[mapserver-commits] r8565 - sandbox/graphics
Tue Feb 17 08:54:57 EST 2009
Author: toby
Date: 2009-02-17 08:54:57 -0500 (Tue, 17 Feb 2009)
New Revision: 8565
   sandbox/graphics/mapoglrenderer.cpp
   sandbox/graphics/mapoglrenderer.h
Improved opengl texture quality by checking if non-power-of-2 sized textures are supported.
Modified: sandbox/graphics/mapoglrenderer.cpp
--- sandbox/graphics/mapoglrenderer.cpp	2009-02-17 13:06:35 UTC (rev 8564)
+++ sandbox/graphics/mapoglrenderer.cpp	2009-02-17 13:54:57 UTC (rev 8565)
@@ -30,15 +30,14 @@
 GLvoid CALLBACK vertexCallback(GLdouble *vertex);
 OglTexture::OglTexture(ms_uint32 width, ms_uint32 height, colorObj* color)
-	: OglRenderer(MS_MAX(MS_MIN(NextPowerOf2(width), OglContext::MAX_TEXTURE_SIZE), OglContext::MIN_TEXTURE_SIZE)+TEXTURE_BORDER,
-				  MS_MAX(MS_MIN(NextPowerOf2(height), OglContext::MAX_TEXTURE_SIZE), OglContext::MIN_TEXTURE_SIZE)+TEXTURE_BORDER)
+	: OglRenderer(getTextureSize(GL_TEXTURE_WIDTH, width)+TEXTURE_BORDER,
+				  getTextureSize(GL_TEXTURE_HEIGHT, height)+TEXTURE_BORDER)
-	this->width = width;
-	this->height = height;
-	this->transparency = 1.0;
-	this->pow2width = MS_MAX(MS_MIN(NextPowerOf2(width), OglContext::MAX_TEXTURE_SIZE), OglContext::MIN_TEXTURE_SIZE);
-	this->pow2height = MS_MAX(MS_MIN(NextPowerOf2(height), OglContext::MAX_TEXTURE_SIZE), OglContext::MIN_TEXTURE_SIZE);
+	this->pow2width = getWidth()-TEXTURE_BORDER;
+	this->pow2height = getHeight()-TEXTURE_BORDER;
+	this->textureWidth = width;
+	this->textureHeight = height;
 	glPushMatrix();
@@ -61,8 +60,8 @@
 	makeCurrent();
 	OglCache* tile = new OglCache();
 	tile->texture = createTexture(TEXTURE_BORDER/2, TEXTURE_BORDER/2);
-	tile->width = width;
-	tile->height = height;
+	tile->width = this->textureWidth;
+	tile->height = this->textureHeight;
 	return tile;
@@ -85,6 +84,21 @@
 	return texture;
+ms_uint32 OglTexture::getTextureSize(GLuint dimension, ms_uint32 value)
+	glTexImage2D(GL_PROXY_TEXTURE_2D, 0, GL_RGBA,  value, value, 0, GL_RGBA, GL_UNSIGNED_BYTE, NULL);
+    GLint check;
+    glGetTexLevelParameteriv(GL_PROXY_TEXTURE_2D, 0, dimension, &check);
+    if (check == 0)
+    	return MS_MAX(MS_MIN(NextPowerOf2(value), OglContext::MAX_TEXTURE_SIZE), OglContext::MIN_TEXTURE_SIZE);
+    else
+    	return value;
 OglRenderer::OglRenderer(ms_uint32 width, ms_uint32 height, colorObj* color)
 	int viewPort[4];
@@ -339,7 +353,6 @@
 	glPopMatrix();
 	glBindTexture(GL_TEXTURE_2D, 0);
 	glDisable(GL_SAMPLE_ALPHA_TO_COVERAGE_ARB);
-	int error = glGetError();
 void OglRenderer::renderPolylineTile(shapeObj *shape, OglCache* tile){
Modified: sandbox/graphics/mapoglrenderer.h
--- sandbox/graphics/mapoglrenderer.h	2009-02-17 13:06:35 UTC (rev 8564)
+++ sandbox/graphics/mapoglrenderer.h	2009-02-17 13:54:57 UTC (rev 8565)
@@ -95,12 +95,13 @@
 	~OglTexture();
 	OglCache* renderToTile();
 private:
-	int width;
-	int height;
-	int pow2width;
-	int pow2height;
+	ms_uint32 textureWidth;
+	ms_uint32 textureHeight;
+	ms_uint32 pow2width;
+	ms_uint32 pow2height;
 	double scaleWidth;
 	double scaleHeight;
+	ms_uint32 getTextureSize(GLuint dimension, ms_uint32 value);
 	GLuint NextPowerOf2(GLuint in);
 	GLuint createTexture(ms_uint32 x, ms_uint32 y);
 	static ms_uint32 TEXTURE_BORDER;
