[mapserver-commits] r8379 - trunk/docs/installation
Fri Jan 2 12:40:16 EST 2009
Author: jmckenna
Date: 2009-01-02 12:40:16 -0500 (Fri, 02 Jan 2009)
New Revision: 8379
   trunk/docs/installation/unix.txt
correct libproj and libgeotiff links, use common header
Modified: trunk/docs/installation/unix.txt
--- trunk/docs/installation/unix.txt	2009-01-02 17:29:01 UTC (rev 8378)
+++ trunk/docs/installation/unix.txt	2009-01-02 17:40:16 UTC (rev 8379)
@@ -4,13 +4,12 @@
  Compiling on Unix
-:Release: 5.2
-:Revision: $Revision$
-:Date: $Date$
 :Author: J.F. Doyon
 :Contact: jdoyon at nrcan.gc.ca
 :Author: Howard Butler
 :Contact: hobu.inc at gmail.com
+:Revision: $Revision$
+:Date: $Date$
 .. contents:: Table of Contents
     :depth: 2
@@ -57,7 +56,7 @@
-* `libproj <http://proj.maptools.org/>`__: libproj provides projection
+* `libproj <http://trac.osgeo.org/proj/>`__: libproj provides projection
   support for MapServer.  Version 4.4.6 or greater is required.
 * `libcurl <http://curl.haxx.se/libcurl/>`__: libcurl is the foundation of
   OGC (WFS/WMS/WCS) client and server support.  Version 7.10 or greater is
@@ -78,7 +77,7 @@
 * `libtiff <http://www.libtiff.org/>`__: libtiff provides TIFF
   (Tagged Image File Format) reading support to MapServer.
-* `libgeotiff <http://www.remotesensing.org/geotiff/geotiff.html>`__
+* `libgeotiff <http://trac.osgeo.org/geotiff/>`__
   libgeotiff provides support to read GeoTIFF files (TIFF files with
   geographic referencing).
