree(name_encoded);
@@ -1482,8 +1555,10 @@
    msFree(pszMetadataName);
-   msWMSPrintScaleHint("        ", lp->minscaledenom, lp->maxscaledenom, map->resolution);
+   if (nVersion <  OWS_1_3_0)
+     msWMSPrintScaleHint("        ", lp->minscaledenom, lp->maxscaledenom, map->resolution);
+   else
+     msWMSPrintScaleDenominator("        ", lp->minscaledenom, lp->maxscaledenom);
    msIO_printf("%s    </Layer>\n", indent);
    return MS_SUCCESS;
@@ -1669,7 +1744,8 @@
     dtd_url = strdup(schemalocation);
     dtd_url = msStringConcatenate(dtd_url, "/wms/1.1.0/capabilities_1_1_0.dtd");
-  else {
+  /*TODO review wms1.3.0*/
+  else if (nVersion != OWS_1_3_0) {
     nVersion = OWS_1_1_1;
     /* this exception was added to accomadote the OGC test suite (Bug 1576)*/
@@ -1689,8 +1765,8 @@
       return msWMSException(map, nVersion, NULL);
-  if (nVersion <= OWS_1_0_7)
-      msIO_printf("Content-type: text/xml%c%c",10,10);  /* 1.0.0 to 1.0.7 */
+  if (nVersion <= OWS_1_0_7 || nVersion >= OWS_1_3_0)
+      msIO_printf("Content-type: text/xml%c%c",10,10);  /* 1.0.0 to 1.0.7 and >=1.3.0*/
   else
       msIO_printf("Content-type: application/vnd.ogc.wms_xml%c%c",10,10);  /* 1.1.0 and later */
@@ -1698,24 +1774,44 @@
                 "ISO-8859-1");
-  msIO_printf("<!DOCTYPE WMT_MS_Capabilities SYSTEM \"%s\"\n", dtd_url);
-  msIO_printf(" [\n");
-  /* some mapserver specific declarations will go here */
-  msIO_printf(" <!ELEMENT VendorSpecificCapabilities EMPTY>\n");
+  if ( nVersion < OWS_1_3_0)
+      msIO_printf("<!DOCTYPE WMT_MS_Capabilities SYSTEM \"%s\"\n", dtd_url);
+      msIO_printf(" [\n");
-  msIO_printf(" ]>  <!-- end of DOCTYPE declaration -->\n\n");
+      /* some mapserver specific declarations will go here */
+      msIO_printf(" <!ELEMENT VendorSpecificCapabilities EMPTY>\n");
-  msIO_printf("<WMT_MS_Capabilities version=\"%s\"",
-         msOWSGetVersionString(nVersion, szVersionBuf));
+      msIO_printf(" ]>  <!-- end of DOCTYPE declaration -->\n\n");
   updatesequence = msOWSLookupMetadata(&(map->web.metadata), "MO", "updatesequence");
+  if ( nVersion >= OWS_1_3_0)
+    msIO_printf("<WMS_Capabilities version=\"%s\"",
+                msOWSGetVersionString(nVersion, szVersionBuf));
+  else
+    msIO_printf("<WMT_MS_Capabilities version=\"%s\"",
   if (updatesequence)
     msIO_printf(" updateSequence=\"%s\"",updatesequence);
-  msIO_printf(">\n",updatesequence);
+  if ( nVersion == OWS_1_3_0)
+      msIO_printf("  xmlns=\"http://www.opengis.net/wms\""
+                  "   xmlns:sld=\"http://www.opengis.net/sld\""
+                  "   xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\""
+                  "   xsi:schemaLocation=\"http://www.opengis.net/wms %s/wms/%s/capabilities_1_3_0.xsd "
+                  " http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd\"",
+         msOWSGetSchemasLocation(map), msOWSGetVersionString(nVersion, szVersionBuf));
+  msIO_printf(">\n");
   /* Report MapServer Version Information */
   msIO_printf("\n<!-- %s -->\n\n", msGetVersion());
@@ -1725,8 +1821,11 @@
   /* Service name is defined by the spec and changed at v1.0.0 */
       msIO_printf("  <Name>GetMap</Name>\n");  /* v 1.0.0 to 1.0.7 */
