[mapserver-commits] r8420 - in trunk/mapserver: . mapscript/php3
Fri Jan 9 09:05:47 EST 2009
Author: aboudreault
Date: 2009-01-09 09:05:46 -0500 (Fri, 09 Jan 2009)
New Revision: 8420
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapscript/php3/mapscript_i.c
   trunk/mapserver/mapscript/php3/php_mapscript.c
   trunk/mapserver/mapscript/php3/php_mapscript.h
Added ms_newMapObjFromString mapObj constructor in PHP/Mapscript
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2009-01-09 12:44:21 UTC (rev 8419)
+++ trunk/mapserver/HISTORY.TXT	2009-01-09 14:05:46 UTC (rev 8420)
@@ -12,6 +12,8 @@
 Current Version (5.3-dev, SVN trunk):
+- Added ms_newMapObjFromString mapObj constructor in PHP/Mapscript (#2399)
 - Add support to compile mssql2008 when SDE or ORACLE is not compiled (#2851)
 - Add support for creating debug builds for the plugins on Windows
Modified: trunk/mapserver/mapscript/php3/mapscript_i.c
--- trunk/mapserver/mapscript/php3/mapscript_i.c	2009-01-09 12:44:21 UTC (rev 8419)
+++ trunk/mapserver/mapscript/php3/mapscript_i.c	2009-01-09 14:05:46 UTC (rev 8420)
@@ -52,6 +52,15 @@
+mapObj *mapObj_newFromString(char *map_text, char *new_path) {
+      if(map_text && strlen(map_text))
+        return msLoadMapFromString(map_text, new_path);
+      else { /* create an empty map, no layers etc... */
+        return msNewMapObj();
 void  mapObj_destroy(mapObj* self) {
     msFreeMap(self);
Modified: trunk/mapserver/mapscript/php3/php_mapscript.c
--- trunk/mapserver/mapscript/php3/php_mapscript.c	2009-01-09 12:44:21 UTC (rev 8419)
+++ trunk/mapserver/mapscript/php3/php_mapscript.c	2009-01-09 14:05:46 UTC (rev 8420)
@@ -92,6 +92,7 @@
 DLEXPORT void php3_ms_tokenizeMap(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_new(INTERNAL_FUNCTION_PARAMETERS);
+DLEXPORT void php3_ms_map_new_from_string(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_clone(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_setProperty(INTERNAL_FUNCTION_PARAMETERS);
 DLEXPORT void php3_ms_map_setProjection(INTERNAL_FUNCTION_PARAMETERS);
@@ -593,6 +594,7 @@
     {"ms_getversion",   php3_ms_getversion,     NULL},
     {"ms_getversionint",php3_ms_getversionint,  NULL},
     {"ms_newmapobj",    php3_ms_map_new,        NULL},
+    {"ms_newmapobjfromstring",    php3_ms_map_new_from_string,        NULL},
     {"ms_newlayerobj",  php3_ms_lyr_new,        two_args_first_arg_force_ref},
     {"ms_newclassobj",  php3_ms_class_new,      one_arg_force_ref},
     {"ms_newpointobj",  php3_ms_point_new,      NULL},
@@ -1701,6 +1703,72 @@
+ *                        ms_newMapObjFromString()
+/* {{{ proto mapObj ms_newMapObjFromString(string mapfileString)
+   Returns a new object to deal with a MapServer map file. */
+    pval        *pMapText, *pNewPath;
+    mapObj      *pNewMap = NULL;
+    int         nArgs;
+    char        *pszNewPath = NULL;
+    HashTable   *list=NULL;
+#if defined(WIN32)
+    char        szPath[MS_MAXPATHLEN], szMapText[MS_MAXPATHLEN];
+    char        szNewPath[MS_MAXPATHLEN];
+#endif
+    nArgs = ARG_COUNT(ht);
+    if ((nArgs != 1 && nArgs != 2) ||
+        getParameters(ht, nArgs, &pMapText, &pNewPath) != SUCCESS)
+        WRONG_PARAM_COUNT;
+    convert_to_string(pMapText);
+    if (nArgs >= 2)
+        convert_to_string(pNewPath);
+        pszNewPath = pNewPath->value.str.val;
+    /* Attempt to open the MAP file
+#if defined(WIN32)
+    if (pszNewPath)
+        msBuildPath(szNewPath, NULL, pszNewPath);
+        pNewMap = mapObj_newFromString(szMapText, szNewPath);
+    else
+       pNewMap = mapObj_newFromString(szMapText, pszNewPath);
+#else
+    pNewMap = mapObj_newFromString(pMapText->value.str.val, pszNewPath);
+#endif
+    if (pNewMap == NULL)
+        _phpms_report_mapserver_error(E_WARNING);
+        php3_error(E_WARNING, "Failed to open map file %s",
+                            pMapText->value.str.val);
+        RETURN_FALSE;
+    /* Return map object */
+    _phpms_build_map_object(pNewMap, list, return_value TSRMLS_CC);
  *                        map->clone()
Modified: trunk/mapserver/mapscript/php3/php_mapscript.h
--- trunk/mapserver/mapscript/php3/php_mapscript.h	2009-01-09 12:44:21 UTC (rev 8419)
+++ trunk/mapserver/mapscript/php3/php_mapscript.h	2009-01-09 14:05:46 UTC (rev 8420)
@@ -59,6 +59,7 @@
 mapObj         *mapObj_new(char *filename, char *new_path);
+mapObj         *mapObj_newFromString(char *map_text, char *new_path);
 void            mapObj_destroy(mapObj* self);
 mapObj         *mapObj_clone(mapObj* self);
 int             mapObj_setRotation(mapObj* self, double rotation_angle );
