[mapserver-commits] r8612 - trunk/msautotest/wxs/expected
Wed Feb 25 19:16:32 EST 2009
Author: tomkralidis
Date: 2009-02-25 19:16:31 -0500 (Wed, 25 Feb 2009)
New Revision: 8612
   trunk/msautotest/wxs/expected/wms_cap.xml
   trunk/msautotest/wxs/expected/wms_cap130.xml
   trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml
   trunk/msautotest/wxs/expected/wms_describe.xml
   trunk/msautotest/wxs/expected/wms_describelayer130.xml
   trunk/msautotest/wxs/expected/wms_exception130.xml
   trunk/msautotest/wxs/expected/wms_exception_updatesequence1.xml
   trunk/msautotest/wxs/expected/wms_exception_updatesequence2.xml
   trunk/msautotest/wxs/expected/wms_getschemaex.xml
   trunk/msautotest/wxs/expected/wms_version_exception.xml
updated schema pointer per r8611 (#473)
Modified: trunk/msautotest/wxs/expected/wms_cap.xml
(Binary files differ)
Modified: trunk/msautotest/wxs/expected/wms_cap130.xml
--- trunk/msautotest/wxs/expected/wms_cap130.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_cap130.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 Content-type: text/xml
 <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
-<WMS_Capabilities version="1.3.0" updateSequence="123"  xmlns="http://www.opengis.net/wms"   xmlns:sld="http://www.opengis.net/sld"   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"   xsi:schemaLocation="http://www.opengis.net/wms http://ogc.dmsolutions.ca/wms/1.3.0/capabilities_1_3_0.xsd  http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd  http://mapserver.gis.umn.edu/mapserver http://localhost/path/to/wms_simple?service=WMS&amp;version=1.3.0&amp;request=GetSchemaExtension">
+<WMS_Capabilities version="1.3.0" updateSequence="123"  xmlns="http://www.opengis.net/wms"   xmlns:sld="http://www.opengis.net/sld"   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"   xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd  http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/sld_capabilities.xsd  http://mapserver.gis.umn.edu/mapserver http://localhost/path/to/wms_simple?service=WMS&amp;version=1.3.0&amp;request=GetSchemaExtension">
 <Service>
   <Name>WMS</Name>
Modified: trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml
--- trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_caps_updatesequence.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 Content-type: application/vnd.ogc.wms_xml
-<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://ogc.dmsolutions.ca/wms/1.1.1/capabilities_1_1_1.dtd"
+<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
  <!ELEMENT VendorSpecificCapabilities EMPTY>
  ]>  <!-- end of DOCTYPE declaration -->
Modified: trunk/msautotest/wxs/expected/wms_describe.xml
Modified: trunk/msautotest/wxs/expected/wms_describelayer130.xml
--- trunk/msautotest/wxs/expected/wms_describelayer130.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_describelayer130.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 <?xml version='1.0' encoding="ISO-8859-1"?>
-<DescribeLayerResponse xmlns="http://www.opengis.net/sld" xmlns:ows="http://www.opengis.net/ows" xmlns:se="http://www.opengis.net/se" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/sld http://ogc.dmsolutions.ca/sld/1.1.0/DescribeLayer.xsd">
+<DescribeLayerResponse xmlns="http://www.opengis.net/sld" xmlns:ows="http://www.opengis.net/ows" xmlns:se="http://www.opengis.net/se" xmlns:wfs="http://www.opengis.net/wfs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/DescribeLayer.xsd">
 <Version>1.1.0</Version>
   <LayerDescription>
     <owsType>wfs</owsType>
Modified: trunk/msautotest/wxs/expected/wms_exception130.xml
--- trunk/msautotest/wxs/expected/wms_exception130.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_exception130.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
-<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://ogc.dmsolutions.ca/wms/1.3.0/exceptions_1_3_0.xsd">
+<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
 <ServiceException code="LayerNotDefined">
 msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
 </ServiceException>
Modified: trunk/msautotest/wxs/expected/wms_exception_updatesequence1.xml
--- trunk/msautotest/wxs/expected/wms_exception_updatesequence1.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_exception_updatesequence1.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 Content-type: application/vnd.ogc.se_xml
-<!DOCTYPE ServiceExceptionReport SYSTEM "http://ogc.dmsolutions.ca/wms/1.1.1/exception_1_1_1.dtd">
+<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
 <ServiceExceptionReport version="1.1.1">
 <ServiceException code="CurrentUpdateSequence">
 msWMSGetCapabilities(): WMS server error. UPDATESEQUENCE parameter (123) is equal to server (123)
Modified: trunk/msautotest/wxs/expected/wms_exception_updatesequence2.xml
--- trunk/msautotest/wxs/expected/wms_exception_updatesequence2.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_exception_updatesequence2.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 <ServiceException code="InvalidUpdateSequence">
 msWMSGetCapabilities(): WMS server error. UPDATESEQUENCE parameter (876) is higher than server (123)
Modified: trunk/msautotest/wxs/expected/wms_getschemaex.xml
--- trunk/msautotest/wxs/expected/wms_getschemaex.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_getschemaex.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -2,6 +2,6 @@
 <schema xmlns="http://www.w3.org/2001/XMLSchema" xmlns:wms="http://www.opengis.net/wms" xmlns:ms="http://mapserver.gis.umn.edu/mapserver" targetNamespace="http://mapserver.gis.umn.edu/mapserver" elementFormDefault="qualified" version="1.0.0">
-  <import namespace="http://www.opengis.net/wms" schemaLocation="http://ogc.dmsolutions.ca/wms/1.3.0/capabilities_1_3_0.xsd"/>
+  <import namespace="http://www.opengis.net/wms" schemaLocation="http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd"/>
   <element name="GetStyles" type="wms:OperationType" substitutionGroup="wms:_ExtendedOperation"/>
 </schema>
\ No newline at end of file
Modified: trunk/msautotest/wxs/expected/wms_version_exception.xml
--- trunk/msautotest/wxs/expected/wms_version_exception.xml	2009-02-25 13:32:19 UTC (rev 8611)
+++ trunk/msautotest/wxs/expected/wms_version_exception.xml	2009-02-26 00:16:31 UTC (rev 8612)
@@ -1,7 +1,7 @@
 <ServiceException>
 msOWSParseVersionString(): OWS error. Invalid version (1). Version must be in the format &#39;x.y&#39; or &#39;x.y.z&#39;
