[mapserver-commits] r8548 - sandbox/graphics
Fri Feb 13 01:27:11 EST 2009
Author: toby
Date: 2009-02-13 01:27:10 -0500 (Fri, 13 Feb 2009)
New Revision: 8548
   sandbox/graphics/mapogl.cpp
   sandbox/graphics/mapoglrenderer.cpp
   sandbox/graphics/mapoglrenderer.h
   sandbox/graphics/maprendering.c
   sandbox/graphics/mapserver.h
Opengl now supports tiled polygons. Modified vtable to support tiled
polygons with outlines.
Modified: sandbox/graphics/mapogl.cpp
--- sandbox/graphics/mapogl.cpp	2009-02-13 06:14:00 UTC (rev 8547)
+++ sandbox/graphics/mapogl.cpp	2009-02-13 06:27:10 UTC (rev 8548)
@@ -42,22 +42,10 @@
 	renderer->renderPolylineTile(p, width, (ogl_cache*)tile);
-void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, void *tile)
+void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile)
-	//	cairo_renderer *r = getCairoRenderer(img);
-	//	cairo_pattern_t *pattern = cairo_pattern_create_for_surface(tile);
-	//	cairo_pattern_set_extend(pattern, CAIRO_EXTEND_REPEAT);
-	//	int i,j;
-	//	cairo_set_source(r->cr, pattern);
-	//	for (i = 0; i < p->numlines; i++) {
-	//		lineObj *l = &(p->line[i]);
-	//		cairo_move_to(r->cr, l->point[0].x, l->point[0].y);
-	//		for (j = 1; j < l->numpoints; j++) {
-	//			cairo_line_to(r->cr, l->point[j].x, l->point[j].y);
-	//		//cairo_close_path(r->cr);
-	//	cairo_fill(r->cr);
+	OglRenderer* renderer = getOglRenderer(img);
+	renderer->renderPolygon(p, NULL, oc, outlineWidth, (ogl_cache*)tile);
 void msRenderPixmapOgl(imageObj *img, double x, double y, symbolObj *symbol,
@@ -221,7 +209,7 @@
 void msStartNewLayerOgl(imageObj *img, double opacity)
-	getOglRenderer(img)->setTransparency(1.0 - opacity);
+	getOglRenderer(img)->setTransparency(opacity/100);
 void msCloseNewLayerOgl(imageObj *img, double opacity)
Modified: sandbox/graphics/mapoglrenderer.cpp
--- sandbox/graphics/mapoglrenderer.cpp	2009-02-13 06:14:00 UTC (rev 8547)
+++ sandbox/graphics/mapoglrenderer.cpp	2009-02-13 06:27:10 UTC (rev 8548)
@@ -248,7 +248,7 @@
 void OglRenderer::setColor(colorObj *color)
-	if (color)
+	if (color && MS_VALID_COLOR(*color))
 		glColor4d((double) color->red / 255, (double) color->green / 255, (double) color->blue / 255, transparency);
@@ -528,7 +528,7 @@
 	glEnd();
-void OglRenderer::renderPolygon(shapeObj *p, colorObj *color, colorObj *outlinecolor, double outlinewidth, int lineCap, int joinStyle)
+void OglRenderer::renderPolygon(shapeObj *p, colorObj *color, colorObj *outlinecolor, double outlinewidth, ogl_cache* tile, int lineCap, int joinStyle)
 	 OpenGL cannot draw complex polygons so we need to use a Tessallator to draw the polygon using a GL_TRIANGLE_FAN
@@ -537,37 +537,49 @@
 	 Reports need for a combine callback.
