[mapserver-commits] r8550 - trunk/mapserver
Fri Feb 13 17:30:14 EST 2009
Author: assefa
Date: 2009-02-13 17:30:14 -0500 (Fri, 13 Feb 2009)
New Revision: 8550
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapwms.c
Support CRS request for GetMap #473
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2009-02-13 20:00:45 UTC (rev 8549)
+++ trunk/mapserver/mapfile.c	2009-02-13 22:30:14 UTC (rev 8550)
@@ -1207,6 +1207,10 @@
       if( strcasecmp(id,"CRS84") == 0 )
           strcpy( init_string, "init=epsg:4326" );
+      if( strcasecmp(id,"CRS83") == 0 )
+          strcpy( init_string, "init=epsg:4269" );
+      if( strcasecmp(id,"CRS27") == 0 )
+          strcpy( init_string, "init=epsg:4267" );
       else
           msSetError( MS_PROJERR,
@@ -1220,6 +1224,28 @@
       p->args[0] = strdup(init_string);
       p->numargs = 1;
+  else if (strncasecmp(value, "CRS:",4) == 0 )
+      char init_string[100];
+      init_string[0] = '\0';
+      if (atoi(value+4) == 84)
+        strcpy( init_string, "init=epsg:4326");
+      else if (atoi(value+4) == 83)
+        strcpy( init_string, "init=epsg:4269");
+      else if (atoi(value+4) == 27)
+        strcpy( init_string, "init=epsg:4267");
+      else
+          msSetError( MS_PROJERR,
+                      "Unrecognised OGC CRS def '%s'.",
+                      "msLoadProjectionString()",
+                      value );
+          return -1;
+      p->args = (char**)malloc(sizeof(char*) * 2);
+      p->args[0] = strdup(init_string);
+      p->numargs = 1;
    * Handle old style comma delimited.  eg. "proj=utm,zone=11,ellps=WGS84".
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2009-02-13 20:00:45 UTC (rev 8549)
+++ trunk/mapserver/mapwms.c	2009-02-13 22:30:14 UTC (rev 8550)
@@ -387,6 +387,8 @@
   char *request = NULL;
   int status = 0;
+  char *bboxrequest=NULL;
    epsgbuf[0]='\0';
    srsbuffer[0]='\0';
@@ -510,14 +512,17 @@
         styles = values[i];
-    else if (strcasecmp(names[i], "SRS") == 0) {
+    else if (strcasecmp(names[i], "SRS") == 0 || strcasecmp(names[i], "CRS") == 0) {
       srsfound = 1;
       /* SRS is in format "EPSG:epsg_id" or "AUTO:proj_id,unit_id,lon0,lat0" */
       if (strncasecmp(values[i], "EPSG:", 5) == 0)
         /* SRS=EPSG:xxxx */
-          snprintf(srsbuffer, 100, "init=epsg:%.20s", values[i]+5);
+        /*don't need to copy init=xxx since the srsbudder is only
+          used with msLoadProjection and that does alreay the job*/
+        //snprintf(srsbuffer, 100, "init=epsg:%.20s", values[i]+5);
+          snprintf(srsbuffer, 100, "EPSG:%.20s",values[i]+5);
           snprintf(epsgbuf, 100, "EPSG:%.20s",values[i]+5);
         /* we need to wait until all params are read before */
@@ -532,7 +537,7 @@
           map->units = iUnits;
-      else if (strncasecmp(values[i], "AUTO:", 5) == 0)
+      else if (strncasecmp(values[i], "AUTO:", 5) == 0 && nVersion < OWS_1_3_0)
         snprintf(srsbuffer, 100, "%s",  values[i]);
         /* SRS=AUTO:proj_id,unit_id,lon0,lat0 */
@@ -545,12 +550,27 @@
+      else if (nVersion >= OWS_1_3_0 && (strncasecmp(values[i], "AUTO2:", 6) == 0 ||
+                                         strncasecmp(values[i], "CRS:", 4) == 0))
+          snprintf(srsbuffer, 100, "%s",  values[i]);
       else
-        msSetError(MS_WMSERR,
-                   "Unsupported SRS namespace (only EPSG and AUTO currently supported).",
-                   "msWMSLoadGetMapParams()");
-        return msWMSException(map, nVersion, "InvalidSRS");
+          if (nVersion >= OWS_1_3_0)
+              msSetError(MS_WMSERR,
+                         "Unsupported CRS namespace (only EPSG, AUTO2, CRS currently supported).",
+                         "msWMSLoadGetMapParams()");
+              return msWMSException(map, nVersion, "InvalidCRS");
+          else
+                         "Unsupported SRS namespace (only EPSG and AUTO currently supported).",
+              return msWMSException(map, nVersion, "InvalidSRS");
     else if (strcasecmp(names[i], "BBOX") == 0) {
@@ -563,23 +583,30 @@
         return msWMSException(map, nVersion, NULL);
-      map->extent.minx = atof(tokens[0]);
-      map->extent.miny = atof(tokens[1]);
-      map->extent.maxx = atof(tokens[2]);
-      map->extent.maxy = atof(tokens[3]);
+      bboxrequest = values[i];
-      msFreeCharArray(tokens, n);
+      /*for wms 1.3.0 we will do the validation of the bbox after all parameters
+       are read to account for the axes order*/
+      if (nVersion < OWS_1_3_0)
+          map->extent.minx = atof(tokens[0]);
+          map->extent.miny = atof(tokens[1]);
+          map->extent.maxx = atof(tokens[2]);
+          map->extent.maxy = atof(tokens[3]);
-      /* validate bbox values */
-      if ( map->extent.minx >= map->extent.maxx ||
-           map->extent.miny >=  map->extent.maxy)
