[mapserver-commits] r8384 - trunk/docs/installation
Sat Jan 3 11:22:06 EST 2009
Author: jmckenna
Date: 2009-01-03 11:22:06 -0500 (Sat, 03 Jan 2009)
New Revision: 8384
   trunk/docs/installation/dotnet.txt
some more mapscript references
Modified: trunk/docs/installation/dotnet.txt
--- trunk/docs/installation/dotnet.txt	2009-01-03 16:19:20 UTC (rev 8383)
+++ trunk/docs/installation/dotnet.txt	2009-01-03 16:22:06 UTC (rev 8384)
@@ -12,7 +12,7 @@
 Compilation
-Before compiling C# mapscript you should compile MapServer with the options
+Before compiling C# MapScript you should compile MapServer with the options
 for your requirements. For more information about the compilation of
 MapServer please see :ref:`Win32 Compilation and Installation Guide <win32>`.
 It is highly recommended to minimize the library dependency of your application,
@@ -25,7 +25,7 @@
 Win32 compilation targeting the MS.NET framework 1.1
-You should compile MapServer, mapscript and all of the subsequent libraries
+You should compile MapServer, MapScript and all of the subsequent libraries
 using Visual Studio 2003. Download and uncompress the latest SWIGWIN package
 that contains the precompiled swig.exe Open the Visual Studio .NET 2003
 Command Prompt and step into the /mapscript/csharp directory. Edit makefile.vc
