[mapserver-commits] r8374 - trunk/docs/ogc
Fri Jan 2 10:09:01 EST 2009
Author: tomkralidis
Date: 2009-01-02 10:09:01 -0500 (Fri, 02 Jan 2009)
New Revision: 8374
   trunk/docs/ogc/wms_server.txt
fix mime type info
Modified: trunk/docs/ogc/wms_server.txt
--- trunk/docs/ogc/wms_server.txt	2009-01-02 15:08:30 UTC (rev 8373)
+++ trunk/docs/ogc/wms_server.txt	2009-01-02 15:09:01 UTC (rev 8374)
@@ -35,7 +35,7 @@
 Links to WMS-Related Information
-- :ref:`MapServer WMS Client HowTo <wms_client>`
+- :ref:`MapServer WMS Client Howto <wms_client>`
 - `WMS 1.1.1 specification`_
 - `Open Geospatial Consortium (OGC)`_ home page
 - `WMS-Dev mailing list and archive`_
@@ -43,7 +43,8 @@
 - `WMS XML Capabilities validator`_
 - `WMS Cookbook`_
 - `MapServer OGC Web Services Workshop`_ package
-- :ref:`MapServer Styled Layer Descriptor (SLD) HowTo <sld>`
+- :ref:`MapServer Styled Layer Descriptor (SLD) Howto <sld>`
+- :ref:`MapServer WMS Time Support Howto <wms_time>`
 How does a WMS Work
@@ -65,13 +66,13 @@
 1. **GetFeatureInfo:** return info about feature(s) at a query (mouse click) location.
    MapServer supports 3 types of responses to this request:
-   - Text/plain output with attribute info.
+   - text/plain output with attribute info.
-   - Text/html output using MapServer query templates specified in the CLASS
+   - text/html output using MapServer query templates specified in the CLASS
      template parameter. The MIME type returned by the Class templates defaults
      to text/html and can be controlled using the metadata "wms_feature_info_mime_type".
-   - Gml features.
+   - application/vnd.ogc.gml, GML.1 or GML for GML features.
 2. **DescribeLayer:** return an XML description of one or more map layers. To execute this:
@@ -403,7 +404,7 @@
 If you don't have your own WMS client installed already, here are a few pointers:
-- MapServer itself can be used as a WMS client, see the :ref:`MapServer WMS Client HowTo <wms_client>`.
+- MapServer itself can be used as a WMS client, see the :ref:`MapServer WMS Client Howto <wms_client>`.
 - `Deegree`_ provides a WMS client.
@@ -757,7 +758,7 @@
 - *Description:* The time format to be used when a request is sent. (e.g.
   "wms_timeformat" "%Y-%m-%d %H, %Y-%m-%d %H:%M"). Please see the :ref:`WMS
-  Time Support HowTo <wms_time>` for more information.
+  Time Support Howto <wms_time>` for more information.
 **wms_title**
@@ -1042,20 +1043,20 @@
 - *Description:* (Optional for Time Support) This value is used if it is
   defined and the Time value is missing in the request. Please see the
-  :ref:`WMS Time Support HowTo <wms_time>` for more information.
+  :ref:`WMS Time Support Howto <wms_time>` for more information.
 **wms_timeextent**
 - *Description:* (Mandatory for Time Support) This is used in the capabilities
   to return the valid time values for the layer. The value defined here should
-  be a valid time range. Please see the :ref:`WMS Time Support HowTo
+  be a valid time range. Please see the :ref:`WMS Time Support Howto
 **wms_timeitem**
 - *Description:* (Mandatory for Time Support) This is the name of the field in
   the DB that contains the time values. Please see the :ref:`WMS Time Support
-  HowTo <wms_time>` for more information.
+  Howto <wms_time>` for more information.
 **wms_title**
