[mapserver-commits] r8412 - in sandbox: MapServer opengl
Thu Jan 8 22:24:35 EST 2009
Author: jbourke
Date: 2009-01-08 22:24:35 -0500 (Thu, 08 Jan 2009)
New Revision: 8412
Added:
   sandbox/MapServer/Makefile.vc
Removed:
   sandbox/opengl/Makefile.vc
Moved remotely
Copied: sandbox/MapServer/Makefile.vc (from rev 8411, sandbox/opengl/Makefile.vc)
--- sandbox/MapServer/Makefile.vc	                        (rev 0)
+++ sandbox/MapServer/Makefile.vc	2009-01-09 03:24:35 UTC (rev 8412)
@@ -0,0 +1,211 @@
+# makefile.vc - Main MapServer makefile for MSVC++
+# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the other
+# MapServer command-line programs.
+# To use the makefile:
+#  - Open a DOS prompt window
+#  - Run the VCVARS32.BAT script to initialize the VC++ environment variables
+#  - Start the build with:  nmake /f makefile.vc
+# $Id: Makefile.vc 6648 2007-08-19 21:51:51Z tamas $
+MAPSERVER_ROOT = .
+!INCLUDE nmake.opt
+BASE_CFLAGS = 	$(OPTFLAGS)
+CFLAGS=$(BASE_CFLAGS) $(MS_CFLAGS)
+CC=     cl
+LINK=   link
+# Main MapServer library.
+MS_DLL = libmap.dll
+MS_OBJS = 	mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
+		mapparser.obj maplexer.obj maptree.obj \
+		mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
+		maplegend.obj maputil.obj mapscale.obj mapquery.obj \
+		maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
+		mapraster.obj cgiutil.obj mapsde.obj mapogr.obj maptime.obj \
+		maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj \
+		mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
+		mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj mapswf.obj \
+		mapgdal.obj mapwfs.obj mapwfslayer.obj mapows.obj maphttp.obj \
+		mappdf.obj mapcontext.obj mapdrawgdal.obj mapjoin.obj mapgraticule.obj \
+		mapmygis.obj mapimagemap.obj mapcopy.obj maprasterquery.obj \
+		mapogcfilter.obj mapogcsld.obj mapthread.obj mapobject.obj \
+		classobject.obj layerobject.obj mapwcs.obj mapgeos.obj strptime.obj \
+		mapcpl.obj mapio.obj mappool.obj mapsvg.obj mapregex.obj mappluginlayer.obj \
+		mapogcsos.obj mappostgresql.obj mapcrypto.obj mapowscommon.obj \
+		mapdebug.obj mapchart.obj mapagg.obj maptclutf.obj mapogl.obj mdstime.obj gd_topal.obj \
+		$(EPPL_OBJ) $(REGEX_OBJ)
+MS_HDRS = 	mapserver.h mapfile.h
+MS_EXE = 	mapserv.exe \
+                shp2img.exe legend.exe \
+		shptree.exe scalebar.exe sortshp.exe tile4ms.exe \
+		shptreevis.exe shptreetst.exe msencrypt.exe
+default: 	all
+all:		$(MS_LIB) $(MS_EXE) mapscriptvars
+$(MS_OBJS):	$(MS_HDRS)
+$(MS_DLL) $(MS_LIB_DLL):	$(MS_LIB)
+	link /dll $(LDEBUG) \
+	   $(MS_OBJS) $(EXTERNAL_LIBS) \
+	   /out:$(MS_DLL) /implib:$(MS_LIB_DLL)
+	if exist $(MS_DLL).manifest mt -manifest $(MS_DLL).manifest -outputresource:$(MS_DLL);2
+$(MS_LIB):	$(MS_OBJS)
+	if exist $(GDAL_DIR)\gdal.pdb copy $(GDAL_DIR)\gdal.pdb .
+	lib /out:$(MS_LIB) $(MS_OBJS)
+!IFDEF DLLBUILD
+$(MS_EXE):	$(MS_DLL) $(MS_LIB_DLL)
+!ELSE
+$(MS_EXE):	$(MS_LIB)
+!ENDIF
+gd::
+	cd gd143
+	nmake /f makefile.nt OPTFLAGS="$(OPTFLAGS)"
+	cd ..
