[mapserver-commits] r8607 - trunk/docs/cgi
Mon Feb 23 14:07:54 EST 2009
Author: hobu
Date: 2009-02-23 14:07:54 -0500 (Mon, 23 Feb 2009)
New Revision: 8607
   trunk/docs/cgi/runsub.txt
add Steve's note about runtime substitution of FILTERs
Modified: trunk/docs/cgi/runsub.txt
--- trunk/docs/cgi/runsub.txt	2009-02-22 22:35:13 UTC (rev 8606)
+++ trunk/docs/cgi/runsub.txt	2009-02-23 19:07:54 UTC (rev 8607)
@@ -68,3 +68,34 @@
 * LAYER: CONNECTION
 * LAYER: FILTER
 * CLASS EXPRESSION
+FILTERs
+You can use runtime substitutions to change values within a FILTER as you go.
+For example your FILTER could be written like so::
+    FILTER ("multimedia='[multimedia]' and seats >= [nseats] and Sound= '[sound]')
+Then (assuming you're using the CGI interface) you could pass in variables
+named multimedia, nseats and sound with values defined by the user in an HTML
+form.
+You should also define validation expressions on these variables to guard
+against unintentional SQL being submitted to postgis. Within the layer
+metadata you'd do the following:
+.. code-block:: mapfile
+    METADATA
+        'multimedia_validation_string' '^yes|no$'
+        'sound_validation_string' '^yes|no$'
+        'nseats_validation_string' '^[0-9]{1,2}$'
+        '... more metadata ...'
+    END
+The validation strings are regular expressions that are applied against the
+appropriate variable value before being added to the FILTER. The first two
+limit the value of multimedia and sound to yes or no. The third limits the
+value for nseats to a 2 digit integer.
