[mapserver-commits] r8578 - in trunk/docs: input/vector mapfile
Wed Feb 18 16:24:03 EST 2009
Author: jmckenna
Date: 2009-02-18 16:24:03 -0500 (Wed, 18 Feb 2009)
New Revision: 8578
   trunk/docs/input/vector/ogr.txt
   trunk/docs/mapfile/layer.txt
add styleitemauto label styles section to ogr doc, and update mapfile layer processing section (ticket:2719)
Modified: trunk/docs/input/vector/ogr.txt
--- trunk/docs/input/vector/ogr.txt	2009-02-18 16:38:50 UTC (rev 8577)
+++ trunk/docs/input/vector/ogr.txt	2009-02-18 21:24:03 UTC (rev 8578)
@@ -5,10 +5,9 @@
 :Author:       Jeff McKenna
-:Contact:      jeffmckenna at gmail.com
+:Contact:      jmckenna at gatewaygeomatics.com
 :Revision: $Revision$
 :Date: $Date$
-:Last Updated: 2008/06/20
 .. contents:: Table of Contents
     :depth: 2
@@ -70,20 +69,32 @@
 formats. At the date this document was written, the following formats were
 supported:
-- `ArcInfo Coverages`_
+- `ArcInfo Binary Coverages`_
+- `ArcInfo E00 Coverages`_
+- `Atlas BNA`_
 - `Comma Separated Value (.csv)`_
 - `DODS/OPeNDAP`_
+- `ESRI ArcSDE`_
 - `ESRI Personal GeoDatabase`_
 - `ESRI Shapefiles`_
 - `FMEObjects Gateway`_
+- `Géoconcept Export`_
+- `GeoJSON`_
+- `GeoRSS`_
 - `GML`_
+- `GMT`_
 - `GRASS`_
+- `GPX`_
+- `Informix DataBlade`_
+- `INGRES`_
 - `INTERLIS`_
+- `KML`_
 - `MapInfo files`_
+- `Memory`_
 - `Microstation DGN files`_
 - `MySQL`_
+- `ODBC`_
 - `OGDI Vectors`_
-- `ODBC`_
 - `Oracle Spatial`_
 - `PostgreSQL`_
 - `SDTS`_
@@ -91,6 +102,7 @@
 - `UK.NTF (National Transfer Format)`_
 - `US Census TIGER/Line`_
 - `VRT - Virtual Datasource`_
+- `X-Plane/Flighgear aeronautical data`_
 .. note::
@@ -175,13 +187,13 @@
 The .map file LAYER definition for file-based sources is as follows:
+.. code-block:: mapfile
       LAYER
          CONNECTIONTYPE OGR
          CONNECTION "<datasource_name>"
-               DATA "<layer_definition>"
+         DATA "<layer_definition>"
       END
@@ -241,7 +253,7 @@
 **Example 1. MapInfo TAB file**
       LAYER
          NAME "Builtup_Areas_tab"
@@ -260,7 +272,7 @@
 The entire DGN file is represented in OGR as one layer (see the `DGN driver
 page`_ for more details):
       LAYER
          NAME "dgn"
@@ -276,7 +288,7 @@
 **Example 3. TIGER/Line file using <layer_name>**
       LAYER
          NAME "Roads_tig"
@@ -292,7 +304,7 @@
 **Example 4. Directory of Shapefiles using SQL JOIN**
       LAYER
          NAME "Parks_cov"
@@ -455,7 +467,7 @@
 The following is a simple example of a point layer using a tile index.
    LAYER
      NAME "ogr_points"
@@ -464,9 +476,12 @@
      TILEINDEX "PIP_ogr_tiles.shp,0"
      STATUS ON
      CLASS
-        SYMBOL "default-circle"
-        COLOR 255 0 0
-        SIZE 6
+        NAME "points"
+        STYLE
+          SYMBOL "default-circle"
+          COLOR 255 0 0
+          SIZE 6
+        END
      END
    END
@@ -501,7 +516,7 @@
 till layer. In the second (or last) layer we request NORMAL connection handling
 (though this could have been left out as normal handling is the default).
     LAYER
        NAME "AdminAreas"
@@ -576,8 +591,9 @@
 **Example 10. Layer Definition Using STYLEITEM "AUTO" without a CLASSITEM**
     LAYER
        NAME "test_dgn"
        STATUS ON
@@ -597,7 +613,7 @@
 **Example 11. Layer Definition Using STYLEITEM "AUTO" with a CLASSITEM**
     LAYER
@@ -733,7 +749,62 @@
     2. If TTF fonts are not supported or if all above cases failed, then BITMAP
        MEDIUM font will be used.