+.c.obj:
+	$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
+.cpp.obj:
+	$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
+.c.exe:
+!IFDEF DLLBUILD
+	$(LINK) $(LDFLAGS) $*.obj $(LIBS_DLL)
+!ELSE
+        $(LINK) $(LDFLAGS) $*.obj $(LIBS)
+!ENDIF
+	if exist $@.manifest mt -manifest $@.manifest -outputresource:$@;1
+clean:
+	del *.obj
+	del $(REGEX_OBJ)
+	del *.lib
+	del *.dll
+	del $(MS_EXE)
+	del *.pdb
+	del *.exp
+	del *.ilk
+	del *.manifest
+!IFDEF DOT_NET
+	cd mapscript\csharp
+	nmake /f makefile.vc clean
+	cd ..\..
+!ENDIF
+!IFDEF JAVA_HOME
+	cd mapscript\java
+	cd ..\..
+!ENDIF
+!IFDEF PHP_HOME
+	cd mapscript\php3
+	cd ..\..
+!ENDIF
+!IFDEF PYTHON_HOME
+    cd mapscript\python
+    -del mapscript_wrap.c
+    -rmdir /s /q build
+    cd ..\..
+!ENDIF
+mapscriptvars: makefile.vc nmake.opt
+	-del mapscriptvars
+	echo $(MS_CURRENT) > mapscriptvars
+	echo $(MS_DEFS) -DWIN32 -D_WIN32 >> mapscriptvars
+	echo $(INCLUDES) >> mapscriptvars
+	echo $(LIBS_DLL) >> mapscriptvars
+	echo $(LIBS) >> mapscriptvars
+	findstr MS_VERSION mapserver.h | findstr define >> mapscriptvars
+install: $(MS_DLL) $(MS_EXE) python csharp java php
+	-mkdir $(BINDIR)
+	xcopy /y /r /d /f $(MS_DLL) $(BINDIR)
+	copy *.exe $(BINDIR)
+!IFDEF PYTHON_HOME
+    -mkdir $(BINDIR)\mapscript\python
+	xcopy /y /r /d /f .\mapscript\python\dist\*.zip $(BINDIR)\mapscript\python
+!ENDIF
+!IFDEF DOT_NET
+    -mkdir $(BINDIR)\mapscript\csharp
+	xcopy /y /r /d /f .\mapscript\csharp\*.dll $(BINDIR)\mapscript\csharp
+	xcopy /y /r /d /f .\mapscript\csharp\*.exe $(BINDIR)\mapscript\csharp
+	xcopy /y /r /d /f .\mapscript\csharp\*.manifest $(BINDIR)\mapscript\csharp
+	xcopy /y /r /d /f .\mapscript\csharp\*.config $(BINDIR)\mapscript\csharp
+!ENDIF
+!IFDEF JAVA_HOME
+    -mkdir $(BINDIR)\mapscript\java
+	xcopy /y /r /d /f .\mapscript\java\*.dll $(BINDIR)\mapscript\java
+	xcopy /y /r /d /f .\mapscript\java\*.jar $(BINDIR)\mapscript\java
+!ENDIF
+!IFDEF PHP_HOME
+    -mkdir $(BINDIR)\mapscript\php
+	xcopy /y /r /d /f .\mapscript\php3\*.dll $(BINDIR)\mapscript\php
+!ENDIF
+!IFDEF PYTHON_HOME
+python: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
+    $(SWIG) -python -shadow -o mapscript_wrap.c ../mapscript.i
+    $(PYTHON_HOME)\PCBuild\python.exe setup.py bdist
+    cd ..\..
+!ELSE
+python:
+!ENDIF
+!IFDEF DOT_NET
+csharp: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
+    cd ..\..
+!ELSE
+csharp:
+!ENDIF
+!IFDEF JAVA_HOME
+java: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
+    cd mapscript\java
+    cd ..\..
+!ELSE
+java:
+!ENDIF
+!IFDEF PHP_HOME
+php: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
+    cd mapscript\php3
+    cd ..\..