+  else if (nVersion > OWS_1_0_7 && nVersion < OWS_1_3_0)
+      msIO_printf("  <Name>OGC:WMS</Name>\n"); /* v 1.1.0 to 1.1.1*/
   else
-      msIO_printf("  <Name>OGC:WMS</Name>\n"); /* v 1.1.0+ */
+      msIO_printf("  <Name>WMS</Name>\n"); /* v 1.3.0+ */
   /* the majority of this section is dependent on appropriately named metadata in the WEB object */
   msOWSPrintEncodeMetadata(stdout, &(map->web.metadata), "MO", "title",
@@ -1780,6 +1879,13 @@
                            "accessconstraints", OWS_NOERR,
                         "  <AccessConstraints>%s</AccessConstraints>\n", NULL);
+      /* LayerLimit not supported. No restriction in MapServer at this point*/
+      msIO_printf("  <MaxWidth>%d</MaxWidth>\n", map->maxsize);
+      msIO_printf("  <MaxHeight>%d</MaxHeight>\n", map->maxsize);
   msIO_printf("</Service>\n\n");
   /* WMS capabilities definitions */
@@ -1814,9 +1920,14 @@
     /* Note changes to the request names, their ordering, and to the formats */
-    msWMSPrintRequestCap(nVersion, "GetCapabilities", script_url_encoded,
-                    "application/vnd.ogc.wms_xml",
-                    NULL);
+      msWMSPrintRequestCap(nVersion, "GetCapabilities", script_url_encoded,
+                           "text/xml",
+                           NULL);
+    else
+                           "application/vnd.ogc.wms_xml",
+                           NULL);
     msGetOutputFormatMimeListWMS(map,mime_list,sizeof(mime_list)/sizeof(char*));
     msWMSPrintRequestCap(nVersion, "GetMap", script_url_encoded,
@@ -1852,22 +1963,38 @@
                        NULL);
-    msWMSPrintRequestCap(nVersion, "DescribeLayer", script_url_encoded,
-                         "text/xml",
-                         NULL);
+    if (nVersion == OWS_1_3_0)
+      msWMSPrintRequestCap(nVersion, "sld:DescribeLayer", script_url_encoded,
+                           "text/xml",
+                           NULL);
+    else
+      msWMSPrintRequestCap(nVersion, "DescribeLayer", script_url_encoded,
+                           "text/xml",
+                           NULL);
     msGetOutputFormatMimeListGD(map,mime_list,sizeof(mime_list)/sizeof(char*));
     if (nVersion >= OWS_1_1_1) {
-      msWMSPrintRequestCap(nVersion, "GetLegendGraphic", script_url_encoded,
+          msWMSPrintRequestCap(nVersion, "sld:GetLegendGraphic", script_url_encoded,
                     mime_list[0], mime_list[1], mime_list[2], mime_list[3],
                     mime_list[4], mime_list[5], mime_list[6], mime_list[7],
                     mime_list[8], mime_list[9], mime_list[10], mime_list[11],
                     mime_list[12], mime_list[13], mime_list[14], mime_list[15],
                     mime_list[16], mime_list[17], mime_list[18], mime_list[19],
                     NULL );
-      msWMSPrintRequestCap(nVersion, "GetStyles", script_url_encoded, "text/xml", NULL);
+        else
+            msWMSPrintRequestCap(nVersion, "GetLegendGraphic", script_url_encoded,
+                    mime_list[0], mime_list[1], mime_list[2], mime_list[3],
+                    mime_list[4], mime_list[5], mime_list[6], mime_list[7],
+                    mime_list[8], mime_list[9], mime_list[10], mime_list[11],
