[mapserver-commits] r8581 - trunk/docs/mapfile
Wed Feb 18 17:07:22 EST 2009
Author: jmckenna
Date: 2009-02-18 17:07:22 -0500 (Wed, 18 Feb 2009)
New Revision: 8581
   trunk/docs/mapfile/label.txt
darn, added the ms version change late again
Modified: trunk/docs/mapfile/label.txt
--- trunk/docs/mapfile/label.txt	2009-02-18 22:03:28 UTC (rev 8580)
+++ trunk/docs/mapfile/label.txt	2009-02-18 22:07:22 UTC (rev 8581)
@@ -173,11 +173,11 @@
     MapServer to calculate a label position that will not interfere with other
     labels. With points, MapServer selects from the 8 outer
     positions (i.e. excluding cc). With polygons, MapServer selects from
-    cc, uc, lc, cl and cr as possible positions.  With lines, it only uses
-    lc or uc, until it finds a position that doesn't collide with labels that
-    have already been drawn. If all positions cause a conflict, then the
-    label is not drawn (Unless the label's FORCE_ a parameter is set to "true").
-    "Auto" placement is only available with cached labels.
+    cc (added in MapServer 5.4), uc, lc, cl and cr as possible positions.
+    With lines, it only uses lc or uc, until it finds a position that doesn't
+    collide with labels that have already been drawn. If all positions cause
+    a conflict, then the label is not drawn (Unless the label's FORCE_ a
+    parameter is set to "true"). "Auto" placement is only available with cached labels.
 PRIORITY [integer]|[item_name]
      The priority parameter (added in v5.0) takes an integer value between 1