+!ELSE
+php:
+!ENDIF
+!IFDEF SDE_OPT
+plugins:  $(MS_DLL) $(MS_LIB_DLL)
+		-del mapsde.obj
+		$(CC) $(CFLAGS) -DUSE_SDE /c mapsde.c /Fomapsde.obj
+    link /dll /out:msplugin_sde_$(SDE_VERSION).dll mapsde.obj mapthread.obj mapserver_i.lib $(SDE_LIB)
+!ELSE
+plugins:
+!ENDIF
Deleted: sandbox/opengl/Makefile.vc
--- sandbox/opengl/Makefile.vc	2009-01-09 03:23:53 UTC (rev 8411)
+++ sandbox/opengl/Makefile.vc	2009-01-09 03:24:35 UTC (rev 8412)
@@ -1,211 +0,0 @@
-# makefile.vc - Main MapServer makefile for MSVC++
-# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the other
-# MapServer command-line programs.
-# To use the makefile:
-#  - Open a DOS prompt window
-#  - Run the VCVARS32.BAT script to initialize the VC++ environment variables
-#  - Start the build with:  nmake /f makefile.vc
-# $Id: Makefile.vc 6648 2007-08-19 21:51:51Z tamas $
-MAPSERVER_ROOT = .
-!INCLUDE nmake.opt
-BASE_CFLAGS = 	$(OPTFLAGS)
-CFLAGS=$(BASE_CFLAGS) $(MS_CFLAGS)
-CC=     cl
-LINK=   link
-# Main MapServer library.
-MS_DLL = libmap.dll
-MS_OBJS = 	mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
-		mapparser.obj maplexer.obj maptree.obj \
-		mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
-		maplegend.obj maputil.obj mapscale.obj mapquery.obj \
-		maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
-		mapraster.obj cgiutil.obj mapsde.obj mapogr.obj maptime.obj \
-		maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj \
-		mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
-		mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj mapswf.obj \
-		mapgdal.obj mapwfs.obj mapwfslayer.obj mapows.obj maphttp.obj \
-		mappdf.obj mapcontext.obj mapdrawgdal.obj mapjoin.obj mapgraticule.obj \
-		mapmygis.obj mapimagemap.obj mapcopy.obj maprasterquery.obj \
-		mapogcfilter.obj mapogcsld.obj mapthread.obj mapobject.obj \
-		classobject.obj layerobject.obj mapwcs.obj mapgeos.obj strptime.obj \
-		mapcpl.obj mapio.obj mappool.obj mapsvg.obj mapregex.obj mappluginlayer.obj \
-		mapogcsos.obj mappostgresql.obj mapcrypto.obj mapowscommon.obj \
-		mapdebug.obj mapchart.obj mapagg.obj maptclutf.obj mapogl.obj mdstime.obj gd_topal.obj \
-		$(EPPL_OBJ) $(REGEX_OBJ)
-MS_HDRS = 	mapserver.h mapfile.h
-MS_EXE = 	mapserv.exe \
-                shp2img.exe legend.exe \
-		shptree.exe scalebar.exe sortshp.exe tile4ms.exe \
-		shptreevis.exe shptreetst.exe msencrypt.exe
-default: 	all
-all:		$(MS_LIB) $(MS_EXE) mapscriptvars
-$(MS_OBJS):	$(MS_HDRS)
-$(MS_DLL) $(MS_LIB_DLL):	$(MS_LIB)
-	link /dll $(LDEBUG) \
-	   $(MS_OBJS) $(EXTERNAL_LIBS) \
-	   /out:$(MS_DLL) /implib:$(MS_LIB_DLL)
-	if exist $(MS_DLL).manifest mt -manifest $(MS_DLL).manifest -outputresource:$(MS_DLL);2
-$(MS_LIB):	$(MS_OBJS)
-	if exist $(GDAL_DIR)\gdal.pdb copy $(GDAL_DIR)\gdal.pdb .
-	lib /out:$(MS_LIB) $(MS_OBJS)
-!IFDEF DLLBUILD
-$(MS_EXE):	$(MS_DLL) $(MS_LIB_DLL)
-!ELSE
-$(MS_EXE):	$(MS_LIB)
-!ENDIF
-gd::
-	cd gd143
-	nmake /f makefile.nt OPTFLAGS="$(OPTFLAGS)"
-	cd ..