+.. _styleitemauto-label-styles:
+Accessing OGR STYLEITEMAUTO Label Styles Through MapScript
+OGR STYLEITEMAUTO label styles can be accessed through MapScript, such as
+PHP/MapScript's getshape() or getvalue() methods, by setting the LAYER's PROCESSING
+parameter to "GETSHAPE_STYLE_ITEMS=all".  Therefore, the LAYER may contain:
+  LAYER
+    PROCESSING "GETSHAPE_STYLE_ITEMS=all"
+  END
+The following label styles are supported:
+Label Style         Description
+OGR:LabelFont       Comma-delimited list of fonts names
+OGR:LabelSize       Numeric value with units
+OGR:LabelText       Label text string
+OGR:LabelAngle      Rotation angle (in degrees)
+OGR:LabelFColor     Foreground color
+OGR:LabelBColor     Background color
+OGR:LabelPlacement  How is the text drawn
+                    relative to the feature's geometry
+OGR:LabelAnchor     A value from 1 to 12 defining the
+                    label's position relative to the
+                    point to which it is attached.
+OGR:LabelDx         X offset
+OGR:LabelDy         Y offset
+OGR:LabelPerp       Perpendicular offset
+OGR:LabelBold       Bold text
+OGR:LabelItalic     Italic text
+OGR:LabelUnderline  Underlined text
+OGR:LabelPriority   Numeric value defining the order
+                    in which style parts should be
+                    drawn.
+OGR:LabelStrikeout  Strike out text
+OGR:LabelStretch    Stretch factor changes the width
+                    of all characters in the font by
+                    factor percent.
+OGR:LabelAdjHor     Horizontally adjacent text
+OGR:LabelAdjVert    Vertically adjacent text
+OGR:LabelHColor     Shadow color (gdal > 1.4.0)
+OGR:LabelOColor     Outline color (gdal > 1.6.0)
+Please see the `OGR Feature Style Specification`_ document for more details
+on those specific styles.
 Sample Sites Using OGR/MapServer
@@ -794,18 +865,30 @@
 .. _`FWTools`: http://fwtools.maptools.org/
 .. _`MS4W`: http://www.maptools.org/ms4w/
-.. _`ArcInfo Coverages`: http://www.gdal.org/ogr/drv_avcbin.html
+.. _`ArcInfo Binary Coverages`: http://www.gdal.org/ogr/drv_avcbin.html
+.. _`ArcInfo E00 Coverages`: http://www.gdal.org/ogr/drv_avce00.html
+.. _`Atlas BNA`: http://www.gdal.org/ogr/drv_bna.html
 .. _`Comma Separated Value (.csv)`: http://www.gdal.org/ogr/drv_csv.html
 .. _`DODS/OPeNDAP`: http://www.gdal.org/ogr/drv_dods.html
 .. _`DWG`: http://www.gdal.org/ogr/drv_dxfdwg.html
 .. _`DXF`: http://www.gdal.org/ogr/drv_dxfdwg.html
+.. _`ESRI ArcSDE`: http://www.gdal.org/ogr/drv_sde.html
 .. _`ESRI Personal GeoDatabase`: http://www.gdal.org/ogr/drv_pgeo.html
 .. _`ESRI Shapefiles`: http://www.gdal.org/ogr/drv_shapefile.html
 .. _`FMEObjects Gateway`: http://www.gdal.org/ogr/drv_fme.html
 .. _`GML`: http://www.gdal.org/ogr/drv_gml.html
+.. _`GMT`: http://www.gdal.org/ogr/drv_gmt.html
+.. _`Géoconcept Export`: http://www.gdal.org/ogr/drv_geoconcept.html
+.. _`GeoJSON`: http://www.gdal.org/ogr/drv_geojson.html
+.. _`GeoRSS`: http://www.gdal.org/ogr/drv_georss.html
+.. _`GPX`: http://www.gdal.org/ogr/drv_gpx.html
 .. _`GRASS`: http://www.gdal.org/ogr/drv_grass.html
+.. _`Informix DataBlade`: http://www.gdal.org/ogr/drv_idb.html
+.. _`INGRES`: http://www.gdal.org/ogr/drv_ingres.html
 .. _`INTERLIS`: http://www.gdal.org/ogr/drv_ili.html
+.. _`KML`: http://www.gdal.org/ogr/drv_kml.html
 .. _`MapInfo files`: http://www.gdal.org/ogr/drv_mitab.html
+.. _`Memory`: http://www.gdal.org/ogr/drv_memory.html
 .. _`Microstation DGN files`: http://www.gdal.org/ogr/drv_dgn.html
 .. _`MySQL`: http://www.gdal.org/ogr/drv_mysql.html
 .. _`OGDI Vectors`: http://www.gdal.org/ogr/drv_ogdi.html
@@ -817,11 +900,13 @@
 .. _`UK.NTF (National Transfer Format)`: http://www.gdal.org/ogr/drv_ntf.html