+                    mime_list[12], mime_list[13], mime_list[14], mime_list[15],
+                    mime_list[16], mime_list[17], mime_list[18], mime_list[19],
+                    NULL );
+            msWMSPrintRequestCap(nVersion, "GetStyles", script_url_encoded, "text/xml", NULL);
@@ -1879,6 +2006,9 @@
       msIO_printf("    <Format><BLANK /><INIMAGE /><WMS_XML /></Format>\n");
   else
+      /*allow text/xml for >=1.3.0*/
+        msIO_printf("    <Format>text/xml</Format>\n");
       msIO_printf("    <Format>application/vnd.ogc.se_xml</Format>\n");
       msIO_printf("    <Format>application/vnd.ogc.se_inimage</Format>\n");
@@ -1887,11 +2017,15 @@
   msIO_printf("  </Exception>\n");
-  msIO_printf("  <VendorSpecificCapabilities />\n"); /* nothing yet */
+  if (nVersion != OWS_1_3_0)
+    msIO_printf("  <VendorSpecificCapabilities />\n"); /* nothing yet */
   /* SLD support */
   if (nVersion >= OWS_1_0_7) {
-    msIO_printf("  <UserDefinedSymbolization SupportSLD=\"1\" UserLayer=\"0\" UserStyle=\"1\" RemoteWFS=\"0\"/>\n");
+        msIO_printf("  <sld:UserDefinedSymbolization SupportSLD=\"1\" UserLayer=\"0\" UserStyle=\"1\" RemoteWFS=\"0\" InlineFeature=\"0\" RemoteWCS=\"0\"/>\n");
+      else
+        msIO_printf("  <UserDefinedSymbolization SupportSLD=\"1\" UserLayer=\"0\" UserStyle=\"1\" RemoteWFS=\"0\"/>\n");
   /* Top-level layer with map extents and SRS, encloses all map layers */
@@ -1912,15 +2046,27 @@
   /* is REQUIRED.  It also suggests that we use an empty SRS element if there */
   /* is no common SRS. */
                                 msOWSGetEPSGProj(&(map->projection),
                                                  "MO", MS_FALSE),
+                                "    <CRS>%s</CRS>\n", "");
+      else
+                                msOWSGetEPSGProj(&(map->projection),
+                                                 "MO", MS_FALSE),
                                 "    <SRS>%s</SRS>\n", "");
   else
     msOWSPrintEncodeParam(stdout, "MAP.PROJECTION (or wms_srs metadata)",
@@ -1929,17 +2075,25 @@
                                              "MO", MS_FALSE),
                             OWS_WARN, "    <SRS>%s</SRS>\n", "");
-  msOWSPrintLatLonBoundingBox(stdout, "    ", &(map->extent),
+    msOWSPrintEX_GeographicBoundingBox(stdout, "    ", &(map->extent),
+  else
+    msOWSPrintLatLonBoundingBox(stdout, "    ", &(map->extent),
   msOWSPrintBoundingBox( stdout, "    ", &(map->extent), &(map->projection),
+                         &(map->web.metadata), "MO", nVersion);
     msWMSPrintAttribution(stdout, "    ", &(map->web.metadata), "MO");
-  msWMSPrintScaleHint("    ", map->web.minscaledenom, map->web.maxscaledenom,
-                      map->resolution);
+    msWMSPrintScaleHint("    ", map->web.minscaledenom, map->web.maxscaledenom,
+                        map->resolution);
+  else
+    msWMSPrintScaleDenominator("    ", map->web.minscaledenom, map->web.maxscaledenom);
@@ -2041,7 +2195,10 @@
   msIO_printf("  </Layer>\n");
   msIO_printf("</Capability>\n");
-  msIO_printf("</WMT_MS_Capabilities>\n");
+    msIO_printf("</WMS_Capabilities>\n");
+  else
+    msIO_printf("</WMT_MS_Capabilities>\n");
   free(script_url);
   free(script_url_encoded);