-.c.obj:
-	$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
-.cpp.obj:
-	$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
-.c.exe:
-!IFDEF DLLBUILD
-	$(LINK) $(LDFLAGS) $*.obj $(LIBS_DLL)
-!ELSE
-        $(LINK) $(LDFLAGS) $*.obj $(LIBS)
-!ENDIF
-	if exist $@.manifest mt -manifest $@.manifest -outputresource:$@;1
-clean:
-	del *.obj
-	del $(REGEX_OBJ)
-	del *.lib
-	del *.dll
-	del $(MS_EXE)
-	del *.pdb
-	del *.exp
-	del *.ilk
-	del *.manifest
-!IFDEF DOT_NET
-	cd mapscript\csharp
-	nmake /f makefile.vc clean
-	cd ..\..
-!ENDIF
-!IFDEF JAVA_HOME
-	cd mapscript\java
-	cd ..\..
-!ENDIF
-!IFDEF PHP_HOME
-	cd mapscript\php3
-	cd ..\..
-!ENDIF
-!IFDEF PYTHON_HOME
-    cd mapscript\python
-    -del mapscript_wrap.c
-    -rmdir /s /q build
-    cd ..\..
-!ENDIF
-mapscriptvars: makefile.vc nmake.opt
-	-del mapscriptvars
-	echo $(MS_CURRENT) > mapscriptvars
-	echo $(MS_DEFS) -DWIN32 -D_WIN32 >> mapscriptvars
-	echo $(INCLUDES) >> mapscriptvars
-	echo $(LIBS_DLL) >> mapscriptvars
-	echo $(LIBS) >> mapscriptvars
-	findstr MS_VERSION mapserver.h | findstr define >> mapscriptvars
-install: $(MS_DLL) $(MS_EXE) python csharp java php
-	-mkdir $(BINDIR)
-	xcopy /y /r /d /f $(MS_DLL) $(BINDIR)
-	copy *.exe $(BINDIR)
-!IFDEF PYTHON_HOME
-    -mkdir $(BINDIR)\mapscript\python
-	xcopy /y /r /d /f .\mapscript\python\dist\*.zip $(BINDIR)\mapscript\python
-!ENDIF
-!IFDEF DOT_NET
-    -mkdir $(BINDIR)\mapscript\csharp
-	xcopy /y /r /d /f .\mapscript\csharp\*.dll $(BINDIR)\mapscript\csharp
-	xcopy /y /r /d /f .\mapscript\csharp\*.exe $(BINDIR)\mapscript\csharp
-	xcopy /y /r /d /f .\mapscript\csharp\*.manifest $(BINDIR)\mapscript\csharp
-	xcopy /y /r /d /f .\mapscript\csharp\*.config $(BINDIR)\mapscript\csharp
-!ENDIF
-!IFDEF JAVA_HOME
-    -mkdir $(BINDIR)\mapscript\java
-	xcopy /y /r /d /f .\mapscript\java\*.dll $(BINDIR)\mapscript\java
-	xcopy /y /r /d /f .\mapscript\java\*.jar $(BINDIR)\mapscript\java
-!ENDIF
-!IFDEF PHP_HOME
-    -mkdir $(BINDIR)\mapscript\php
-	xcopy /y /r /d /f .\mapscript\php3\*.dll $(BINDIR)\mapscript\php
-!ENDIF
-!IFDEF PYTHON_HOME
-python: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
-    $(SWIG) -python -shadow -o mapscript_wrap.c ../mapscript.i
-    $(PYTHON_HOME)\PCBuild\python.exe setup.py bdist
-    cd ..\..
-!ELSE
-python:
-!ENDIF
-!IFDEF DOT_NET
-csharp: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
-    cd ..\..
-!ELSE
-csharp:
-!ENDIF
-!IFDEF JAVA_HOME
-java: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
-    cd mapscript\java
-    cd ..\..
-!ELSE
-java:
-!ENDIF
-!IFDEF PHP_HOME
-php: mapscriptvars $(MS_DLL) $(MS_LIB_DLL)
-    cd mapscript\php3
-    cd ..\..
-!ELSE
-php:
-!ENDIF
-!IFDEF SDE_OPT
-plugins:  $(MS_DLL) $(MS_LIB_DLL)
-		-del mapsde.obj
-		$(CC) $(CFLAGS) -DUSE_SDE /c mapsde.c /Fomapsde.obj
-    link /dll /out:msplugin_sde_$(SDE_VERSION).dll mapsde.obj mapthread.obj mapserver_i.lib $(SDE_LIB)
-!ELSE
-plugins:
-!ENDIF