 .. _`US Census TIGER/Line`: http://www.gdal.org/ogr/drv_tiger.html
 .. _`VRT - Virtual Datasource`: http://www.gdal.org/ogr/drv_vrt.html
+.. _`X-Plane/Flighgear aeronautical data`: http://www.gdal.org/ogr/drv_xplane.html
 .. _`GDAL mailing list`: http://lists.osgeo.org/mailman/listinfo/gdal-dev
 .. _`OGR page`: http://www.gdal.org/ogr/
 .. _`FGS`: http://www.maptools.org/fgs/
 .. _`OGR formats page`: http://www.gdal.org/ogr/ogr_formats.html
 .. _`DGN driver page`: http://www.gdal.org/ogr/drv_dgn.html
-.. _`OGR Utilities Page`: http://www.gdal.org/ogr/ogr_utilities.html
+.. _`OGR Utilities Page`: http://www.gdal.org/ogr_utilities.html
 .. _`GDAL Wiki`: http://trac.osgeo.org/gdal/wiki/
+.. _`OGR Feature Style Specification`: http://www.gdal.org/ogr/ogr_feature_style.html
Modified: trunk/docs/mapfile/layer.txt
--- trunk/docs/mapfile/layer.txt	2009-02-18 16:38:50 UTC (rev 8577)
+++ trunk/docs/mapfile/layer.txt	2009-02-18 21:24:03 UTC (rev 8578)
@@ -359,35 +359,46 @@
 PROCESSING [string]
     Passes a processing directive to be used with this layer. The supported
     processing directives vary by layer type, and the underlying driver that
-    processes them. Here we see the SCALE and BANDs directivMap Scalees used to
-    autoscale raster data and alter the band mapping.  All raster processing
-    options are described in :ref:`raster`.
-    .. code-block:: mapfile
+    processes them.
+    - **Attributes Directive** - The ITEMS processing option allows to
+      specify the name of attributes for inline layers or specify the subset
+      of the attributes to be used by the layer, such as:
-        PROCESSING "SCALE=AUTO"
-        PROCESSING "BANDS=3,2,1"
+      .. code-block:: mapfile
-    This is also where you can enable connection pooling for certain layer
-    layer types. Connection pooling will allow MapServer to share the handle
-    to an open database or layer connection throughout a single map draw
-    process. Additionally, if you have FastCGI enabled, the connection handle
-    will stay open indefinitely, or according to the options specified in the
-    :ref:`FastCGI <fastcgi>` configuration. :ref:`oci`, :ref:`arcsde`,
-    :ref:`ogr` and :ref:`input_postgis` currently support this approach.
+          PROCESSING "ITEMS=itemname1,itemname2,itemname3"
+    - **Connection Pooling Directive** - This is where you can enable
+      connection pooling for certain layer layer types. Connection pooling
+      will allow MapServer to share the handle to an open database or layer
+      connection throughout a single map draw process. Additionally, if you
+      have FastCGI enabled, the connection handle will stay open indefinitely,
+      or according to the options specified in the
+      :ref:`FastCGI <fastcgi>` configuration. :ref:`oci`, :ref:`arcsde`,
+      :ref:`ogr` and :ref:`input_postgis` currently support this approach.
-        PROCESSING "CLOSE_CONNECTION=DEFER"
+          PROCESSING "CLOSE_CONNECTION=DEFER"
+    - **OGR Styles Directive** - This directive can be used for obtaining
+      label styles through MapScript.  For more information see the
+      :ref:`MapServer's OGR document <styleitemauto-label-styles>`.
+    - **Raster Directives** - All raster processing options are described
+      in :ref:`raster`.  Here we see the SCALE and BANDs directives used to
+      autoscale raster data and alter the band mapping.
-    The ITEMS processing option allows to specify the name of attributes
-    for inline layers or specify the subset of the attributes to be used by
-    the layer, like:
+          PROCESSING "SCALE=AUTO"
+          PROCESSING "BANDS=3,2,1"
-        PROCESSING "ITEMS=itemname1,itemname2,itemname3"
 :ref:`PROJECTION`
     Signals the start of a :ref:`PROJECTION` object.