-                   "Invalid values for BBOX.",
-          return msWMSException(map, nVersion, NULL);
+          msFreeCharArray(tokens, n);
+          /* validate bbox values */
+          if ( map->extent.minx >= map->extent.maxx ||
+               map->extent.miny >=  map->extent.maxy)
+                         "Invalid values for BBOX.",
+              return msWMSException(map, nVersion, NULL);
+          adjust_extent = MS_TRUE;
-      adjust_extent = MS_TRUE;
     else if (strcasecmp(names[i], "WIDTH") == 0) {
       widthfound = 1;
@@ -629,6 +656,51 @@
+   if (bboxfound && bboxrequest && nVersion >= OWS_1_3_0)
+       char **tokens;
+       int n;
+       rectObj rect;
+       projectionObj proj;
+       tokens = msStringSplit(bboxrequest, ',', &n);
+       /*we have already validated that the request format when reding
+        the request parameters*/
+       rect.minx = atof(tokens[0]);
+       rect.miny = atof(tokens[1]);
+       rect.maxx = atof(tokens[2]);
+       rect.maxy = atof(tokens[3]);
+       /*try to adjust the axes if necessary*/
+       if (srsbuffer && strlen(srsbuffer) > 1)
+            msInitProjection(&proj);
+            if (msLoadProjectionStringEPSG(&proj, (char *)srsbuffer) == 0)
+                msAxisNormalizePoints( &proj, 1, &rect.minx, &rect.miny );
+                msAxisNormalizePoints( &proj, 1, &rect.maxx, &rect.maxy );
+            msFreeProjection( &proj );
+       map->extent.minx = rect.minx;
+       map->extent.miny = rect.miny;
+       map->extent.maxx = rect.maxx;
+       map->extent.maxy = rect.maxy;
   ** If any select layers have a default time, we will apply the default
   ** time value even if no TIME request was in the url.
@@ -732,9 +804,18 @@
                   if (epsgvalid == MS_FALSE)
-                      msSetError(MS_WMSERR, "Invalid SRS given : SRS must be valid for all requested layers.",
+                          msSetError(MS_WMSERR, "Invalid CRS given : CRS must be valid for all requested layers.",
+                      else
+                          msSetError(MS_WMSERR, "Invalid SRS given : SRS must be valid for all requested layers.",
@@ -788,19 +869,38 @@
       if (map->projection.numargs <= 0)
-          msSetError(MS_WMSERR, "Cannot set new SRS on a map that doesn't "
-                     "have any projection set. Please make sure your mapfile "
-                     "has a projection defined at the top level.",
+              msSetError(MS_WMSERR, "Cannot set new CRS on a map that doesn't "
+                         "have any projection set. Please make sure your mapfile "
+                         "has a projection defined at the top level.",
+          else
+               msSetError(MS_WMSERR, "Cannot set new SRS on a map that doesn't "
       msInitProjection(&newProj);
-      if (srsbuffer != NULL && strlen(srsbuffer) > 1 &&
-          msLoadProjectionString(&newProj, srsbuffer) != 0)
+      if (srsbuffer != NULL && strlen(srsbuffer) > 1)
-          msFreeProjection(&newProj);
+          int nTmp;
+            nTmp = msLoadProjectionStringEPSG(&newProj, srsbuffer);
+          else
+            nTmp = msLoadProjectionString(&newProj, srsbuffer);
+          if (nTmp != 0)
+              msFreeProjection(&newProj);
       if (nonsquare_enabled ||
@@ -840,12 +940,18 @@
   /* that the srs given as parameter is valid for all layers */
-      if (msLoadProjectionString(&(map->projection), srsbuffer) != 0)
+      int nTmp;
+        nTmp = msLoadProjectionStringEPSG(&(map->projection), srsbuffer);
+      else
+        nTmp = msLoadProjectionString(&(map->projection), srsbuffer);
-        iUnits = GetMapserverUnitUsingProj(&(map->projection));
-        if (iUnits != -1)
-          map->units = iUnits;
+      if (nTmp != 0)
+      iUnits = GetMapserverUnitUsingProj(&(map->projection));
+      if (iUnits != -1)
+        map->units = iUnits;
   /* Validate Styles :
@@ -2547,9 +2653,9 @@
       info_format = values[i];
     else if (strcasecmp(names[i], "FEATURE_COUNT") == 0)
       feature_count = atoi(values[i]);
-    else if(strcasecmp(names[i], "X") == 0)
+    else if(strcasecmp(names[i], "X") == 0 || strcasecmp(names[i], "I") == 0)
       point.x = atof(values[i]);
-    else if (strcasecmp(names[i], "Y") == 0)
+    else if (strcasecmp(names[i], "Y") == 0 || strcasecmp(names[i], "J") == 0)
       point.y = atof(values[i]);
     else if (strcasecmp(names[i], "RADIUS") == 0)
@@ -2594,7 +2700,10 @@
   if(point.x == -1.0 || point.y == -1.0) {
-    msSetError(MS_WMSERR, "Required X/Y parameters missing for getFeatureInfo.", "msWMSFeatureInfo()");
+      msSetError(MS_WMSERR, "Required I/J parameters missing for getFeatureInfo.", "msWMSFeatureInfo()");
+    else
+      msSetError(MS_WMSERR, "Required X/Y parameters missing for getFeatureInfo.", "msWMSFeatureInfo()");