+	double texWidth = 0;
+	double texHeight = 0;
+	if (tile)
+		glBindTexture(GL_TEXTURE_2D, tile->texture); // Select Our Texture
+		texWidth = tile->width;
+		texHeight = tile->height;
 	context->makeCurrent();
 	std::vector<GLdouble*> pointers;
-	if (color != NULL && MS_VALID_COLOR(*color))
+	setColor(color);
+	gluTessBeginPolygon(tess, NULL );
+	for (int j = 0; j < p->numlines; j++)
-		setColor(color);
-		gluTessBeginPolygon(tess, NULL );
-		for (int j = 0; j < p->numlines; j++)
+		gluTessBeginContour(tess);
+		for (int i = 0; i < p->line[j].numpoints; i++)
-			gluTessBeginContour(tess);
-			for (int i = 0; i < p->line[j].numpoints; i++)
-				// create temp array and place
-				GLdouble* dbls = new GLdouble[3];
-				pointers.push_back(dbls);
-				dbls[0] = p->line[j].point[i].x;
-				dbls[1] = p->line[j].point[i].y;
-				dbls[2] = 0.0;
-				gluTessVertex(tess, dbls, dbls);
-			gluTessEndContour(tess);
+			// create temp array and place
+			GLdouble* dbls = new GLdouble[5];
+			pointers.push_back(dbls);
+			dbls[0] = p->line[j].point[i].x;
+			dbls[1] = p->line[j].point[i].y;
+			dbls[2] = 0.0;
+			dbls[3] = texWidth;
+			dbls[4] = texHeight;
+			gluTessVertex(tess, dbls, dbls);
+		gluTessEndContour(tess);
-		gluTessEndPolygon(tess);
-		// destroy temp arrays
-		for (std::vector<GLdouble*>::iterator iter = pointers.begin(); iter
-				!= pointers.end(); iter++)
-			delete[] *iter;
+	gluTessEndPolygon(tess);
+	// destroy temp arrays
+	for (std::vector<GLdouble*>::iterator iter = pointers.begin(); iter
+			!= pointers.end(); iter++)
+		delete[] *iter;
+	glBindTexture(GL_TEXTURE_2D, 0); // Select Our Texture
 	if (outlinecolor != NULL && MS_VALID_COLOR(*outlinecolor) && outlinewidth > 0)
 		renderPolyline(p, outlinecolor, outlinewidth, 0, NULL, lineCap,
@@ -770,16 +782,18 @@
 		GLfloat weight[4], void** dataOut, void* polygon_data)
 	GLdouble *vertex;
-	vertex = (GLdouble *) malloc(6 * sizeof(GLdouble));
+	vertex = (GLdouble *) malloc(5 * sizeof(GLdouble));
 	vertex[0] = coords[0];
 	vertex[1] = coords[1];
 	vertex[2] = coords[2];
-	vertex[3] = vertex[4] = vertex[5] = 0;
+	vertex[3] = vertex_data[0][3];
+	vertex[4] = vertex_data[0][4];
 	*dataOut = vertex;
 void vertexCallback(GLdouble *vertex)
+	if (vertex[3] > 0) glTexCoord2d(vertex[0]/vertex[3], vertex[1]/vertex[4]);
 	glVertex3dv(vertex);
Modified: sandbox/graphics/mapoglrenderer.h
--- sandbox/graphics/mapoglrenderer.h	2009-02-13 06:14:00 UTC (rev 8547)
+++ sandbox/graphics/mapoglrenderer.h	2009-02-13 06:27:10 UTC (rev 8548)
@@ -28,7 +28,7 @@
     GLubyte* gd2ogl(gdImagePtr img);
 	void renderPolyline(shapeObj *p,colorObj *c, double width, int patternlength, int* pattern, int lineCap = MS_CJC_ROUND, int joinStyle = MS_CJC_ROUND, colorObj *outlinecolor = NULL, double outlinewidth = 0);
-	void renderPolygon(shapeObj*, colorObj *color, colorObj *outlinecolor, double outlinewidth, int lineCap=MS_CJC_ROUND, int joinStyle=MS_CJC_ROUND);
+	void renderPolygon(shapeObj*, colorObj *color, colorObj *outlinecolor, double outlinewidth, ogl_cache* tile = NULL, int lineCap=MS_CJC_ROUND, int joinStyle=MS_CJC_ROUND);
 	void renderGlyphs(double x, double y, colorObj *color, colorObj *outlinecolor, double size, char* font, char *thechars, double angle, colorObj *shadowcolor, double shdx, double shdy);
     void renderPixmap(symbolObj *symbol, double x, double y, double angle, double scale);
     void renderEllipse(double x, double y, double angle, double w, double h, colorObj *color, colorObj *outlinecolor, double outlinewidth);
