[mapserver-commits] r8391 - in trunk/docs/mapscript: . php
Tue Jan 6 13:27:51 EST 2009
Author: aboudreault
Date: 2009-01-06 13:27:50 -0500 (Tue, 06 Jan 2009)
New Revision: 8391
   trunk/docs/mapscript/mapscript.txt
   trunk/docs/mapscript/php/index.txt
Update the projectionObj in Mapscript documentation.
Modified: trunk/docs/mapscript/mapscript.txt
--- trunk/docs/mapscript/mapscript.txt	2009-01-06 16:50:51 UTC (rev 8390)
+++ trunk/docs/mapscript/mapscript.txt	2009-01-06 18:27:50 UTC (rev 8391)
@@ -2112,6 +2112,9 @@
     Create new instance of projectionObj.  Input parameter *proj4* is a
     PROJ.4 definition string such as "init=EPSG:4269".
+getUnits() : int
+    Returns the units of a projection object. Returns -1 on error.
  rectObj
Modified: trunk/docs/mapscript/php/index.txt
--- trunk/docs/mapscript/php/index.txt	2009-01-06 16:50:51 UTC (rev 8390)
+++ trunk/docs/mapscript/php/index.txt	2009-01-06 18:27:50 UTC (rev 8391)
@@ -230,6 +230,7 @@
 string          fontsetfilename (read-only, set by setFontSet())
 labelcacheObj   labelcache (no members. Used only to be able to free the
                 the label cache (ex : map->labelcache->free())
+projectionObj   projection
 int             transparent   (deprecated, use outputFormatObj)
 int             interlace     (deprecated, use outputFormatObj)
 int             imagetype     (deprecated, use outputFormatObj)
@@ -696,6 +697,7 @@
 string          requires
 string          labelrequires
 hashTableObj    metadata
@@ -1789,7 +1791,12 @@
     $poPoint->setXY(-92.0, 62.0);
     $poPoint->project($projInObj, $projOutObj);
+Methods
+int getUnits()
 ScalebarObj Class