Modified: sandbox/graphics/maprendering.c
--- sandbox/graphics/maprendering.c	2009-02-13 06:14:00 UTC (rev 8547)
+++ sandbox/graphics/maprendering.c	2009-02-13 06:27:10 UTC (rev 8548)
@@ -30,7 +30,7 @@
 			tile = r->createTileVector(symbol, scale, angle, c,bc,oc, width);
 			break;
 		case MS_SYMBOL_ELLIPSE:
-			tile = r->createTileEllipse(scale * symbol->sizex, scale * width, angle, c, bc, oc, scale * style->outlinewidth);
+			tile = r->createTileEllipse(scale * symbol->sizex, scale * symbol->sizey, angle, c, bc, oc, scale * style->outlinewidth);
 			break;
 		case MS_SYMBOL_TRUETYPE: {
 			char* font = msLookupHashTable(&(symbolset->fontset->fonts), symbol->font);
@@ -344,6 +344,7 @@
         	colorObj c = style->color;
         	colorObj oc = style->outlinecolor;
         	colorObj bc = style->backgroundcolor;
+        	double ow = style->outlinewidth == 0 ? 1.0 : style->outlinewidth;
         	c.alpha = MS_NINT(style->opacity*2.55);
         	oc.alpha = bc.alpha = c.alpha;
 			if (style->symbol >= symbolset->numsymbols || style->symbol < 0)
@@ -406,10 +407,13 @@
 				void *tile;
 				switch(symbol->type) {
+				case MS_SYMBOL_TRUETYPE:
+				case MS_SYMBOL_PIXMAP:
+				case MS_SYMBOL_ELLIPSE:
 				case MS_SYMBOL_VECTOR:
 					tile = getTile(image,symbolset,style,scaling,width,angle_radians);
-				r->renderPolygonTiled(image,offsetPolygon,tile);
+				r->renderPolygonTiled(image,offsetPolygon, &oc, ow, tile);
 			if (style->offsety == -99) {
Modified: sandbox/graphics/mapserver.h
--- sandbox/graphics/mapserver.h	2009-02-13 06:14:00 UTC (rev 8547)
+++ sandbox/graphics/mapserver.h	2009-02-13 06:27:10 UTC (rev 8548)
@@ -2349,7 +2349,7 @@
 imageObj* msImageCreateOgl(int width, int height, outputFormatObj *format, colorObj* bg);
 int msSaveImageOgl(imageObj *img, char *filename, outputFormatObj *format);
 void msDrawPolygonOgl(imageObj *img, shapeObj *p,colorObj *c, colorObj *oc, double outlineWidth);
-void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, void *tile);
+void msDrawPolygonTiledOgl(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile);
 void msDrawLineTiledOgl(imageObj *img, shapeObj *p, double width, void* tile);
 void msRenderGlyphsOgl(imageObj *img,double x, double y, colorObj *color, colorObj *outlinecolor,
             double size, char *font, char *thechars, double angle,
@@ -2401,7 +2401,7 @@
     imageObj* msImageCreateCairo(int width, int height, outputFormatObj *format, colorObj* bg);
     int msSaveImageCairo(imageObj *img, char *filename, outputFormatObj *format);
     void msDrawPolygonCairo(imageObj *img, shapeObj *p,colorObj *c, colorObj *oc, double outlineWidth);
-    void msDrawPolygonTiledCairo(imageObj *img, shapeObj *p, void *tile);
+    void msDrawPolygonTiledCairo(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile);
     void msRenderGlyphsCairo(imageObj *img,double x, double y, colorObj *color, colorObj *outlinecolor,
                 colorObj *shadowcolor, double shdx, double shdy,
@@ -2457,7 +2457,7 @@
     		double width, int patternlength, int* pattern);
     void (*renderPolygon)(imageObj *img, shapeObj *p, colorObj *c,
-    void (*renderPolygonTiled)(imageObj *img, shapeObj *p, void *tile);
+    void (*renderPolygonTiled)(imageObj *img, shapeObj *p, colorObj *oc, double outlineWidth, void *tile);
     void (*renderLineTiled)(imageObj *img, shapeObj *p, double width, void* tile);
     void (*renderGlyphs)(imageObj *img, double x, double y,
